Question about Garden
My tecumseh push mower will start good but wont stay running..could it be old or bad gas
    President:
  • 957 Answers
It can be a couple of things. Definitely it could be bad gas. It also could be a defective spark-plug, debris inside the carb., clogged air-filter, a nest underneath the cover that covers the fly-wheel, rust on the magnet ( that needs to be lightly sanded off) reducing the created pulse to the coil, If you have done the following inspections and the symptoms stay the same then you may need to replace the carb, over time they get old and wear out. Let me know how it went, good-luck.
Posted on May 15, 2010
Mower starts and runs for 10 - 15 seconds, then dies. Will almost start again, but soon will not even kick over. After a while, it will start for a few seconds. This is a 15 horse Tecumseh that looks...
It sounds like a carburetor issue. The jets are probably gummed up from the old gas that was in it. Remove the carburetor and clean it out with a can of carb cleaner. Then reinstall.
May 22, 2011 | Tecumseh Enduro Vertical Engine 16 HP 1in...
I have a lawn boy 10335 push mower that sat unused for several years. I added new gas and went to start it up it spring a gushing leak out of the carburator. There is a small red hose that the gas was...
The needle and seat are bad in the carburetor. You need a tecumseh part 631021barterjoe_2.jpg and it might be recommended to get a service manual. They are inexpensive at a shop like www.arcolawn.com
good luck
Joe
Feb 13, 2011 | Tecumseh Lawn Boy Push Mowers Insight...
Lawn Mower will not stay running then will not restart
I think we all understand the frustation penaone.
I noticed u didn't clean the fuel tank, water, dirt, and rust in it can give u problems. But u need to clean the lines and carb. again also. One of the kids filled my mower gas tank with driveway gravel once, and after I cleaned things out, the mower never run so good. Also your spark may be grounding out somewhere before it gets to the spark plug. Check for a bad spot in the wires from the magneto. Some of that may be behind the flywheel though.
ballping
Jul 28, 2010 | Tecumseh Lawn Boy Push Mowers Insight...
My push mower will start good but wont stay running..could gas that was left in it over the winter be the problem or just the wrong kind of gas
does it have a fuel tap or not, if it doesnt then the fuel that was left in the carby has gone to jelly or harder ,a carby service should do the trick and save you money in the long run
May 15, 2010 | Tecumseh Lawn Boy Push Mowers Insight...
Won't stay running
Check the gas cap vent. A partial vacuum in the tank will cause these symptoms.
Sep 06, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Lawn boy 2 cycle that smokes
Check the air breather. Make sure it is clean.
If it is clean, you will probably need to replace the diaphragm. A bad diaphragm will cause black smoke and also cause the mower to run erratically.
Jim
Jun 21, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Toro Tecumseh mower won't start or stay running
Sounds like you need to clean the carburetor. If you need tips on how to do this, just let me know.
Jim
May 20, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
I would push the prime button 3 or 4 times it starts then quiet
I took my carburetor off and blew it out with compressed air. Runs great now. Make sure to get all of it. Little screw on bottom has a hole in it too!
Apr 18, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
I have an mtd yard man mower that wont stay running, Any suggestions why?
I was having the exact same problem with my 6.5 hp Toro lawnmower with a Tecumseh engine. The engine would start up okay but after a few minutes of mowing, the mower would start missing and eventually shut down. I would pull and pull and pull on the starter rope, getting angry and frustrated and eventually going back in the house to let it cool down.
I looked up all kinds of information and I finally decided it was a bad coil (something about the resistance being low when the mower wasn't hot and then when it heated up the coil would conduct enough electricity to somehow make the engine shut down.)
I called a local shop and wanted to get an estimate on replacing the coil. I have no clue about engines so I dared not get into the guts of the mower myself. He told me to check the gas cap. HUH??????
He told me to make sure there wasn't a part missing out of it. I thought, what the heck would a gas cap have to do with the engine shutting down. Well, apparently there is a mechanism on these caps that prevents a vacuum from pulling on the fuel system and my gas cap indeed had a part missing. To verify this, I cut the grass for about 5 minutes. When it started to run rough, I took the gas cap off to allow pressure to escape from the gas tank and voila! it started to purr like a kitten.
So, I'm only out $4 for a new gas cap and I'm as good as new. Man I wish I was more mechanically inclined so I hope your problem is as easy to solve as this one.
Hope this helps!
Apr 14, 2009 | Mtd 22" Yard Machine Push Mower
Garden Logo
18 people viewed this question
Top Garden Experts
Jay Finke
Jay Finke
Dennis Key
Dennis Key
john h
