Question about Kenmore Front Load Washer
Oxiclean how to use oxiclean in my front loading machine? They said to dissolve oxiclean in a cup of water and put it in the bleach dispenser. But the dispenser doesn't take a whole cup. Is there other ways to add this product to the wash cycle?
  • Anonymous Mar 17, 2014
    don't know how to add oxiclean to soak cycle
  • 5,081 Answers
Mix one ounce OxiClean powder with your powdered detergent in the detergent dispenser of your front loading washing machine.
OR
Dump one ounce OxiClean powder into the washing machine before you add clothes.
Posted on May 15, 2010
I have a fisher & paykel front loading washing machine & need to know what each of the three slots where washing powder goes stand for? Machine Product Code 98707 & numbers WH70F60W1
You normally have 3 cups; 1 for Bleach, 1 for Liquid Fabric Softener, and 1 Liquid Clothes Detergent. I don't ever recommend using Laundry powder in front loads as it has a tendency to not fully dissolve and will build up in the dispenser overtime and prevent your clothes from washing.
Feb 12, 2018 | Fisher Washing Machines
How do I get the bleach dispenser to drain?
Hello Denise C - There are several things that could cause the bleach to not dispense into the washer. Are you sure the liquid in the dispenser after the wash is bleach? If it is pure bleach, the solenoid that lets the water into the dispenser is not working. This solenoid is located on the back of the dispenser. It only gets voltage during the dispense time and fills the bleach dispenser with water. The bleach dispenser fills while the washer is filling for the rinse cycle.
When the washer begins to fill for the rinse cycle, the bleach solenoid is energized and water flows into the bleach dispenser cup. When the cup is full the water siphons out and bleach and water flow into the tub.
If the liquid in the bleach dispenser is pure bleach you may need a technician to diagnose and repair the problem. The voltage will have to be tested to the bleach solenoid and a volt meter is required.
If the liquid in the bleach dispenser is water you probably need to clean the dispenser cup. Scum will build up in the siphon tube and stop the liquid from going into the washer tub. The incoming water will dilute the bleach and overflow the dispenser cup and run into the tub.
Remove the insert from the bleach and fabric softener compartments. Clean the bottom of the insert and the bleach and fabric softener compartments. Reinstall the insert and put the drawer back inside the washer.
To test the siphon action slowly pour water into the bleach compartment. When the water level goes above the maximum line stop pouring. The water should all drain out. You may also test the fabric softener compartment the same way.
I do hope this information proves to be helpful.
Jan 01, 2013 | Frigidaire Affinity ATF7000E Front Load...
Why does my bleach dispenser cup fill up with water every time I do a load of laundry?
I agree with grady709 about the plugged inlet lines, I had water left in my Samsung front load all the time and made sure the machine level and nothing wrong with venturi. I suddenly had water leaking from somewhere instead and when I took the top off I could feel the line swell up and leak at the fitting. Hose still leaked after replacing. Put a drill bit by hand down the nozzle where the hose clamps on and it was plugged up and also the bleach line was plugged up, also inside where the tray goes there is small holes in the top where the water sprays out can be plugged. Worked for me. Live where the water is hard.
Nov 24, 2012 | Samsung Washing Machines
How to clean my washing machine Electrolux Front Loader
Hello -
First rub some bleach around the door gasket. Let this dry. Next rub some vinegar around the door gasket. Let this dry. (Do NOT mix the bleach and vinegar) Then run a hot empty load of bleach in all three dispensers. Put 1/2 cup of bleach in the detergent dispenser and fill the softener and bleach dispenser to the max fill line with bleach. Once that is done repeat the process with vinegar. Please make sure you run a load of towels or some sort of items that will not matter if you get a little bleach on them once this process is done.
Sep 21, 2012 | Electrolux EW1000i Front Load Washer
Bleach not dispensing
Make sure it is actually bleach, and not water. Most models with a bleach dispenser in the drawer actually dispense the bleach by adding water to the cup and allowing the mixture to overflow into the machine- so that pure bleach doesn't land on your favorite shirt before there is any water in the machine.
Jul 30, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
My HE washer doesn't dispense the fabric softner
Try removing the dispenser cup - and washing the inner cup thoroughly- run a sanitary cycle with whites and chlorine bleach mold and mildew likes to haunt these front loaders - be sure to run a bleach hot water cycle once weekly
Mar 01, 2009 | Kenmore Elite 45986 Front Load Washer
Bleaching subsequent loads
I'm no repairman but here's a coupla thots:
1 - try running an empty load after bleaching. Save money and just use cold water. First add a few cups of water to the bleach dispenser to help flush out the old bleach that might remain, then run it.
2 - lemon juice is naturally acidic and should neutralize the bleach. You could add some to the bleach dispenser and do the above. Maybe mix a half-cup with a few cups of water and put in the dispenser, then run it. (Lemon juice [or vinegar] is good thing if you get bleach on your hands, too.)
OF COURSE -- Test to see if this works with a couple colored rags before running any good clothes through.
3 - How about using oxygen bleach alternatives (color-safe bleach) instead of regular bleach?
I suppose there could be a problem with your dispenser, idk....
Feb 20, 2009 | GE WBSE2090A Top Load Washer
Bleach dispener always full of water
call for service, they will probably order the dispenser assembly (includes new drawer.)
Apr 23, 2008 | LG WM2455 Front Load Washer
Kenmore Front Load Washer Logo
994 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
