Question about Frigidaire FEX831CS Top Load Stacked Washer/Dryer
Stackable unit with a squeak
I have a stackable unit with a squeak when drying. I have read to replace the rear barring you should do it through the front of the dryer. But that was on modles that are not stacked. Is it the same way on a stackable dryer? and if so any clue on how to get the front off?
  • Grammy213 Jan 08, 2009
    Yes I have the same dryer problem as inocntdevil. With regard to aborcass' instructions,The only problem for me is it does not indicate where to purchase the e-kit. Could you please advise, Thank you very much! ncm
    President:
  • Frigidaire Master
  • 2,651 Answers
The front panel will need to come off, disconnect power to unit.
remove the angular panel between the units theres a couple of screws behind there to remove the console(it drops sown no need to remove)
next there are maybe 4 screws across the very top of the unit (actually will be easier to remve the entire top of unit)
2 more screws behind the console then release the front panel, need to be mindfull of door switch wires.
ok from here you can reach under drum and release the tension pulley holding the belt( beforeyou do get a feel (you wont be able to see it) get a feel for how it operates and applies tension because youre gonna have to reattach in in alittle while
after that grab hold of the entire drum and give it a good lift off the rear bearing, might need a little ummf but ittl come out. afterthat follow instuctions in th ekit and reassemble unit.
my adive is that you use the supplied screws that hold rear bearing to drum to thread the rear bearing plate ahead of actually trying to secure it. much easier trying to reach in the drum and tightene the screws if the holes are all ready threaded.
Posted on Mar 31, 2008
Kenmore stackable dryer squeaks So loud. How can I fix this.
A model number would greatly help, the dryer is most likely made by Frigidaire for Kenmore, your squeal is probably from a dried our drum support bearing at the rear center of the drum. If this is the case, an experienced repairman is advised to make this repair. Pleazer Appliance...
May 18, 2014 | Dryers
My Frigidaire Gallery dryer squeaks and leaves brown crescent burn marks on our laundry items.
If you live in Pasadena, CA and you need a Dryer repair service our professional technicians will perfectly repair your dryer as fast as possible. All you need to do is to call at (626) 460-0903 or visit our website http://www.appliancerepairspasadena.com .
Dryer repair Pasadena CA Bosch LG Electronics Amana Beko
Sep 02, 2017 | Frigidaire Gallery Series GLHS269ZDB 36"...
My kenmore electric stackable dryer squeaks and I can't find anything rubbing. Is there a place that I should lube?
That sounds like a belt. Try a bar of soap first. If it quits, replace the belt.Oh yeah, rub the soap around the belt.
Nov 21, 2012 | Dryers
Ge stackable wsm2700dawww Dryer making noise,maby belt,and not drying very well.
USUALYY FRONT DRUM GLIDES AND REAR BEARING ASSYMBLEY PARTS ARE MADE OF TEFLON AND THEY WEAR OUT
Jan 24, 2011 | GE WSM2700W Unitized Spacemaker Washer and...
My dryer squeaks upon starting to dry a load of clothes...everything else works fine except it squeaks the whole entire time. Any advice?
GE dryers have a straight rod in the back center of the drum that goes through the rear bulk head and that is what supports the drum in the rear, it is also what squeaks when it gets warn out , around that short rod that goes into rear bulk head from the drum is a black Teflon plastic sleeve called a barring replace it and that will fix the noise
Apr 05, 2010 | GE DVL223EBWW Electric Dryer
Squeaks and sqeals during dry cycle
Lubricate the contact points, pulleys , change the felt seal .
Get a new dryer, abot time?
Vitally
May 14, 2009 | Dryers
Irregular squeaking from stackable dryer
Post your make and model please. Sounds like the rear drum bearing is dried up
Feb 20, 2009 | Frigidaire FEQ332E Electric Dryer
Dryer makes a loud squeaking/squealing noise while drying.
If the dryer model number begins with 417, the drum is supported by a ball bearing in back, and a seal and glides up front. Often, the bearing will become very dry, either from years of use, or from excessive lint blowing up into the bearing. If the bearing isn't cracked or otherwise noticeably bad, you can usually solve the issue simply by lubing the bearing with a high temp grease. While the machine is apart...(a major pain in the butt), make sure to check the condition of the seal and glides on the front panel, and replace the belt if it looks at all cracked or frayed.
If this dryer is not a 417 and/or does not have a rear bearing, it's best to get a maintainance kit (belt, idler pulley and drum rollers) and install all the aforementioned parts, as they are the most likely source of screech. Also, check the motor by spinning the shaft manually with the belt off....if that is squeeking, it's motor
time.
Jan 15, 2008 | Kenmore 98702 Stacked Washer/Dryer
Frigidaire FEX831CS Top Load Stacked Washer/Dryer Logo
276 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
