Ga-k8ns pro motherboard/ pc self build
HI ALL. CAN ANYONE HELP SOLVE A NO BIOS PROBLEM? I JUST PUT TOGETHER A PC USING THE INSTALL GUIDE. EVERYTHING SEEMS TO RUN BUT GOT NO BIOS OR BEEPS.NOTHING ON SCREEN. TRIED THE RAM. TAKING OUT A STICK,REPLACE. ADDED SPEAKER. NO BEEPS. DIFFERENT GIGABYTE BOARDS. GOT THE SAME. ANY IDEAS PLEASE. NEW TO THIS ,BEAR WITH ME. THANKS AGAIN PAUL
  • paul Apr 02, 2008
    HI FRIEND. THANKS FOR YOUR HELP. I TOOK EVERYTHING BACK OUT AND STARTED AGAIN. FOUND TO BE THE CPU. PUT THE BOARD TO ONE SIDE FOR A WHILE AND BUILT A 663AS PRO 1.2. PUT A XP AMD (THINK THATS D NAME) 1 GIG RAM, VOODOO 3DFX CARD AND SEEMS TO RUN WELL. NOT BAD FOR FREECYCLE COMPONENTS. (cost £0). I GOTTA GET A 64 CPU FOR A GA K8VT800 PRO BOARD. LIKE I SAY IM NEW TO THIS BUT BIN BITTEN BY THE BUG.L.O.L. HAVE A NICE DAY. PAUL
Puhdi k driver kahan chupa k rakah hai
Posted on Aug 06, 2008
Hey me too. Just bought a sata drive. I have the same mobo (AK86-L), and now the same problem. Updated the bios and SATA is enabled. Updated the driver. Tried both sata 1 and sata 2 connections on the mobo. It will not recognize the drive although it picks up that something is connected to the mobo. Its a WD Caviar 500 GB drive. Anyone have any thoughts?
Posted on Mar 31, 2008
  • Reddin
    Reddin Apr 02, 2008
    Hi Paul,
    First I don't know why the comment I made on another thread is here, but I'll try and speak to your problem in this post.
    I put together a couple of computers a while ago and everytime there was a no beep situation and nothing on the monitor, it was the RAM. One time bad ram, the other time - it just wasn't connected to the board well enough. Of course there could be other problems, but I would verify that its not the ram first. Maybe double check the type of ram you are to use with the board. Also maybe try the ram on another computer if you can to make sure it actually works. Once you verify its not the ram, then you can move on to the next set of possibilities...
GA-K8NS losing Cmos - not the battery
Hi, you can download drivers and software here:
http://www.gigabyte.com/products/product-page.aspx?pid=1783#driver
Try to change the cmos battery.
When the battery run out of power the bios can`t
remember its settings.
Thats probably why you have a cmos error.
The battery is a 2032 watch type.
You can try to remove the battery and measure the voltage
with a voltmeter.
Its should be around 3 volts.
Consider to upgrade the bios when you get it up and running.
You have to make sure its the right mainboard when you flashing
the bios or the mainboard will be destroyed.
Sep 07, 2011 | Gigabyte GA-K8NS Motherboard
I want to install an Ati Radeon Pro 9800 vga card in my Asus Terminator P4 533a, but the card is not recognized. I tried to change the vga bios to agp and pci, no effect. I even disabled onboard vga, then...
Hi,Try to clean your video card by using an eraser,then plug it again,If the problem still exist,try to use other video card,but still not working the problem would be your motherboard.thanks
Sep 02, 2011 | ASUS Terminator P4 PC Desktop
Im getting 3 long beeps when i turn my pc on
copy bios if built in vga if external vga check vga
Nov 01, 2010 | Gigabyte GA-K8NS Motherboard
My system is this type:Gigabyte GA-8I845GVM-RZ Motherboard I am install win xp load and other software pc is ok after install software install vga driver and pc restart countinuebut without vga...
One possible cause of this problem is that you have not installed the correct driver for your graphics adapter. Use the Main board utility driver pack together with your motherboard, use the auto run setup to make sure you have installed the right driver.
Let me know for any clarification.
Jun 22, 2010 | Gigabyte GA-8I845GVM-RZ Motherboard
Ga-6vxd7 keyboard wont work to boot from cd
Plug the USB keyboard into another port (preferably one at the back) restart the PC and enter the BIOS again, this time go through the BIOS and set all the USB controllers to enabled, hit F10 save the changes and exit the bios. The computer will restart and you should now be able to use the USB keyboard to install the OS.
Please post back if you need anymore advice.
Good luck
Jun 15, 2009 | Gigabyte GA-6VXD7 Motherboard
Ga-k8ns memory problems
did you go into bios and check set up of ram speed etc
Jul 14, 2008 | Gigabyte GA-K8NS Motherboard
Installing 2 sticks of 1 gb ram = DRAM error beeps
If the computer is working with one gb stick and not the other, try this:
Swap the sticks with the one that does work. If it works then its the memory card slot on the motherboard. If it doesn't boot up, then it's the memory stick.
Jun 13, 2008 | Gigabyte GA-K8NS Motherboard
Boot only Frm Cd boot sequience has been set
Take out the cd from the drive. If it still trys to boot from it change the boot sequence in the bios.
Feb 19, 2008 | Gigabyte GA-K8NS Pro Motherboard
Computers & Internet Logo
546 people viewed this question
David Payne
David Payne
