Question about iiyama E431S-B 17" LCD Monitor
Power on, not picture, blue indicator keeps coming on, going off plus a click at each change. Ghost flicker on screen but not enough to distinguish a picture. It was working perfectly for the last 5 years until now (in use every day).
  • 11,361 Answers
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on May 16, 2010
On my HP Pavillion laptop I have a static line and ghost URL across the bottom of my screen
Reinstall browser. Is that only in browser or everywhere ? Consider reinstalling Windows again
Jan 03, 2013 | HP Pavilion dv4-1430us Notebook
The picture has a pink and reddish hue
Any magician can make a trick look easy - but NOTHING replaces years of training and experience. That said, here's your answer:
  1. Enter the I2C Service Menu, be sure the power is OFF.
  2. On the front control panel, press and hold the INPUT button. Then press the POWER button for two seconds. You may keep the INPUT button depressed until you see the OSD with the Service Menu displayed.
If you don't see the service menu, please repeat Process making sure you wait until the Power blinking LED stops.
COPY DOWN THESE SETTINGS:
IMPORTANT: The following are Service Adjustments. These Data Values are lost when Memory Initialization is preformed. It's important to write the values down before proceeding.
H Position: ________
V Position: ________
LCD ADJUST (NOT LCD DRIVE) (Arrow right)
GHOST (Arrow right)> LCD ADJUST =SHP: _______
(Press Select) LCD ADJUST GHOST=R: _______
(Press Select) LCD ADJUST GHOST=G: _______
(Press Select) LCD ADJUST GHOST=B: _______
(Press Select, then Exit)
V COM (Arrow right)> V COM-R: Set For Minimum Flicker
(Press Select) V COM-G: Set For Minimum Flicker
(Press Select) V COM-B: Set For Minimum Flicker
NRSH (Arrow right)> VS-DAT 1 through 9: _______, _______, _______, _______, _______, _______, _______, _______, _______ (Press exit twice)
Scroll down to: “TA1383” then (Arrow right)
Scroll down to:
CONTM1: _______
CONTS1: _______ (Press exit)
After writing down these values, please continue:
Nov 11, 2007 | Hitachi 50V500 50 in. HD-Ready LCD...
Samsung screen flicker
Have you recently changed the resolution/refresh rate? This is usually set automaticallly by windows by check anyway.
Right click the desktop and select Screen Resolution
Change the slider/dropdown to the (recommended) selection and click apply. Click keep changes if it appears.
Still having issues then go back into Screen Resolution and click the "advanced settings" blue link on the bottom right.
Click on the "Monitor" tab and select the highest refresh rate you can and click ok. again click "keep settings" if it appears.
Dec 23, 2012 | Samsung X Computers & Internet
TV will not turn on? Blinking LED,won't turn on? Changing back and forth from Blue and Yellow; which is on and off from panel lights?
the red picture is because the optical block is bad now this part cost about $500 plus labor , when you took the lamp out you need to put the door back otherways the tv wont wort
Jan 27, 2012 | Toshiba 62MX195 62" HDTV
Hi! I am experiencing the following three
Hi Rafael,
First of all thank you for posting your question here at Fixya.
Please confirm if the brand and model number above is correct.
Blinking of the the LED (yellow and blue) at the front panel indicating that the lamp door cover is not seated properly. This cover will engaged to a micro switch giving the signal to the processor, once it is in open position, the unit will not power up and will experienced that kind of blinking error code. Go back to the lamp door cover and ensure that it is properly seat-in.
3D, 2D, red/green/blue ghost on the picture and letters means that the convergence circuitry gone bad. Symptoms is not connected to the light engine. The faulty parts is the convergence chips(IC). This chips are mounted on the large aluminum heat sink and starts with STKXXXX-XX (X means number). The most common STK chips used on Projection TV's is the STK392-110. You have to replaced them both on the board to resolve the issue(red ghosting). It is necessary also to check the resistance value of the resistors around its circuitry using the multimeter. For more info how to repair a convergence problem, watch the video below.
Jdvillanueva
Projection TV flickering blue screen, cannot access devices
Did you ever get this problem solved. I am having the exact same problem?
Nov 09, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Acer Aspire 5735 LCD changes bight-dim-bright, etc.
You could have a faulty inverter, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Jun 24, 2009 | Acer Aspire 5735 Notebook
Laptop screen goes blank at random times.
Defective CCFL backlight may has the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
Go to www.lcdparts.net for parts detail and installation
Feb 28, 2009 | Dell Computers & Internet
Monitor flickring
  1. Flickering screen display
    Flickering on the screen can be caused by defective hardware in the computer or by improperly installed software, but it can also be caused by interference from external devices. The following examples describe situations in which your screen could start flickering:
    • Screen starts flickering because of interference caused by devices which generate magnetic fields, for instance:
      • a TV set
      • a laser printer
      • another monitor
      • fluorescent lights
      • hidden power lines
    • Apart from interference, an incorrect setting in your system CMOS setup can also cause flickering. On some systems it is possible to distinguish between interlaced and non-interlaced monitors. The setup of your system should always be colour non-interlaced.
    • Proximity to the monitor of fans, air-conditioning units or other devices with rotating motors.
    • The number of devices using power from the same electrical line. Are you overloading the plug?
    • Monitor placed on an unstable surface.
    • Improper video drivers, this is a software problem, see section B
    • An improperly configured or a defective video card.
  2. Reinstalling the video drivers
    1. Start the computer.
    2. Click Start, select Settings, and click Control Panel.
    3. Double-click the System icon.
    4. Select the Device Manager tab in the System Properties window.
    5. Make sure that View devices by type is selected and locate Display adapters and Monitor in the list.
    6. Click the plus sign (+) in front of both items to get a list of installed devices.
    7. You need to remove every device by highlighting it and clicking the Remove button and OK when the warning message appears.
    8. After doing so for both items, they should disappear from the list.
    9. Close the Device Manager by clicking OK, and you will return to the Control Panel.
    10. Double-click the Add New Hardware icon.
    11. Click Next, select Yes when it asks "Do you want Windows to search for your new hardware?", and click Next twice to start searching for new hardware.
    12. This will take a few minutes and, after it is finished, you will have to restart the computer. Windows 95 or higher will automatically set up the correct monitor and video drivers.
    13. If the screen is still flickering, click Start, select Settings, and click Control Panel.
    14. Double-click the Display icon and select the Refresh tab.
    15. Change the Monitor Refresh Rates until the flickering disappears.
    16. If the flickering remains, go to step C.
  3. Troubleshooting
    1. If it is possible, connect a different monitor to the computer. If the flickering disappears, it is a fair indication that the monitor is defective, otherwise go to the next step.
    2. Set up the computer and the monitor on a different place in your house. If the flickering disappears now, it is most likely an interference caused by something in the original location. Check for devices which can cause interference.
    3. If the flickering persists, check the setup of your system. If available in the setup, make sure that the option Monitor Type is configured as Colour Non-Interlaced.
Dec 24, 2007 | E-Machines E17T 17" Flat Panel LCD Monitor
iiyama E431S-B 17" LCD Monitor Logo
265 people viewed this question
Top iiyama Computers & Internet Experts
William Miller
William Miller
Are you an iiyama Computer and Internet Expert? Answer questions, earn points and help others
