Question about KitchenAid KEMC377K Convection / Microwave Oven
Is there an electonic reset for 'door open' message. Mechanical latches appear to be working
  • KitchenAid Master
  • 9,047 Answers
If the switches are good (test & order info here), and it's a Kitchenaid / Whirlpool of recent design (by L.G.) then they have more than one fuse inside.
There will be a fuse associated with the door circuit which will cause this problem, but not render the oven "dead".
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
is there an electonic reset for 'door open' - mini_manual_behind_grille_small.jpg33eec4f.jpg
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you don't find your mini-manual, or if you want to look at it before removing the controller, you can download it here (just enter your model number).
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
Posted on May 16, 2010
Door will not open
Hello friend, thank you for your post!
I see that the door on your Frigidaire microwave will not open. Sounds like your door latch could be faulty. I would recommend performing a reset on your microwave and you can do that by disconnecting the power cord for roughly ten minutes. If your door does not open after the power has been restored you may want to contact a professional for proper repairs. Hopefully this is helpful. -Matt
Feb 28, 2015 | Frigidaire 5304440289 Microwave Door Latch...
The door of the microwave is not opened correctly
It's hard to say what could be wrong, You did not provide the Make or Model of your Microwave. Generally the latching mechanism is mechanical in nature. The latch if made of plastic could have broken, there could be a spring or a lever out of place. the movement could just have some food that got in there and "gummed up" the works.
The only way to truly figure out what the problem is is to pull the cover off and inspect it.
Dec 29, 2014 | Microwave Ovens
My Panasonic microwave nn-t945sfx. Door is hard to shut and is not latching correctly. I inspected the spring and latch and it appears to be working correctly. I noticed the two holes where the latch
Common problem. Apply a small dab of lithium grease to the tips of the door hooks. You might also have to adt. the door latch switch assembly inside the oven as it could be bent out of shape from the hard to close door.
Nov 19, 2014 | Panasonic Microwave Ovens
Fan goes on when we open the door. Goes off when we close the door. Any fixes?
This is a malfunction and must be checked to confirm if the microwave itself is working when the door is open which is dangerous. The reason can be due to a short in the door lock switch or a mis-alignment of the door switch. Also a malfunction of the main board, relay cannot be ruled out.Remove power and close the door with a gentle force , few times so as to disengage any lock switch defect. now try if the fan cuts off or else it is best to take opinion as you will need to disconnect the HT section to check this fault to prevent any stray microwave.
Nov 30, 2011 | Frigidaire PLMV169DC Microwave Oven
Neff H7871 oven door does not stay closed. Catches do not appear to be working
The door latch is either cracked or broken.The door when gets closed the door latches clicks.But if the door latch is loose or cracked it will not click and door will not close.The door needs to be disassembled and the door latch has to be replaced, if the latch is cracked.Also to check the latch from inside the door needs to be removed.-------- This will help.thanks.Helpmech.
Jun 29, 2011 | Neff Microwave Ovens
Message F5E1
F5 E1 16 Door latch not operating Check that door switch is completely closed. Check latch, solenoid, and actuation switch for electrical or mechanical malfunction.
See the technical sheet hidden behind your control panel or look it up by model number here.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Aug 21, 2010 | Microwave Ovens
NN-T774 INVERTER STOPPED WORKING AFTER 4 WEEKS
Check to make sure one of the plastic hooks on the door was not broken off. If both door hook latches are functional then the most likely cause of your problem is one of the latch switches located behind the control panel. These switches will fail if the oven user opens the door frequently BEFORE the cook cycle ends. Always push STOP/RESET before opening any microwave oven door.
Dec 30, 2009 | Panasonic Microwave Ovens
MICROWAVE WILL NOT HEAT. F9 APPEARS IN THE DISPLAY WINDOW
F9 indicates a problem with the door latch.  There is a safety switch that will not allow the microwave to operate if it detects the door is not closed properly.  Even though physically it may seem the door is shut, the safety switch is not relaying the message to the onboard computer.  You need another door latch switch.
Mar 10, 2009 | Kenmore 63663 Microwave Oven
Panasonic - convection/microwave oven door is stuck shut spring will not open same -dinner in oven help
What usually breaks is the door open lever.
On a counter top model, the outer cover will need to be removed to diagnose and repair this. On an over-the-range model, only the control panel needs to be
removed.
Please unplug the oven first.
If you or someone you know wants to look into this, we have critical safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa.
Once it is apart, you'll be able to see how the door open button would press against the door open lever, which would then lift up against the door latch heads (hook-like projections on the door) and the door should open.
You can order Panasonic parts here.
I hope this picture shows up - it helps illustrate:
Aug 10, 2008 | Panasonic Microwave Ovens
KitchenAid KEMC377K Convection / Microwave Oven Logo
137 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Stu Ungar
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
