Question about Lexmark All-in-One Printer with PictBridge
Lexmark 3500 paper feeding oblique and stops shortly
  • stumpfwe May 15, 2010
    Hi! You may need to reset the printer, please try this. Unplug the printer from power source and press hold the power button for 10secs. while unplugged. Plug the printer again to power source and turn it on, this would reset the printer's system and can get your machine back to working. Hope this helps and have a good one!
    This maneuver twice did not work!
    paper feeds about 2inches than one side goes ahead and it immediately stops
    President:
  • 4,070 Answers
Posted on May 15, 2010
  • 4,924 Answers
The paper not feeding in the strait way ..is just a matter from the rolers that drive it ..so ..you have to open the printer and check the rollers..not to be blocked..or out of track ..or some springs that have for tension not to be out of place ...the issue is difference in traction of one side from the other ..and automatically drive the paper in diagonal and jam it ..Also clean them well so it do not have any paper left from other jams.. and try to see one by one if they move well...also If in a side the rollers seam not equal positioned it is an issue ...and see if it has guidance screws to make distances even ..it may be one damaged and that's why it drive it in a side....In final there is nothing else that can be wrong but either the rollers..or the top that press the paper down ..may be not leveled and it retain paper in one side..and that's what cause it to follow a diagonal way ...and of course..the slightest deviance cause the block...
when you remove the paper always keep the start button pressed for to reset the job and get it out..
It may be nothing wrong ..but just open it ,and chack them and put it back with care ..and be gentle but ferm when you click or place anything in place ...and reset it after you put it back ..just to hear it working without dragging paper....this will align it like it should ...
For most printers the reset its made by power off..and power it up again and keep the button pressed for 10 seconds ..you should hear it working from side to side ,,and rolling ....
It wont feed the paper it keeps say paper jam but the paper is not even going in
Lexmark Impact S301 Printer won't take the paper -
printersquestions.com/lexmark-impact-s301-printer-wont-take-the-paper....
Dec 19, 2013 - Feeding paper is the first step of printing materials. However, what will you do when the Lexmark Impact S301 Printer won't take the paper ...
Paper Jam Troubleshooting on 2009 Printers - Lexmark
support.lexmark.com/index?pmv=print&page...en...
LexmarkLexmark Impact S301, Lexmark Impact S302, Lexmark Impact S305 ... When troubleshooting paper jams on Lemark's 2009 printer models, make sure you also ...
[PDF]Solving paper feed problems - Lexmark
www.lexmark.com/publications/pdfs/w820/eng/prfedprb.pdf
LexmarkUse the following table to find solutions to paper feed problems you are ... For detailed instructions on clearing paper jams, see Clearing print media jams.Missing: impact ‎s301
How To: Clear a Paper Jam on a Top Feeding Lexmark ...
? 2:30
https://www.youtube.com/watch?v=H1-J1xDbDsY
Jan 14, 2016 | Lexmark Impact S301 Wireless All-in-one...
Lexmark e232 The automatic feed has stopped operating and I get a "paper default" light button. I can't findf a paper jam. The system refuses to pick up the sheet and feed. Where else...
Just power down the printer. This should resolve the issue.
If you need further assistance, please contact Lexmark Technical Support Center.
Jun 13, 2011 | Lexmark E232 Laser Printer
I have a lexmark e2e2 printer that starts to feed the paper then stops, I have checked the feedrollers, they pick up the paper and start to advance it, I have replace the fron paper sensor and still will...
You may not have to replace the rollers. I had that same problem and all I did was turn the rubbers on the rollers inside out. The problem is that the rubbers have become too smooth to grab the papers.
Jan 18, 2010 | Lexmark E232 Laser Printer
Lexmark 3500-4500 Series error message paper jam
I suggest you list your problem under lexmark printers.
DickyO
Sep 08, 2009 | Lexmark Wheelwriter 3500 Typewriter
My Lexmark X73 made a snapping noise and stopped
My printer did the same thing, after tearing into it, I found one of the plastic gears had broke in two.
Aug 08, 2009 | Lexmark X73 All-In-One InkJet Printer
LEXMARK 3500 4500
  1. Turn the printer off and open the access cover.
  2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
  3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
  4. Watch the paper as it feeds through and try to determine where the jam is occurring.
  5. Check to see if all the rollers are turning.
    If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
    If not, there is probably a feed motor or a gear problem and the printer may require service.
  6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
  7. Turn the printer off.
  8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
  9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Jun 10, 2008 | Lexmark All-in-One Printer with PictBridge
Lexmark Z11 Printer will not work
i am having the same problem and after looking it over, something is not feeding it thru the beginning of the paper starting in. if i pust 1 sheet down far enough to grab the paper it will print one page at a time. I have been unable to determine what is not feeding at the beginning yet.
Oct 03, 2006 | Lexmark JetPrinter Z11 InkJet Color...
Lexmark All-in-One Printer with PictBridge Logo
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
