Question about Neovo F 415 (Black) 15" LCD Monitor
Neovo F-417 Auto Adjust Won't Stop Blinking. How
My Neovo PC Monitor all of a sudden starting Auto Adjusting all by itelf, and it wouldn't stop. I had to turn off the computer and plug in a different monitor. Anyone know how I can fix this Neovo Montior from stopping this Auto Adjust issue?
sandrew
  • 2961 Answers
SOURCE: Neovo F-417 failure
You may need to set your laptop to send the video signal to a secondary screen, this will be done by right clicking on the desktop and clicking on graphics properties. Some laptops have a presentation mode on them it may well be there also.
Posted on Jan 29, 2007
  • 359 Answers
SOURCE: X2Gen MW19U: Start "Auto Adjusting"
This sounds like a straight hardware issue. However, to be certain, try to attach another monitor to this PC, and if it works properly, you will know that there is nothing wrong with the graphics card/driver or other related component of the PC involved. (Also make sure you are using the proper type of cable - analog/digital - for the connection.) Also suggest switching out cables to eliminate that. Further, you could try to see if the monitor functions properly when attached to another machine. If the machine is not functional and another is, that will confirm that the issue is hardware-based.
Unfortunately, X2Gen has declared bankruptcy (see http://x2gen.com/) and there is no way to go back to the manufacturer for either support or warranty service. If you are still within a given time frame with either the retailer, or perhaps through a credit card company, this would be your best recourse. Here is the link to the form via which you could file a bankruptcy claim: http://www.x2gen.com/files/Claim.pdf. Hope this may help, if you can't get reimbursed through some other means.
My experience with this type of issue is that the hardware has gone bad. Particularly with the nature of your problem, it seems that it is not a minor problem, and does not appear to involve drivers or other software-type fixes. If you could get a professional tech to repair it, the cost would most likely be more than replacement of the monitor. Sorry for the bad news, but I don't think there is a better solution.
If the monitor continues to behave in the same manner, I think that is absolute confirmation that you have a "nonnegotiable" hardware issue. If not - in other words, if you see something different with switch of connections/machines, there could be a graphics card/driver or other issue that we could work on further.
Please post back if you need additional assistance, or this does not answer all your questions. Otherwise, thanks for using and rating FixYa!
Posted on May 29, 2008
mavreix
  • 63 Answers
SOURCE: My Neovo f-417 LCD Monitor is switching off after
This means there is a hardware failure in the monitor that could be either blown CAPs or a shorted out inverter. It is difficult and dangerous to replace both of those(involving soldering and desoldering) if you don't know how as LCD's are made of a hazardous material. I would try new cables and on a different computer as a last resort and if that doesnt work then your monitor is trashed. If it works on another computer then the issue is not with your monitor. Good luck!
Posted on Sep 23, 2009
  • 293 Answers
SOURCE: Neovo F-417 monitor keeps switching
The power supply of your monitor have problem.Leak capacitor at ur power supply need for replacement
Posted on Oct 05, 2010
SOURCE: Please ? i need shematic diagram for monitor NEOVO
jais un probleme avec mon monitor lcd nuevo s17 ,il s'allume et l'écran ne s'affiche pas c'est quoi la solution a se probléme
Posted on Dec 31, 2010
F-417 Neovo monitor only works in safe mode. Can this be fixed?
Can you please clarify the problem? It works if you start the computer in safe mode but not in normal mode? Do you get the message like 'out off range", "format not supported"?
Mar 18, 2011 | Neovo F-417 17" LCD Monitor
Neovo F-417 contantly autoadjusting - help!!!!!
Check to see if the auto button is sticking (press it hard a few times, and wiggle it)
If it's not that then It's probably the power supply blinking out (monitor thinks it was shut off and back on)
If so, There's a good chance you have failing electrolytic capacitors either in the power section or the inverter section or both.
Any caps in these sections that look bulged at the top, or bulged/leaking at the bottom need to be replaced.
If you aren't tech savvy, this unit needs to go in for repair.
If you are handy with a soldering iron and can identify the power supply and inverter / FM section for the backlights, an inexpensive handful of capacitors will likely fix you right up.
Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.
IE - it's not a bad idea to replace a 10V cap with a 16V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are positive it's only doing ripple filtering).
Mar 01, 2011 | Neovo F-417 17" LCD Monitor
Neovo F-417 monitor keeps switching off and takes several minutes to be able to switch it back on again
Oct 04, 2010 | Neovo F-417 17" LCD Monitor
Please ? i need shematic diagram for monitor NEOVO F - 417
May 29, 2010 | Neovo F-417 17" LCD Monitor
Circuit board for a neovo monitor
Which circuit board are you after
Jan 08, 2010 | Neovo F-417 17" LCD Monitor
My Neovo f-417 LCD Monitor is switching off after 3-4 seconds. Green lamp is still blinking but there is no ligts and picture on screen. Only black screen
Sep 23, 2009 | Neovo F-417 17" LCD Monitor
The auto adjust has started popping up/picture keeps moving
take your monitor backand Req a new one.
It is having a "jumper" prob ,... The solder is arcing from one diode to the next.
Dec 23, 2008 | Neovo F-417 17" LCD Monitor
Neovo F 415 (Black) 15" LCD Monitor Logo
436 people viewed this question
Top Neovo Computers & Internet Experts
Questman
Questman
Level 1 Expert
Dimitar Todorov
Are you a Neovo Computer and Internet Expert? Answer questions, earn points and help others
