Question about Apple iPod nano
How do you re-install itunes to get the intunes icon to show up on my mac computer?
I have a mac computer so how would i uninstall itunes and then install it again to get the itunes icon?
  • Apple Master
  • 13,433 Answers
Oh, your useing a Mac.
I've used a pc all my life, I dont know, Il find out later.
Posted on Mar 30, 2008
Itunes is changing my desktop icons when i install it
Contact 1-800-204-4427 iTunes technical support phone number is a fast and easy way to resolve all iTunes account related issues, iTunes Support Phone Number 1 800 204 4427 Tech Help
May 18, 2017 | Apple iTunes
Apple Application Support was not found. Apple Application Support is required to run iTunes. Please uninstall iTunes, then install iTunes again. Error...
How did you uninstall itunes? If you run into an error, or your computer while your itunes was installing, it could leave things behind messing up all the other installations as well. What you need to do is first of all make sure you don't have any instances of itunes open, or trying to be opened. Then you can go ahead and run the uninstaller on itunes.
Then you will need to go into explorer (windows+e, or right click on your My Computer icon and press "explore" from the menu), navigate to C:\Program Files\ and delete the itunes folder completely. If you get an error saying something to the effect of "This file/folder is being used by another program, please stop that program and try again." go ahead and restart your computer, and try to delete the folder again when your computer comes back up.
Then try and reinstall it, making sure that you are downloading the correct version of itunes for your operating system.
Dec 27, 2010 | Apple iTunes
My Rio Forge 512 won't show up in my mac itunes. It shows up on my mac desktop, but not in my itunes ver. 9. I reformatted it on a PC and reinstalled firmware 1.33 on a PC. I also have the rio itunes...
This device is not supported by itunes.
all you can do is drag music to it on the desk top icon for your rio
it will never show in itunes
hope this helps.
Feb 17, 2010 | Rio Forge Sport Digital Media Player
My ipod touch wont let me sync songs onto my ipod. im so confused
Uninstall itunes from your computer and re-install the same itunes version you had before. Make sure your ipod is fully charged and then plug it in and have a go at it.
Cheers old chap.
Feb 15, 2010 | Apple iPod touch
After installing , when trying to run itunes , it says apple application support is required to run i tunes, please uninstall and imnstall again , i have done what it says. and still the same error comes...
1. Download and install WinRAR.
2. Right-click the iTunesSetup.exe icon and choose "Open with WinRAR".
3. Once the EXE is opened in WinRAR, double-click AppleApplicationSupport.msi and when the installer window is open choose "Repair".
4. Done! You can now run iTunes normally.
Crat
Oct 25, 2009 | Apple iTunes
My white ipod nano still shows the "do not disconnect" icon when connected to the usb port
can you uninstall itunes from add or remove programs and after that, install it again. You should get a icon into your desktop, if its not there.
try to find it
my computer -> c: -> Program files -> iTunes -> right click iTunes.exe -> send to -> desktop.
You should now have a icon on your desktop.
Mar 25, 2008 | Apple iPod nano
Ipod wont show up on itunes
Okay, I had a similar problem with a 5th Gen 30GB, and I stumbled upon a solution that I have not seen anywhere else.
Basically, my iPod was mounting as a disk drive, but would not show up in iTunes. I reset it many times and ran the diagnostics (left and center upon Apple logo at startup). Nothing worked, and of course I couldn't restore it, because it wouldn't show up in iTunes. It did the same thing regardless of what PC or Mac it was plugged into -- it always mounted, but never showed up in iTunes.
Another odd observation was that it was mounting on my Mac desktop with the "external hard drive" icon, not with an iPod icon.
Here is what I did that fixed it:
1. Plugged it in to a Mac. 2. Opened a Terminal session 3. Browsed to the /Volumes/iPod/iPod_Control/ folder 4. Renamed the iTunes sub-folder to iTunes.backup 5. Ejected the iPod, then re-connected it
At this point, iTunes detected my iPod just fine! I went through the restore procedure as a precaution; because I have no idea what this directory really contains.
I realize that the circumstances surrounding my successful restore are somewhat unique, and probably don't apply to very many other situations, which is why I described some of the quirky things (like the icon showing up as an external hard drive) in detail at the beginning of this. Don't attempt it if you're not comfortable with what I described, or if your iPod has different symptoms!
Dec 24, 2006 | Apple iPod nano
Why does my iPod appears on my computer but not in iTunes?
For Mac users "iPod does not appear in iPod Updater or iTunes in Mac OS X Under some circumstances, iPod appears in the Finder in Mac OS X, but does not appear in the iTunes Source list or does not appear in the iPod Updater. Symptom iPod's disk icon appears in the Finder, but it does not appear in the iTunes Source list or in the iPod Updater. Note: The iPod may appear in iTunes, but not in the iPod Updater. Important: If you are using iPod shuffle, you must have 10.2.8 or 10.3.4 or later to connect it to your Mac over USB. Other iPods require 10.3.4 or later Products affected Mac OS X iPod (5 GB) iPod (10 GB) iPod (touch wheel) iPod (dock connector) iPod mini - USB requires Mac OS X 10.3.4 or later. iPod mini (Second Generation) - USB requires Mac OS X 10.3.4 or later. iPod (Click Wheel) - USB requires Mac OS X 10.3.4 or later. iPod with color display (including iPod photo) iPod nano Solution iPod nano Certain models of single processor Power Macintosh G5 computers may show iPod nano mounted in the Finder but not recognized in iTunes. If this happens to you, try restarting your computer and Setting Energy Saver to highest performance and turn off hard disk sleep. If you have an iPod nano, but don't have a G5, then follow the other steps below. Mac OS X 10.4.x Perform an archive installation of Mac OS X10.4. Mac OS X 10.3.x Navigate to /System/Library/Extensions. Drag the iPodDriver.kext file to the Trash (you will be required to enter an administrator account password). Download and install the Mac OS X Combined Update 10.3.9. Restart the computer when prompted to do so by the installer. Connect the iPod. Mac OS X 10.2.8 and earlier To resolve this issue with earlier versions of Mac OS X, you'll need to delete one file and reinstall iTunes. Follow each of the steps below. Step 1 Delete the file using Terminal Warning: The steps below describe how to remove a file by entering commands in the Terminal application (located in the Utilities folder inside of the Applications folder). Users unfamiliar with Terminal and UNIX-like environments should proceed with caution. The entry of incorrect commands may result in data loss or unusable system software. Open Terminal (/Applications/Utilities). Type: sudo rm -R /System/Library/Extensions/iPodDriver.kext Press Return. Enter the administrator account password when prompted. Quit Terminal. Restart the computer (From the Apple menu, choose Restart). Step 2 Reinstall iTunes Download the latest version of iTunes from the iTunes download page. Install iTunes. Restart the computer after the installation has completed. Connect iPod. Step 3 Delete the iPod.plist file Remove the following file in the your home directory and launch the iPod updater again ~/Library/Preferences/com.apple.ipod.plist "
Sep 28, 2005 | Apple iPod nano
Why my iPod doesn?t appear in iTunes?
Apple iPod nano Logo
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
