Question about Frigidaire GLTF1670A Front Load Washer
Hello, I have a frigidaire washer. I loaded it up and started it - the water went in. But after that, it just stopped. I tried it again, tried different cycles, still doesn,t work. The Start light is flashing. Door is locked. The wash light is on. Do you know what could be the problem and how we could resolve it ? Thanks
    Problem Solver:
  • 5 Answers
Well I'm not an expert but I have had problems in the past but it was with my top loader washer. Sounds like it could be a number of things: could be the transmission, or could be a switch or an electrical problem (thats the problem with these new digital washers/dryers!). You will definitely have to call a technician unless you can get a manual and try to fix it yourself. Mine is a year old and I purchased some extra insurance for it, like a year or 2 worth when I bought my washer & dryer new. If your washer is less than a year old you can probably get the manufacturer to fix it for free! Good luck!
Posted on May 15, 2010
The machine starts putting water and stops
Hello paula vaz, thank you for your post!
I understand that your Frigidaire washer will not start. It sounds like a possible problem with the pressure switch, water valve, or control panel. If the water valve is bad it will not feed water into your washer. If the pressure switch or control board is faulty that will cause the washer to not start.
Let's attempt a reset on your washer by disconnecting power from it for ten minutes. If you continue to experience issues with your washer after restoring power to it I would recommend consulting with a professional technician for a diagnosis to be completed. I hope this helps. -Matt
Nov 11, 2014 | Frigidaire Affinity Series FAFW3801L 27"...
My Frigidaire Affinity is brand new. Just did our first load of laundry and mid cycle it stopped and the PAU is lighting up intermittent with the time left. I have tried everything I can think of and it...
Hello Mary Fortner - It means that the washer has been paused; the cycle has been interrupted. Either the "Pause/Cancel" button or "Start/Pause" button has been pressed. To resume wash - press "Pause/Cancel" or "Start/Pause" once. If this does not prove to be successful please turn the breaker to the unit off for 5 minutes. Then turn the breaker back on to the unit, and retry the cycle setting again.
Dec 11, 2012 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire Affinity Washer making clicking sounds after power outage.
Sounds like either the control board or the timer is faulty at this point. Contact a professional so they can diagnose the unit fully and repair where needed.
Jul 28, 2012 | Frigidaire Affinity ATF7000E Front Load...
My frigidaire front load washer will start a wash, complete the first cycle but then stop and flash all the lights and beep continously until I press "start" or "cancel". If I press "start" again it just...
Hello there:
If your cycle does not complete or The cycle doesn't advance
When the cycle should advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. than check the cold water supply line and the filter
Aug 15, 2010 | Frigidaire ATF6000ES Front Load Washer
Frigidaire (LTF2940E) Washer starts, stops, starts, stops...
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
May 07, 2009 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire front loading washer stopped at rinse cycle. 3 beeps
When in doubt check the easiest thing to check. The pump can cause a number of errors to come up. Since the unit stopped in rinse I would start but checking to make sure there is nothing obstructing the pump before going to the expensive parts.
Feb 22, 2009 | Frigidaire ATF6000ES Front Load Washer
Washer fills up than starts draining while in wash cycle
Hello , here is the fix-your drain hose is placed to low in the drain line in the wall, it can not be placed in water or it will siphon the water out of your washer into the drain pipe and it wont stop until it hits air. try pulling your drain hose up and out of the drain and get a zip tie or cable and tie it to one of the water valves by the drain pipe placing the end of the drain hose about 5-6 inches inside the drain pipe. Let me know if you have any other questions and good luck it will work.
Phil
Jan 28, 2009 | Frigidaire FLEB8200DS Top Load Stacked...
Frigidaire GLTF1670A Front Load Washer Logo
109 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
