Question about Exercise & Fitness
I hav a tunturi cross trainer 6 and the main axle bolt has sheared off. can i purchase the main part that hinges the beck wheel
    President:
  • 832 Answers
Call Accell Fitness of North America they are the Tunturi Distributors Contact number is 1-800-388-6887
Posted on May 15, 2010
My Tunturi C45 cross trainer has no display when turned on, can you help?
If you wish to get some details about treadmill repair ; visit the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Dec 27, 2016 | Tunturi Exercise & Fitness
Need a repair to crosstrainer
Sounds like the pulley (bearing) in the back is loose or broken
Apr 27, 2014 | Tunturi C80 Elliptical Cross Trainer
Broken axles on elliptical trainers
I would call and get the prices, if you do the work it is cheaper than replaciong them.
Mar 15, 2014 | Exercise & Fitness
Tunturi C35 clunks
Download: www.manualslib.com/manual/184017/Tunturi-C35 for how to get the owner's manual. If your cross trainer is anything like mine there are joints all over the place to be adjusted and tightened and lubricated all the time. THe clunking can be from any or all of them....check each joint for excessive play and adjust to a reasonable tension.
Jan 02, 2013 | Exercise & Fitness
How do you remove an axle on the right rear of a 1999 explorer? it has a leaking wheel seal.
1. Drain diff if it has a plug.
2. Remove rear cover
3. Undo cross pin bolt and slide the cross pin out of the carrier
4. Push axle shaft in so you can remove the C clip
axle retainers
5. Slide axle out of housing.
6. Remove axle seal and then replace axle seal
7. Reverse steps
May 25, 2010 | 1999 Ford Explorer
I am looking for a manual for a Tunturi C20 Cross trainer
http://tunturi.crealisten.com/js/admin/kfm/get.php?id=292
May 15, 2010 | Exercise & Fitness
Tunturi elliptical cross trainer error e-2
Most E 2 code means communication problem upper and lower boards you will need to check connector. for further info go to http://accellfitnessna.com or Email a.parker@accellfitness.com they will help you they Tunturi Distributor of North America
Apr 02, 2010 | Exercise & Fitness
1994 gmc rear axle removal how to
-Remove tire and brake drum
-put drain pan under axle housing
-remove rear axle housing cover (10 or 12 bolts)
-turn gear untiil the bolt for cross shaft shows and remov e the bolt
-remove the cross shaft.
-push axle in until you can remove "U" clip from axle and axle will pull out,
Remove seal, you need a pulller to remove axle brg.
Jul 26, 2009 | 1994 GMC Suburban
Lost instructions for Rober Black cross trainer
Hi, I have bought a second hand roger black silver cross trainer and I do not have any instructions, also the bolt that holds the front post together is missing and the tension dial does not seem to work can I adjust the tension in side the front post! Please can you help. Kind Regards Janet
Feb 01, 2009 | Exercise & Fitness
Exercise & Fitness Logo
259 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
