Question about Proform Sport 1000 Folding Treadmill PFTL91205 - !
Pro Form Treadmill 625 EX Wide Trac
When we program the mph's we are unable to set the desired mph, the speed either increases or decreased and will not stay set.
  • John Mazmanian
    John Mazmanian May 15, 2010
    Is the speed variation significant and is it a gradual increase or decrease
  • hredmond May 16, 2010
    You can set it for 3.5 and it will go to 4.5, show 4.5, then all of a sudden it will go to 2.7 and keeps changing. Both the actual treadmill and the electronic display keep changing.
    President:
  • Proform Master
  • 832 Answers
1. You may have a worn belt and deck problem ( #1 problem on treadmills ). Test by the following procedure:
a) without the power on stand on the walking belt
b) push the belt in the direction it normally turns
c) if the belt is very difficult to turn (on most treadmill) this means that you have high belt/deck friction.
You must physically inspect the belt and deck. The deck should be smooth. The belt should have a consistent feel from side to side (a belt can be worn out without any sensory signs of a problem). If you feel deep grooves in the deck or uneven wear on the underside of the belt, part replacement is necessary. Continued use of your treadmill may damage expensive electrical components. If their is no signs of excessive wear then the next step is to lubricate the deck follow this procedure:
Before applying lubricant, the belt must have the tension reduced and cleaned deck. Loosen the tension roller by following the instructions in your owner’s manual. Do not loosen the bolts in the tension roller too far or the bolts will come out of the roller shaft. This step may not be necessary for your treadmill model or belt and deck condition.
Contaminants are the worst enemy of your belt and deck. Some treadmills may have an excessive accumulation of dirt and contaminants. If these are trapped during the belt lube process, significant damage will occur. Lift the belt and slide a moist towel between belt and deck, slide the towel the length of the unit to catch the contaminants do this a number of times inspect towel and need be use a fresh towel and repeat cleaning let dry then apply the lube in the center upper third of deck then start unit and walk on it @ 1-2mph for about 5 min. You may purchase the lube from National Gym Supply @ gympart.com Part# TM001 or call them @ 1-800-496-7278 their on the west coast. At this point I believe your problem should be resolved if the above procedures have taken care of problem take a look at the next step, as mentioned the #1 cause of treadmill failure is lack of maintenance of the belt and deck.
On occasion, you may have already damaged the DC board if you have high belt/deck friction. If the belt walks freely, you have a different problem.
2. If it passes the belt/deck checks, you may have a DC board output problem. If the belt tests ok and you have a speed variation, try this test:
  1. Set the speed to 2.5 MPH. Let the treadmill run without anyone on the belt. Check to see if the speed is constant or if there is a variation.
  2. If there is no variation, step on the belt. If the speed slows down or speeds up, you may have an output problem on the DC board. This is the board that connects directly to the motor. Check the speed sensor if it is a magnetic sensor unit ( Under motor shroud usually attached on the left hand side of frame with 1/8' clearance between sensor and front roller pulley) you can test continuity with a multi meter or replace with a new part to test. Many times passing a kitchen magnet in front of the signal will make a speed display on the console if the magnetic sensor is good.
Posted on May 16, 2010
How do i set the cruise control on my 1994 mercedes c220 elegance automatic
Cruise Control
Any given speed above approximately 22 mph (35 km/h) can be maintained with the cruise control by operating the lever.
-see photo
  1. Accelerate and set: Lift lever briefly to set speed. Hold lever up to accelerate.
  2. Decelerate and set:
    Depress lever briefly to set speed. Hold lever down to decelerate.
    Normally the vehicle is accelerated to the desired speed with the accelerator. Speed is set by briefly pushing
    the lever to position 1 or 2. The accelerator can be released. The speed can be increased (e.g. for passing)
    by using the accelerator. As soon as the accelerator is released, the previously set speed will be resumed automatically. If a set speed is to be increased or decreased slightly, e.g. to adapt to the traffic flow, hold lever in position 1 or 2 until the desired speed is reached, or briefly tip the control lever in the appropriate direction for increases or decreases in 0.6 mph (1 km/h) increments. When the lever is released, the newly set speed remains.
  3. Canceling
To cancel the cruise control, briefly push lever to position 3.
When you step on the brake or the vehicle speed drops below approx. 22 rnph (35 km/h), for example when driving upgrade, the cruise control will be canceled.
4. Resume
If the lever is briefly pushed to position 4 when driving at a speed exceeding approx. 22 mph (35 km/h), the vehicle resumes the speed which was set prior to the cancellation of the cruise control. The last memorized speed is canceled when the key in the steering lock is turned to position 1 or 0.
Note:
If the engine does not brake the vehicle sufficiently while driving on a downgrade, the speed you set on the cruise control may be exceeded and you may have to step on the brake pedal to slow down.
As soon as the grade eases, the cruise controlled speed will again be maintained as long as the brakes were not previously applied, or the lever may be used to resume the previously set speed if the brakes were applied.
http://www.benzworld.org/forums/attachments/w202-c36-c43/153145d1197313761-pdf-owners-manual-w202-1995-2000-1999-c280_owners_manual.pdf
Feb 14, 2015 | Mercedes-Benz C-Class Cars & Trucks
Speed changes on it own
speed controller is malfunctioning
Dec 11, 2013 | Weslo Epic 10pi Rear Roller For Model...
Life fitness 95t speeds up after confirming slower speed in cool down mode, and also pauses after touching increase button on screen. both issues are dangerous
book an engineer, sound like motor controller, loose belt could also be a issue, needs a safety check where are you based ?
