Question about Dryers
Kenmore Dryer Model 110-63942101 My daughter's dryer takes multiple cyles to dry clothes when 1 cycle should have done it. The exhaust vent is clear to the outside of the house and I'm getting good warm air flow at the outside of the house when the dryer is on. My daughter has had a repairperson out who said this is a known manufacturer defect and there is nothing that can be done. Sears says they no nothing about a known defect. I saw the same problem posted on FixYa and the response was to replace the timer assembly, but did not explain how the timer assembly could cause the problem. A new timer assembly, with shipping and handling, is over $90. Before I invest in a new timer assembly, how can I be sure the timer assembly is the problem? I'm not sure this test is relevant, but I set the dryer for 20 minutes and it ran for 25.
  • stuusa May 21, 2010
    I think Rylee's first thought was correct: inadequate air flow due to blockage in the exhaust hose. It's not enough that air is flowing outside the house, it must be sufficient air flow to keep the heating element cool.
    If the clothes at the end of cycle are still damp but hot, ventilation is probably the culprit and the exhaust hose from the back of the dryer to the outside of the house is partially or completely blocked.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance. But as per the description you have provided the vent is clear then please check that the heating element might be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes than normal. Please check that the element is not partially burned out. If still the issue is not resolved, then the motor is not running at the desired speed and that’s why it takes more time to dry than normal and also check that it may not be spinning in opposite direction (which occurs due to ground short with main). And also check for the blower motor. If all the above is not the issue then it might be the timer because the dryer is taking more time than the selected and required to be replaced to resolve the issue. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on May 15, 2010
    Rylee, Thanks for the quick response! Actually, I'm back to square 1--ventilation. I had a local repairperson come and look at the dryer. What he found was that although there was exhaust outside the house, the heating element was glowing red, indicating inadequate air flow.
    What he did was remove the exhaust hose and run the dryer with some wet clothes. The heating element glowed orange, but never red, and the exhaust coming directly from the dryer was very hot. His diagnosis was that, although I had tried to clean the vent hose and did get better air flow, the air flow was still not sufficient and some blockage remains in the hose.
    For now, I put a pair of pantyhose on the dryer exhaust to catch lint but let air flow freely. My daughter will let me know if that solves the problem. I've got a feeling that's all there was to it and I'll just need to snake the entire length of the exhaust hose (I had vacuumed 15 feet in from the outside).
    It's interesting that, according to my daughter, the repairpersons (from the warranty program) never disconnected the exhaust hose--they just felt the air coming through the outside vent and said it was adequate.
Kenmore 110.66902690 electric dryer does not dry completely
Dear Barry,
Try 2 things.
One, be certain the clothes are very dry coming out of the washing machine.
If the washer leaves the clothes wet ( like the belt might be slipping), it can take the dryer forever to finish drying the clothes.
You can tell by hand-wringing them.
You should not be able to get any water out of them by hand-wringing after they have spun dry in the washer.
Two, try running a load with the vent hose unhooked off the back of the dryer.
If this fixes the problem, you are having a "clogged vent" issue somehow.
Be blessed.
Apr 16, 2013 | Dryers
I have a kenmore/whirlpool electric dryer that is not getting the clothes dry,it takes 2 1/2 runs to get them dry! the model# is LEC6848AQ1
Remove the exhaust vent on the rear of the dryer and run a load.
If it dries in 1 hour or less,repair the vent or the restriction in the vent.
Jan 25, 2011 | Kenmore Dryers
I have a GE model # DCVH680EJOMS front end loading Dryer and it seems to take multiple cycles to get my clothes dry. I discovered that Water is collecting in the flexible exhaust tubing...not just a...
Hi and Welcome to FixYa. I am Kelly
You already have discovered the problem. Lint has built up in the vent / exhaust ducting. Most of the time the through the wall vent flapper gets lint build up on it outside the house and then as that restricts airflow you get condensation in the ducting. The condensation causes the lint to form a cake like paste inside the ducting. THOROUGHLY Clean out your vent ducting from the dryer connection all the way thru the outside wall and your dryer will be fine. If you need to replace the ducting please do so. Ducting is cheaper than the electricity you waste on clogged ducting. You proved your dryer will work correctly when you dried a load of clothes with the ducting removed.
Thanks for choosing FixYa
Kelly
Sep 27, 2010 | GE DCVH515EF Electric Dryer
My kenmore 400 dryer takes for ever to dry clothes, does it need a new heating element?
Have you ever cleaned it out? If not, that is the most common problem with dryers. It can't breathe and takes multiple cycles to dry the clothes. Unplug the dryer and pull it out. Disconnect the vent from the back of the dryer. Clean out lint from dryer and vent. Take the vent outside if you have to and blow it out with air compressor, if you can. Now check the other end of the vent outside at the vent cap. Clean it out and make sure the vent cap flap is not stuck closed. After reassembling vent, turn on dryer and check for heat at outside vent. You also may need to clean it out more if lint has traveled down the vent. Also, clean out your lint filter religiously for more efficient drying. Those are the easy things to look for and fix on your own. If it still does not improve drying, you made need a repairman to trouble shoot it. Good luck!
May 15, 2010 | Kenmore 400 6942 Dryer
Hello I have a Kenmore clothes dryer (80 series). It takes multiple cycles to dry the clothes.
Remove the connecting vent on the rear and run a timed load 45 minutes. If it dries correctly repair the vent blockage.
Oct 26, 2009 | Kenmore Dryers
Gas dryer heats fine but shuts down before the drying cycle is over taking longer to dry clothes. Lint trap and exhaust tube cleaned out.
You are going to most likely need a vent cleaning. The dryer is getting too hot and shutting off because it is not exhausting good.
Apr 29, 2009 | Kenmore 94702 Front Load Stacked Washer /...
Maytag performa intellidry dryer model#PYE4500AYW
Check drive belts. If too loose or too worn it will not spin at proper speed.
Mar 27, 2009 | Dryers
Maytag dryer model LDE8410acw
Hi james,
How old is the dryer?
Sounds like a bad element!
Age determines if it's worth the investment !
Sep 18, 2008 | Maytag MDG9606 Dryer
LG Stacking Dryer
To make sure it is a vent problem ,Do one load without the vent hose attaching to the wall ,keep in mind that it may blow out some dust, you may want to cover the end of vent hose with a nylon stocking for just this ONE time.Now run this 1 cycle on a timed dry cycle at the highest mark...60, 70,etc.If the clothes are dry at the final stopping point than you know your vent is blocked.Or you pinched the vent hose closed.It only takes a small blockage to create alot of waiting time for dryer to end its cycle.The faster the air can get out of the dryer the faster it dries.
May 21, 2008 | Dryers
Dryers Logo
54 people viewed this question
Top Dryers Experts
