I HAVE A MAYTAG NEPTUNE WASHER, MODEL NO. MAH4000AWW. WASHER WILL NOT SPIN OUT. WATER STAYS IN TUB. I DON'T KNOW WHICH PART NEEDS TO BE REPAIRED, COULD IT HAVE ANYTHING TO DO WITH THE CONTROL BOARD?
  • Anonymous Dec 07, 2008
    my maytag just wont spin, I wonder if it has to do with the door lock, the door lock light does not come on so I wonder if it has to do with the control panel.
  • drty laundry Dec 19, 2008
    I have the same problem with my Maytag washer. It goes through all the cycles and once the load has completed I open the door to soaking wet clothes. Although it cycles through the spin cycle it doesn't accomplish it.
It is the drain pump and motor assembly that does not remove the water from the tub. Althought it spins, water is not sucked out of the tub. Try replacing the drain pump and motor assembly. Part no. 22003059.
I did and my washer works well now.
Bill P
Herndon, VA
Posted on Dec 24, 2008
I have a may tag Neptune washer model # mah4000aww. When I spin the tub it sounds like there is still water in the washer. Clothes are coming out very wet. Rubber drain is off and little water cameout
When a washing machine drum is removed from the tub after it has been in service for a while a number of objects are often discovered - bra wires, buttons, underwear, coins...
It is possible one or more such items is partially blocking the drain inside the tub.
Sep 04, 2016 | Neptune Washing Machines
Mah4000aww no door locked light
The lid/door safety switch needs replaced
Mar 08, 2010 | Washing Machines
Maytag Neptune Front Load Washer Model MAH4000AWW low last spin
two problems here,
your shaft seal is running on its last leg
the sound is unmistakeable and always described the same...
the water issue, you probably have a trickle leak through the cold water valve
the mixing valve is quite an easy repair, but I would have to say with all honesty, it probably time for a new machine
the hub seal is a tub replacment call
2 hrs of labor if hes good
and the tub runs around 500.00 dollars
sory for the bad news
Oct 10, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune model number mah4000aww
its your pump.get at it thru the back.it may be blocked or may have failed.a volt meter will tell you if its getting voltage.if so should drain,make sure on about spin setting to check.ive had to replace the pump on my neptune
Dec 29, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag mah4000aww trys to spin shakes and stops
there are off balance switchs on the tub that will turn it off But if the pump sump is full it will pump slow and throw it off balance so check to see how well and fast it is pumping the water out
Nov 30, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag washer shutting off on rinse cycle
If the washer is not completing the Rinse cycle there may be problem with:
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
Let me know if you need further assistance.
Regards
Ellin
Sep 26, 2008 | Maytag Neptune MAH5500B Front Load Washer
Neptune washer
Why?Do you understand that the bearings are locked into the outer tub and you have to replace that,the outer tub.Very expensive repair that will most likely be almost half the price you had paid for the machine new.My advise is DONT FIX this if you have a bearing problem ,because I honestly believe in letting the customer know the truth.Sorry, but a 15 year old re- conditioned Maytag will out last any Neptune ever made.
Apr 30, 2008 | Maytag Neptune MAH5500B Front Load Washer
Leaking water Maytag Nepture washer MAH400AWW
open door and feel around the rubber bellow possible tear causing leak
Feb 27, 2008 | Maytag MAH6500 Neptune Front Loading...
Maytag Neptune MAH4000AWW
I SAY REPLACE TIMER (POWER CONTROL BOARD)
Jan 15, 2008 | Maytag MAH6500 Neptune Front Loading...
Washing Machines Logo
309 people viewed this question
Top Washing Machines Experts
