Question about D-Link AirPlus G DWL-G510 802.11g/b Wireless Adapter
Wireless Network It finds my wireless network, but when i try to connect ot it. It says that the network is out of range and th bars/ping is full...
3 Suggested Answers
sandrew
  • 2961 Answers
SOURCE: wireless network connection
if you system is secured, then she would not be able to connect to the internet via your rour router unless she has the password.
She won't be able to connect to your pc unless any folders are shared on the network.
Right click on the network icon in your task bar and click view wireless networks, then when all the networks show delete them all and close the window, next, a pop up will say found wirelss connections click the icon again and look for your connection in the list and click connect and enter the pass phrase
Posted on Nov 06, 2007
SOURCE: when trying to connect ot wireless network windows
Have you tried to uninstall the driver and letting windows install a generic driver?
if that doesnt work you can check the signal type. Is the wireless router b/g or n ?
Posted on Feb 24, 2009
Wireless network
Assuming you are using Windows 7, connect to your wireless network, click the signal bars, right click your wireless connection and select properties. Select the Connection tab and make sure
Connect automatically when this network is in range is selected.
nqaakhh4qwaybreaahg4qwaybreaahg4qwaybreaahg4qwaybreaahg4qwaybreaahg4qwaybreaahg4qwaucn9f4k8oqqzjcdlaaaaaelftksuqmcc
Dec 27, 2013 | Dell Inspiron 1525 Notebook
Tip
Configuring WRE54G to a wireless router
Before you start configuring the WRE54G you need to consider the following factors:
1. Make sure that there are no wireless security enabled on the router like WEP and wireless MAC filtering. If you have them enabled try to disable them first. Check if there is a wireless computer that is currently working on your network.
2. Make sure that the SSID broadcast is enabled.
3. Then Hit the Automatic Configuration button on the WRE54G for about 3-5 secs.
The wireless computer should be connected to the SSID of the Range expander.
The range expander doesn’t have any DHCP server. The IP address that will be assigned to the computer will be 0.0.0.0 or the Auto-configuration IP 169.254.xxx.xxx.
Assign a static IP address on the wireless card. IP address should be 192.168.1.5, Subnet Mask 255.255.255.0, Default gateway 192.168.1.1
To assign static IP address on your machine you follow the steps below:
Windows 9 xs and ME:
Go to Start > Settings > Control Panel > Network > Highlight the TCP/IP of the Wireless LAN card you’re using > Properties
Under IP Address TAB:
Specify an IP address: 192.168.1.5
Subnet Mask: 255.255.255.0
Click the GATEWAY TAB:
Under New Gateway: Enter 192.168.1.1 then click on Add.
Then Hit Ok All the way out… hit yes if it’ll ask you to restart
Windows XP and 2000
Go to Start > Control Panel > Network Connections > Right Click Local Area Network Connection that you are using > Properties > Internet Protocol TCP/IP > Properties > Use the following IP address:
IP Address: 192.168.1.5
Default Gateway: 192.168.1.1
Then click ok all the way out.
Try to ping the Range expander. Go to start and then run type CMD for Win XP/2000, COMMAND for Win ME and below. On the black screen that will pop-up type PING 192.168.1.240 (Default IP address of the Range expander.
If the ping test was successful then you can access the setup page of the Range expander. If not, try to reset the Range expander for 10 seconds and then power cycle it.
To reset the range expander, follow the steps below:
Hold down the reset button for 10 seconds then unplug power while holding down reset...plug it back in after 5 seconds then wait for 10 more seconds before releasing the reset button.
To access the setup page of the expander, Open your Internet Explorer and please go to http://192.168.1.240
If will prompt a username and password box, leave the username blank password is admin.
On the setup screen of the expander, you can set the same exact settings on your router. SSID, Channel, WEP settings should be the same on the router and you need to specify the WLAN MAC Address of your router to the space provided for the WLAN MAC address on the setup page of the Range Expander.
Once you applied the settings, the lights on the expander should be both blue.
You can now set your IP address back to obtain an IP automatically and Obtain DNS address automatically.
Range expander should be working after performing the troubleshooting steps above.
If you have an Ethernet port on the WRE54G, try to connect the range expander directly to your computer with static IP address then ping the WRE54G. Make sure that you are not running any firewall and Internet security in your computer. If you were able to ping the 192.168.1.240 try to access it through the Internet Explorer and configure it from the there. Follow the steps that I gave to you to configure the wireless settings of the range expander.
Make sure that you have checked all the wireless security settings on your router. Make sure that you have those disabled. Try to set static IP address in your computer and try to ping the 192.168.1.240 and see if you can get a reply.
To set static IP follow the steps below:
Windows 9x and ME:
Specify an IP address: 192.168.1.10
Windows XP and 2000
IP Address: 192.168.1.10
Then Hit Ok All the way out.
on Feb 07, 2010 | Linksys Wireless-G Range Expander (WRE54G)
Hi I have an old Fujitsu P7010 I'm trying to connect to wireless network at home . But it doesnt seem to find a wireless network in range.
If you are trying to connect to a free WiFi network site try the Airport. Macdonalds, Starbucks etc.
The wireless networks in your area are most likely private wireless networks and if you find one within wireless range you most likely cannot connect into this network without the owner's permission because the connection will be encryption protection (they would need to give you this encryption key).
May 09, 2012 | Fujitsu Siemens LifeBook S7010 Notebook
Wireless router was working now its not, now light showing wireless on the router, I have internet if i plug in derectly to the modem
Jus Powercycle the Whole N/w
Unplug Modem and Router
Plug Modem First and then Router
Check Wired Internet to Router if that Works, wireless will be Online
Oct 01, 2010 | Linksys Wireless-N WRT150N Router
I have an older dell desktop with a pentium4 and runs on XP. It has a Dell truemobile 1180 USB Adapter that connects to wireless networks. Everything worked fine at the last house with 2-4 out of...
In the Network Connections window, right click on the USB adapter and select Properties. Select the "Wireless Networks" tab. In the Preferred networks area, select the name of your wireless network so that it is highlighted. Then press the Remove button. Click OK.
Windows should now inform you that it has located an available network. Try connecting into it now.
Aug 24, 2010 | Dell Computers & Internet
Cant access internet through wireless network.
How do you know your notebook is connected to your wifi AP? Did you try pinging the gateway? If not, open your command window & type "ping 192.168.0.1" (put in your own gateway address.) If you get replies, then ping something outside of your network: "ping 4.2.2.2" (this is a verizon dns server). If you get replies, then "ping yahoo.com". If it does not fail at any of the above steps, you don't have a connectivity problem. If you fail any of the above, then report back & we'll continue the troubleshooting.
Jun 08, 2010 | Acer Aspire 5536-5224 Notebook
My laptop will not recieve a signal from my desktop
Check whether the packets are routed properly. Check Ping for your laptop and desktop. If any packet loss is there check the configuration .
Oct 19, 2009 | Linksys Wireless-G Broadband Router
When trying to connect ot wireless network windows
Feb 24, 2009 | D-Link Platinum RangeBooster N DWA-642...
Default gateway
When you ping the gateway with your computer it could not communicate with the gateway.
Assuming you are connecting via a network cable.
Either the network cable is broken or network card is faulty or it is configured incorrectly.
Make sure your TCP/IP address of your network card has the same TCP/IP address range as your gateway.
Jul 24, 2008 | D-Link AirPlus Xtreme G DWL-2100AP...
D-Link AirPlus G DWL-G510 802.11g/b Wireless Adapter Logo
22 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
