Question about Tecnik 18 in. TKD7000 Built-in Dishwasher
HAVE BEEN ADVISED THAT THESE ARE MADE BY NEFF IS THIS CORRECT PLEASE
    Brigadier General:
  • 3,006 Answers
Yes, sort of. Bosch, Neff, Tecnik and Siemens are the same group, with the same design and engineering teams behind them.
Many spare parts are common to each but they're not necessarily made on the same production lines, although in the case of Neff and Tecnik it seems that many models are as they're often identical except for badging and price.
Please take a moment to rate my answer.
Posted on May 15, 2010
When our Neff dishwasher has completed a cycle most of the tablet is still in the open dispenser. Can you advise ?
Check and clean both spray arms.
make sure nothing is restricting the movements of the arms. Have you selected the correct programme? Quick wash may not always dissolve tablets, you may need to put the tablet straight into cutlery basket at start of quick wash programme
Sep 23, 2014 | Neff Dishwashers
Customer complaint
Most manuals advise you to use a soft cloth.
Paper towels scratch.
Maybe that's it...
Dec 22, 2013 | Neff Microwave Ovens
My neff is not giving any water, I have changed new filter still light shows fix filter?
If the indicator is a light or series of lights, the light will change from green to yellow. This tells you this it is almost time to change your filter. It is recommended that you replace the filter when the status light changes to red, or when water flow to your water dispenser or ice maker noticeably decreases.
Hence, it's advised to check your water flow (pressure) is perfect. If your water flow is normal the indicator display will automatically be gone and also you will get water also. Please also check any tints orkinks in water hose, if it's correct it. Thanks, Helpful?
Feb 12, 2011 | Neff K3965XO Side by Side Refrigerator
How can I remove the fascia panel from my Neff double oven? I have a Neff U1552 oven. The display-film strip showing the temperature for the fan oven broke. I have bought a replacement part from Neff and...
did you manage to fix your strip, i have the same problem, all4 strips have broken in the last 6 months on my U1552. how much was the replacement?
Jan 02, 2011 | Neff Ovens
Please advise how to reset the time clock on a
Hold down 2 buttons - the first button on lhs "timer bell" the "hand" button and then use plus and minus with the other hand to set the time.
Jan 07, 2010 | Neff U1721 Double circotherm Electric Oven
I have a neff oven, cannot remove glass cover to change bulb. Was advised to buy strap wrench, no good. Advised to heat oven, no good. Cover moves about quarter inch, when heated , nothing. can you please...
Having tried several ways to get the glass cover off, there is one other thing you can try.
Spray some WD40 around the glass cover,and keep trying to tighten and then unscrewng it, and tighten again.
If this does not work, then the last resort is to break the glass cover, which is what I have had to do in the past,. but make sure you can get a replacement cover first.
Please rate my solution.
Thanks.
Nov 24, 2009 | Neff U1721 Double circotherm Electric Oven
Unable to release fan on Neff B1441 single oven
It is probably baked on grease that is holding the fan on, if you have removed the center nut, then it should pull straight off.
Try spraying WD40 on it, grasping it with a pair of pliers or similar, and pull it towards you. it should come off, there is nothing else to hold it on.
Please rate my fixya solution.
Thanks.
Feb 13, 2009 | Neff U1721 Double circotherm Electric Oven
Neff U1421 double oven fan has packed up ?
Yes it is the fan that needs replacing.
It is a fairly straight forward repair, just remember that the nut that holds the fan blade on is a left hand thread, so to undo it, turn
it clockwise, as though you were you were tightening it.
Please leave a fixya rating for my solution.
Thankyou.
Feb 03, 2009 | Neff U1421 Double circotherm Electric Oven
Replacing hinges on NEFF built in fridge
1.REMOVE TOP HINGE
2.LIFT DOOR UP AND REMOVE
3.REMOVE MIDDLE POST SUPPORT
4.LIFT UP AND REMOVE LOWER DOOR
5.............YOU GOT IT FROM HERE.
PLEASE RATE THIS . THANK YOU!
Jun 06, 2008 | Refrigerators
Tecnik 18 in. TKD7000 Built-in Dishwasher Logo
377 people viewed this question
Top Tecnik Dishwashers Experts
Renee Knafel-Bullock
 Mikey
Mikey
Are you a Tecnik Dishwasher Expert? Answer questions, earn points and help others
