Question about Kenmore 72212 / 72214 / 72219 Bottom Freezer Refrigerator
How do I replace the freezer racks? - Kenmore 72212 / 72214 / 72219 Bottom Freezer Refrigerator
  • Kenmore Master
  • 17,970 Answers
I suggest check this repair guide for Kenmore Botton Frezeer, hope this help to solve it.
Good luck.
Posted on May 15, 2010
How do I defrost bottom freezer on my Kenmore French door bottom freezer
Take the bottom door off take racks out as well as the tracks of racks then use the flat head screw driver to take out fan cover then un screw back panel and take it off then you can defrost it. Won't be easy
Oct 19, 2014 | Kenmore 77552 Bottom Freezer French Door...
New Frig..just l yr old. Water droplets on floor below bottom pull out freezer compartment. Discovered a layer of ice built up inside below the racks. Can't find anything in the manual to indicate...
Your drain is plugged. When in defrost mode the heater comes on in freezer and melts the frost on coils. Sometimes the frost falls off in a chunk and covers the drain. The heater can only be on for so long until the bi-metal/ defrost thermostat shuts it down. Once the defrost cycle ends the frost turns to ice and builds from there. Your heater is melting the frost and the water has no place to go so it goes under the racks.
To fix remove contents off freezer and remove racks. Remove the back panel 4 screws and you will see your drain plug under the coils. Remove any ice you can see blocking the plug. Now pour hot water into drain until it flows into drip pan under freezer. You can remove back access panel behind fridge at bottom. Once water flows freely though than replace the access panels.
If you leave fridge plugged in while doing this be careful.
Aug 01, 2011 | Maytag Refrigerators
One freezing rack not working! I hav efridge-freezer Bosh Classic Maxx and the top freezing rack does not working ? Everything else is o.k. but not that top rack.So can you help me ,please???? Thank you...
i dont really know this model, how many racks are in the top unit ?
if more than one rack , then i would say it sounds like incorrect coolant level in the freezer system , might have a small leak, and it would need the coolant level increasing .
Dec 18, 2009 | Refrigerators
How does the rack come out of the freezer to adjust
there should be a plastic clip between the rack and left side of the freezer remove the clip then push the rack to the left real hard then the right side should come out raise the right side up and remove rack
Jul 12, 2009 | Frigidaire FRT15B3A Top Freezer...
Ice is building up on the back wall of my freezer
the freezer heater needs replacing, it's inside the freezer after removing all the racks remove the back panel, the heater is on the lower part of the condenser it's about $50.00.
Dec 09, 2008 | GE Refrigerators
Refrigerator side is not cold therfore it seems to be pulling from the freezer because it wont freeze
the freezer heater needs replacing, it goes bad often, it's inside the freezer after you remove the racks remove the back panel the heater is located at the bottom of the condenser. it's about $50.00.
Dec 08, 2008 | GE Profile PSW26P Stainless Steel Side by...
Freezer not cooling
remove back panel inside freezer and see if pipework is frozen up and also check fan is working. if pipework frozen up, indicates a fault with the defrost system
Sep 14, 2008 | Frigidaire 16.7 cu. ft. / 473 liter...
Racks in the freezer are too narrow
try removing the rails form one side and installing plastic spacers, you should only need one or 2 to compensate,
Apr 23, 2008 | GE GSS20IEP Side by Side Refrigerator
Kenmore 72212 / 72214 / 72219 Bottom Freezer Refrigerator Logo
20 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
