Question about Compaq Presario 700 470024-192 Notebook
I don't have audio device - Compaq Presario 700 470024-192 Notebook
    Genius:
  • 1,354 Answers
It shows a no audio ouput device is installed in the lower right area. I have tried scan for hardware changes and it still doesnt work. is there a way i can just download a new audio output device?
Try this,
1 Go to Device manager and look for sound and expand it. 2. Unable to find Device manager ?? Then Go to Start button, click Control Panel, click System and Maintenance, and then click Device Manager.?If you are prompted for an administrator password or confirmation, type the password or provide confirmation. 3.Make sure you don't have a symbol "!" on the Default Audio Driver. 4.If you do/don't just right click on it and go to properties and click on upgrade.
Another solution could be if you click on your sound icon at the bottom right and expand it. You might have one out of x many different sound mixer muted. Unmute them all.
If this helpful, please give a testimonial and vote by pressing button thumbs up.
Sincerely, Thiyaga
Aug 27, 2011 | Computers & Internet
I have no sound at all, not sure wot to do. says something about no audio devices are installed,
hello jenz8860, try open device manager (run type devmgmt.msc), if u find question mark on your audio device then u need to install audio driver.
to install audio driver use motherboard driver, insert to CDROM, right click the audio device on device manager then update driver. choose recommended option then click next and follow the instruction. your audio device will automatically installed. if it success installed then u need to restart your PC.
if there is no problem in device manager, high possibility it's on hardware problem, try to see cable connection between speaker and PC (use back panel connection, don't use front panel audio, this to make sure the connection is good), if it's ok then mostly problem came from your speaker. try to use another speaker.
hope this useful, regards.
Aug 26, 2011 | Audio Players & Recorders
"no audio output device is
I understand that audio output device is very important to a laptop. But don't worry there's a website where you can download the device for free.
Please just click_here so that you will be directed to the exact site.
Thanks.
Aug 22, 2011 | Compaq Presario 700 470024-192 Notebook
My sound is not working its says no audio ouput device is installed
- it seems that you don't have an audio driver installed
- go to device manager and look for other device or an option with exclamation point or question mark
- right click and update driver
Jul 09, 2011 | Computers & Internet
My sound hardware don't works even when I've installed the drivers... so, what can I do?
You can check or updates on the driver, also, check in the audio options,sometimes the audio device is disabled from there even after installing the driver. How to do so depends on your Operative System,but if you have the speaker icon on your tray you can right-click it and select the "playback devices" or "recording devices" depending on which is not working. Click on the device that seems to be disabled and click the "Properties" button. Somewhere in that window (usually in the lower area) there will be a drop-down menu that has the options of "use this device (enable)" or "Don't use this device (disabled)" pick the first to enable the device that is not working.
May 26, 2011 | Computers & Internet
Please Help. I hv HP Compaq dc7600 Convertible Minitower PC Sound Problem.... control panel--->sound and audio devices-->No audio device
well first after turning the computer on, immediately press F10....go to security and check if the audio is turned on (not invisible) if it is go to pci devices and check there if the sound is enabeled, don t forget to press F10 to accept values and reboot the computer goodluck
Oct 17, 2010 | HP Compaq dc7600 Convertible Minitower PC...
Don"t hear anything at all.
control panel sounds and audio devices,audio make necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow? right click re-install drivers
good luck
Aug 29, 2010 | HP (153147-001) Sound Card
Can't hear playback. Windows Vista - Playback device says usb Audio Codec
here is what ION is telling people (short version) this is for vista or win7
1. Visit www.ionaudio.com/ezvc to download the latest EZ Converter software.
2. install new software if needed,
3. connect ION Audio USB. make sure its ON (if it has a switch)
Setup Procedure
1. Start then Control Panel.
2. double-click Hardware and Sound.
3. double-click Sound.
4. At top select Playback tab. choose the audio output device.
Don’t chose “speakers-usb audio codec” (that’s your ION) don’t chose modem
5. click Set Default.
6. select Recording tab at top of Sound Control Panel. choose "Microphone – USB Audio Codec" as the default device. (that’s the ION)
7. Click Set Default.
8. click Properties. select Advanced tab
9. set the Default Format setting to 2-channel, 16 bit 44100 Hz (CD Quality).
10. Un-check the two boxes under Exclusive Mode. Click Apply
11. select Levels tab from the top of the Sound Control Panel.
12. Set the level slider to 4. Click Apply, click OK to close the window.
Have everything set up and running, if you have to call this number for help.
401-658-3743 ext. 1405
Jun 25, 2010 | ION Audio iTTUSB Turntable
C707TU LAPTOP DEVICE DRIVER WIN XP BASED
I don't know if you are using a cd from HP whith the windows xp software on it, because I done something like that before and didn't work, you have to find a cd from hp with windows hp software intallation on it otherwise you will have problems, after the installation you can search for the update drivers from hp.com.
Dec 17, 2007 | Computers & Internet
Compaq Presario 700 470024-192 Notebook Logo
61 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
