Question about Kenmore 15522 Built-in Dishwasher
Leaking from the door around hinge? - Kenmore 15522 Built-in Dishwasher
  • Kenmore Master
  • 43,501 Answers
Here is a tip that I wrote about leaking dishwashers...
There also is a link in there to another tip on how to buy parts online for your dishwasher...
Leaking Dishwasher
http://www.fixya.com/support/r4546178-leaking_dishwasher
heatman101
Posted on May 15, 2010
GE front loader leaking new door hinge on left side... It is not down spout but that the gasket didn't contact door on that side allowing leak door will push .5 -1 inch on hinge side. M#Wbvh6240fww
Recheck the door hinge install. Sound like the hinge is not installed properly leaving a gap on the hinge side. There are sometimes notches or hooks on the hinges that need to be in holes or cutouts on the washer body for proper fit. if the hinge is not in the holes right it will stick out from the body and leak.
May 16, 2015 | GE Washing Machines
Lg p/no 3850dd3006a leaks at door
Every dishwasher door has a door seal. If the dishwasher is leaking water, it might be that the door seal is defective or worn out. Try closing the dishwasher door on a sheet of paper and see if the door seal is making good contact all the way around the door. If not, replace the door seal. If the door seal is good or has been replaced and there is still a leak check the door hinges. If the hinges are bent the door will not close properly and the hinges will need to be replaced
Jun 19, 2014 | LG Dishwashers
Leak on rinse cycle aotpoint aquarius wmf 540
Check the door seal.could have small rip/ tear around Hinge or door lock position....
Nov 06, 2013 | Hotpoint Washing Machines
How do I adjust the drivers door on a 2006 pontiac montana SV6 air is leaking around the door.
Take the fender off. then loosen the door hinge bolts. Move the door left or right up or down in or out until the crack between the door and the pillar looks straight and even. Then do the same with the fender. Chances are the door hinges need replacing.
Oct 25, 2013 | 2006 Pontiac Montana SV6
Dishwasher leaking from door hinges
Hello, your unit is leaking from the door hinges due to the inner seal on the inside of the tub that the door closes against needs to most likely be replaced if you have any further questions message me back Thanks
Rick
Sep 24, 2011 | KitchenAid Dishwashers
The water is leaking out of the door
The seal around the doors is broken. Is there anything keeping the door from closing right? Has there been any damage to the door ?(somebody walking in it damaging the hinges?)
Dec 06, 2009 | Washing Machines
My admiral is leaking at the bottom of the door. I have checked & cleaned all around the seals that made it worse.
The most common reason for leaks is a failed/cracked gasket. Replacing it is actually not as hard as it appears.
The second reason for leaking is damaged/bent (sprung) hinges that, when the door is closed/latched do not tightly seal the door against the gasket.
Please report what you find, OK?
Aug 05, 2009 | Admiral 24 in. DDB1501AWW Free-Standing...
Machine is leaking detergent
check inner gasket for small hole
u can take front off by removing screws from around inside door frame (including hinge screws) the panel will pull out towards u then u might be able to c where its leaking better
Jun 01, 2008 | Maytag Neptune MAH7500WH Front Load Washer
The top hinge of my Neff integrated fridge freezer has broken so the door won't open and shut properly. Neff are sending replacement hinges but as a temporary repair I intend to swop the hinges around...
The top hinge of my Neff integrated fridge freezer has broken so the door won't open and shut properly. As a temporary repair I intend to swop the hinges around -replacing the top hinge with the middle one but can't see how to remove the hinges. Can anyone help?
May 02, 2008 | Refrigerators
Open Questions:
Kenmore 15522 Built-in Dishwasher Logo
69 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
