MY AMD 965 TEMP 55 IN NORMAL AND MY VGA CARD TEMP 60 IN NORMAL WHAT I HAVE TO DO ???
  • 13,433 Answers
Hello
what is the problem? High temperatures are caused by dried out thermal paste between the cpu and the heatsink. Or poor or too small heatsink.
You will void the warranty of the video card if you change its heatsink, make sure the computer case has good air flow instead.
You can freely change the heatsink on the CPU, I have AMD 9650 (same, quad core) My temperature is around 30, because I have a huge heatsink and fan on top of it.
Posted on May 15, 2010
Upgraded cpu and fan om HP p6320y desktop won't stay powered up
The AMD Phenom II X4 850 (HDX850WFK42GM) uses up to 95 Watts of power,
http://www.cpu-world.com/CPUs/K10/AMD-Phenom%20II%20X4%20850.html
(Electrical/Thermal parameters)
While the AMD Phenom II X4 965 uses up to 125 Watts, or 140 Watts; depending on which Part Number....
HDZ965FBK4DGI uses up to 140 Watts.
HDZ965FBK4DGM uses up to 125 Watts.
http://en.wikipedia.org/wiki/List_of_AMD_Phenom_microprocessors#.22Deneb.22_.28C2.2FC3.2C_45_nm.2C_Quad-core.29
Scroll down a little.
I'm going with Not enough power from the Power Supply.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01969880&tmp_task=prodinfoCategory&cc=us&dlc=en&lc=en&product=4120661
Power Supply is ONLY 300 Watts?
Yes, the Power Supply is too small IMHO.
Is there also a graphics card you have installed, and not stated?
Regards,
joecoolvette
May 14, 2013 | Computers & Internet
I installed the Gigabyte 870A-UD3 Motherboard and AMD Phenom II X4 965 Black Edition Quad Core CPU in a computer for my Grandson. It seems to be working with one exception. The processor is idling at 800...
Personally I don't like sites that try to install drivers for you. sometimes they do all right but , sometimes they may install generic updates that don't work or make matters worse. A prime example, is if you try to update a driver for a graphics card. Your best bet for driver updates is to get them from the manufacturer of the software.
http://www.gigabyte.us/support-downloads/download-center.aspx
This is Gigabytes link for downloads. There are a couple of different options depending on your revision.
You also have AMD chipsets and, I'm guessing, an ATI/AMD graphics card. I'm not familiar with "darksider so if you can give me the model number of your card I can help you further or, if you know how to enter info definately get your card updtaes through here:
http://support.amd.com/us/Pages/AMDSupportHub.aspx
If you have problems or questions, let me know at "add a comment"
Dave
Apr 02, 2011 | Gigabyte 870A-UD3 Motherboard and AMD...
Upgraded power supply, upgraded to AMD 965 Quad core, Mother board stops at error C5, monitor blank during this. C5 error says reset video controller. HOW?
try this: 1. turn off the computer 2. disconnect the VGA connector (the cable from the monitor) 3. remove the video card from the motherboard 4. the motherboard has the on board video controller, connect your VGA monitor to that slot. 5. turn on the computer, I hope by now your monitor is ok ;-)
Feb 03, 2011 | Jetway Computers & Internet
Lost monitor,cable and monitor work on other pc.
is this motherboard have normal sound at first boot?if yes, i think you must place PCI vga card, it may caused by your vga on board is damage
Jan 19, 2011 | ASUS This motherboard supports AMD AM3...
Im having no signal to the monitor and a vga error on the mother board try everything
It means there is problem in your VGA Card. VGA Card is Built in OR Insert in PCI Slot or AGP Slot Just change your Card
Problem will be solve . VGA Card Drivers
Mar 12, 2010 | Biostar TA790GXE AM3/AM2+/AM2 AMD 790GX...
Ok So i have a Biostar TA785GE 128M with a Phenom II X4 965 Processor. So ive plugged everything in and the problem is that when i plug the monitor cable thing into my video card, the monitor doesnt have a...
if your mobo has built in video output, connect your monitor to that 1st. if your able to get to the bios, change the primary vga port to PCI-e,save and exit. then reconnect your monitor to your video card..
Hope it helps!
Feb 14, 2010 | Biostar TA785GE 128M AM2+/AM3 AMD 785G...
Motherboard A8V-E SE core Temperature at 58C is that normal?
Hi
AMD's CPU temperature's range from 10-85 degrees, the normal is around 48-60 degrees. So your within the normal. Sometimes depending on what your doing, the chip will run up to 70 or so, that's also normal, but you want to make sure that it doesn't stay at 70 for long. It will shorten the life of the CPU.
Thanks for asking on FixYa
Mark
Jan 31, 2010 | ASUS A8V-E SE Motherboard
AMD temp
AMD Athlon 90C - 95C AMD Athlon64 65C - 70C AMD Athlon64 Mobile 95C - 100C AMD Athlon MP 90C - 95C AMD Athlon XP 85C - 90C AMD Duron 85C - 95C AMD Opteron 65C - 71C AMD Sempron 90C - 95C AMD K5 60C - 70C AMD K6 65C - 70C AMD K6 Mobile 80C - 85C AMD K7 Thunderbird 70C - 95C
Apr 21, 2009 | Computers & Internet
VGA driver...
Is it a Jetway M26GT3-SVP motherboard? if you are using the onboard video (video from motherboard) here is the link to the driver
http://216.185.128.200/temp/jetway0c/downloads/driver/mcp61_2kxp.rar
if you are using a Video card? what is its model ATI or Nvidia?
Feb 01, 2009 | AMD Athlon 64 X2 3800+ Dual Core Processor...
Computers & Internet Logo
David Payne
David Payne
