Question about Acer AL1916W 19" LCD Monitor
Acer monitor says no signal, then goes blank. Is
Acer monitor says no signal, then goes blank. Is there a driver needed, what can I do. I already purchased PCMD and it did not fix the problem
  • Acer Master
  • 4,737 Answers
We are using the same monitor type.. humm it's good that i already had experience with it. No drivers needed to install this monitor, check the connection to the PC and to the monitor, make sure they are inserted properly. Sometimes when you put on the PC first and then power on the Monitor causes this problem. The best recommend resolution is 1440X990, good luck..
Posted on May 15, 2010
Monitor not working it lights up and says acer then it says no signal and goes blank
There are two common reasons for that problem. 1) Your video card on your pc may be having issues. 2) Your monitor is not working properly
Here is a test to isolate the problem to the monitor. Plug it into another pc or laptop VGA or DVI slot and try to power it on again. If it works then you know for sure it's your video card giving trouble. Either gone bad or needs the drivers to be updated/uninstalled and reinstalled.
If it doesn't work then you're looking at some monitor repair or potentially a new one. However since you said you saw the Acer logo, it's a positive sign it's not really your monitor as it would not work all together if it had an issue.
Hope this helps and thanks for using FixYa.com
Apr 24, 2010 | Acer 22" X223w LCD Monitor
No Signal
yes start the computer then keep pressed the key F8 untill the display comes then hightlight the option last good known configuration and select the problem will be solved
Mar 06, 2010 | Acer 22" X223w LCD Monitor
Monitor Acer Al 1914, no signal
Check your connections to the PC. Make sure that they are nice and secure. If there is a resolution problem setting it should display the boot process and then go blank after starting the operating system.
Oct 28, 2009 | Acer AL1914 19" LCD Monitor
How do i get my acer 5715z laptop to work with external monitor , the monitor goes into power save mode as goes to log on page . My laptop monitor has a large cracked mark on it thats why i need an...
Cause If you connected the monitor power already is on, you may not get signal. Power plug off the monitor first, Then connected to laptop. Then power the laptop and power the monitor. FN key press hold with your Monitor swicthing key which symbol of two monitor shows on key probably number 5 or 6 maybe 7 check user guide if you have it.
another cause is your monitor may need driver install in your laptop, Some system required that. Check monitor system requirements.
JMC
Aug 15, 2009 | Acer Computers & Internet
Screen Goes Blank
Ive seen this on other monitors. Look for a 1 and 2. Some monitors do NOT auto detect a signal, and this one might not. Look for a way to set the monitor from Digital input to VGA input. Try that and see.
Jul 21, 2009 | Dell E173FP 17" LCD Monitor
Acer monitor AL1716W 'no signal"
You will need to download the drivers for this monitor. Your laptop already has them installed.
Dec 27, 2008 | Acer AL1716 F Monitor
X191w blank screen after 2 seconds
Just got off the phone with Acer Suppport. This was after I sent an email to them, that suggested that I call. 8-/ annoying. So the guy on the phone says there is one thing that we can do before sending it in. Unplug it completely for the wall and computer. Hold the on/off button in for 30 secs. reconnect power and the computer. It worked for me
Oct 07, 2008 | Acer X191WSD Monitor
Acer AL1711 17" LCD Monitor goes blank without warning
The need to reboot your computer to get your monitor working places the blame totally in the computer. You have a virus, or the computer is overheating and shutting down for thermal reasons.
-CharlyV
Jan 26, 2008 | Acer AL1711 17" LCD Monitor
Installing AGP video card
Don't boot with the monitor connected to the card. You need to let it boot into windows and install the drivers for it first. Once you do that,shutdown and restart with the monitor plugged into it and it should work.
Sep 13, 2007 | Sis 6326, (4 MB) Graphic Card
Acer AL1916W 19" LCD Monitor Logo
160 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