Jan 27, 2013 | Life Fitness Exercise & Fitness
Does anyone know how to change Livestrong LS10.0t treadmill from mph to kph?
Must enter the engineer mode. Turn the machine ON. Wait until you see the "Select user" screen.
1 - Press and hold the key to increase the incline and the key to decrease the speed for 3 to 5 seconds.
2 - Use the arrows to increase speed to get to Eng3 program (or the arrows next to the Enter button).
3 - Press "Enter"
4 - Then press the green start button until KM appears on the screen.
Apr 03, 2012 | Avanti Exercise & Fitness
My treadmill will start and you can increase speed and incline but fan will not work and you can not decrease speed or incline. And I can not stop the treadmill. I have to emer. stop.
I'm not sure if this will help.
First I was unable to identiy your model. Star Trac makes 'S Series' treadmills and Pro Tread DC (5500 Pro S model) treadmills. Can you be more specific on your model?
Second. I have used Star Trac customer service in the past and they are the best. They are responsive, and knowledgeable, and will provide troubleshooting flowcharts to help you solve your problem. I highly recommend giving them a call.
Hope this helps,
Kurt
Jan 21, 2011 | Startrac Fitness Products Star Trac Pro S...
My Pro-form 980 CS will not start. I plug the key
Press the Stop and the Speed Up keys down while inserting the safety key. This should get you into calibration mode. Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, or the like. This means that it passes the EPROM test. If you cannot get into calibration or if the EPROM test fails then the upper console will have to be replaced.
If you get pass to this point then proceed with the calibrating the incline and speed.
Press either incline key and the incline will calibrate automatically.
Be careful the treadmill will run at full speed in the next mode DO NOT STAND ON THE WALKING BELT.Press the Speed Up key and hold it down until 85 is shown in the Distance window (some models may show the 85 number in another window).
If the top speed of the treadmill does not match the displayed speed on the computer console, adjust the max speed potentiometer (pot) on the motor control board. This is the board that the red and black motor wires connect directly into in the motor area. The Max Speed pot is clearly labeled
The max speed potentiometer is a small square with a mobile center and is located in one corner of the board and is labeled MAX SPD. It is near the harness that carries the speed signal labeled H,W,L. Using a small insulated screwdriver adjust this potentiometer clockwise to speed up and counter-clockwise to slow down the max speed of the treadmill. A tiny turn of this potentiometer will make a big difference in speed so be careful when making adjustments.
It is not important to get the speed set exactly at the max speed of the treadmill but do make sure to get the speed within .2 MPH of the max speed of the treadmill. For instance if the max speed of the treadmill is 10 MPH, make sure to have the speed set between 9.8 MPH and 10.2 MPH. Some models have a 12 MPH top speed, so please check your manual if you aren’t sure.
After completing calibration of the speed, press the Speed Down key. The treadmill will automatically return to 0 MPH. Please allow the unit to stop completely before continuing. Press the Stop key once and remove the safety key.
Jun 12, 2010 | Proform 980 CS Treadmill
I have a proform 785..the problem is the speed and incline decreases all of a sudden like within a minute...i raised the speed to 4 and it dropped to 2 within 1 min and same thing with the incline it...
Unplug unit remove motor shroud then start calibration procedure.
Press the Stop and the Speed Up keys down while inserting the safety key. If you cannot get into calibration then upper console needs to be replaced.
Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, or the like. This means that it passes the EPROM test. At this point if it show 2F FF or Fail then upper console needs to be replaced.
BE CAREFUL, THE TREADMILL WILL RUN AT FULL SPEED IN THIS NEXT MODE! DO NOT STAND ON WALKING BELT.
If the top speed of the treadmill does not match the displayed speed on the computer console, adjust the max speed potentiometer (pot) on the motor control board. This is the board that the red and black motor wires connect directly into in the motor area. The Max Speed pot is clearly labeled.
Jun 11, 2010 | Proform 785 CS Personal Trainer Treadmill
Describe how to unfold a treadmill, pro form ex
Hold the upper end of the treadmill with your right hand on the back end of the unit. Using your left hand, pull the lock knob to the left and hold it. Pivot the treadmill down until the frame is past the pin on the lock knob. Note: You may need to push the handrail to the side slightly. 2. Move in front of the back end and hold the treadmill firmly with both hands, and lower the treadmill to the floor. CAUTION: To decrease the possibility of injury, bend your legs and keep your back straight
May 31, 2010 | Proform Exercise & Fitness
How do you change speed from KPH to MPH
To select the settings mode, first remove the key from the console. Then, hold down the Stop button while reinserting the key into the console.When the settings mode is selected, the display will show the word ENGLISH or METRIC to indicate which system of measurement is selected. To change the system of measurement, first highlight UNITS and press the User/Enter button. Next, press the increase or decrease button beside the User/Enter button to select the desired system of measurement. Then, press the User/Enter button.To exit the settings mode at any time, remove the key from the console.
May 07, 2010 | Nordic Track Nordictrack Apex 6500 Reflex...
My Nordic Track treadmill has has 10 speeds (1mph
You should have a speed arrow up & down, this increases and decreases the speed in .1 mph. Try this control and see how the unit re-acts if the speed does not adjust in .1 mph increments or it stay the same either way it sounds like an upper board issue. Go to iconfitness.com go to customer service the replacement parts put you M# and will give part# and pricing.
RULE OF THUMB: IF REPAIR IS MORE THAN THE THE PURCHASE PRICE OF UNIT DOE NOT REPAIR
Feb 27, 2010 | Nordic Track NordicTrack Treadmill, A2550
Proform Sport 1000 Folding Treadmill PFTL91205 - ! Logo
651 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
