Question about HP LaserJet 1010 Printer
2 or 3 wide horizontal black lines appear at every page i print thanks for your help
  • 108 Answers
Change the Cartridge or Recondition the cartridge.. if problem continues, send the printer for any HP authorised service centre
Posted on Jun 01, 2010
Horizontal lines. Xerox 6505DN
clean the print heads and align them
Sep 10, 2012 | Xerox 6505N AllInOne Printer
I have a grey/black line all the way down the right hand side of the page
Run a half test.
Put paper in the manual feed tray.
Print something, anything
When the paper is 1/2 way into the printer, open the cover.
Pull out the toner cartridge. Look down at the paper.
Does it have a black line on the right side?
If yes, replace the cartridge. If no, replace the fuser.
May 11, 2011 | HP LaserJet 1010 Printer
Problem for print by photo copier
sounds like the charge grid is not set properly in the drum unit..did you et up the drum unit properly and run the new dev and drum set up..if youy are getting black the charge is not working correct as the charge of the drum help to keep the toner from adhering to the drum surface when copying .. I would take the drum chrge unit out again and check it is set in the right way when you put it back on also check the contacts arent put out of line.
Aug 05, 2009 | Kyocera Copystar CS-1820 Black and White...
Black vertical line (1 inch wide) appears while scanning/copying
For this kind of problem you need to call the tech support because the printer is already messed up and it is in need of replacement
Hope this help
Byron
Jun 15, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Epson Stylus Pro 4800 Never Before Seen Banding Problem
Clean the nozzles, align the print heads, turn it off for about an hour. You may need to do this twice, but it works for me.
May 26, 2009 | Epson Stylus Pro 4800 InkJet Printer
Black horizontal lines in printout
Seems like the drum needs changing. This is the most common cause for print problems in these printers. If using the high yield TN 6600 toner then you need to change the drum every 3-4 toners. If using the low yield TN 6300 toner then the drum will need replacing every 6-7 toners. Hope this helps
Nov 16, 2008 | Brother HL 1440 Laser Printer
Is there any debris under the printhead nozzle plate?
Jun 22, 2008 | Epson Stylus Pro 4800 InkJet Printer
When printing in color a yellow line appears on document
A horizontal line U say and U don't have problems in B&W pages.... ( on the length or width af a A4 page?) the yellow line is just a line or parallel lines at the same distance?.
1-st of all try replacing the Y cartidge.
Jan 17, 2008 | HP LaserJet 2840 Printer
Dell 3100cn printing horizontal stripes
Sounds like a bad imaging drum to me...
Aug 14, 2007 | Dell 3100cn Laser Printer
HP LaserJet 1010 Printer Logo
159 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
