Question about Amana 3.2 cu. ft. Top-Load Washer
Water is leaking from the washer when performing
Water is leaking from the washer when performing spin cycle
  • 1,557 Answers
You have a leak comming from either the pump seal of pump outlet hose
Posted on May 15, 2010
It will fill but once full the motor will only spin for a few seconds then stop
IT MAY BE DUE TO A RINSE PROBLEM?
WASHER WILL NOT RINSE:
If your washer doesn't go through the washer rinse cycle, the most likely cause is the water valve. What happens is the water valve will stop letting cold water into the washer; therefore, once the washer gets to rinse it will either stop or not do anything during the whole rinse cycle.
This is because when you selected your water temperature, you selected warm/cold or hot/cold. The hot water came in and you didn't notice any problems. When it got to rinse, the cold water the cold water won't come in. Therefore, the washer does nothing.
To check the water valve, first cut the water off and remove the hoses off the back of the washer. Then one at a time point the hoses inside the washer tub and turn the water back on. If you don't have good water pressure, turn the water back off and remove the strainer that should be in one end of the hose. Inspect the strainer to see if it is stopped up, clean it and reinstall it. Now repeat this test. If you have good water pressure now, reinstall hose and your problem is fixed.
If you still don't have good water pressure, the problem is in your house plumbing and you need to call a plumber. If you had good water pressure the first time you performed the test, the water valve is bad and needs replacing.
TIMER
If your washer doesn't go through the washer rinse cycle the timer may be the problem. Sometimes the timer gets stuck in the middle of the cycle or won't turn at all. If the washer runs, but the timer doesn't turn, the timer is bad and needs replacing.
Do you have anti-flood hoses leading to the machine. If you do there is probably a loose tube in the back causing a small leak. When the hoses detect that water is still flowing after a certain amount of time due to the leak it shuts down and causes the machine to turn off during the rinse/spin cycle
Apr 19, 2015 | Washing Machines
Amana washer will not go through rinse cycle
TIMER
Mar 28, 2015 | Amana Washing Machines
My washing machine mentioned above wont drain the water or preform the spin cycle process once it gets to the usual 7 minute mark. No leakage, just not drain or spin. How can I fix it?
TIMER
Mar 26, 2015 | Washing Machines
Washer is leaking during rinse/spin cycle
What is the model number of your unit?
Nov 23, 2012 | Washing Machines
Roper RAX4232JQO does not spin on spin cycle
Rub your hand under the center of the machine at the bottom of the gearcase. If you hand is oily, the gearcase is leaking and the oil has migrated to the spin clutch, causing poor spin performance. The gearcase and clutch will have to be replaced DIY $300.00+. If not oily, then replace the clutch only DIY ~$75.00
Mar 06, 2012 | Whirlpool Washing Machines
Fixn my GE washer spin cycle
It sounds like it could be the lid switch, check to make sure the lid switch is clicking when you close the lid.
Jun 27, 2008 | GE WHRE5260E Top Load Washer
Bosch WFR2460 Leaks
are you sure it only happens in the spin cycle? and is the leak comming from the bottom front of the washer? most front laoders will leak due to a tear in the belows. that is the rubber boot that seals the washer tub to the front panel. if there was a hole or a tear in the bellows it should have a leak inthe wash cycle also. but there are also other possibilitys too.but its strange to only leak in a spin cycle due to the washer is extracting the water and not adding it. so check and see if it leaks in the wash cycle to and get back to me and we can go from there. looking through my training manual i dont see what could cause a leak in just the spin cycle
Aug 04, 2007 | Bosch Axxis+ WFR 2460 Front Load Washer
AMANA WASHER WILL LEAKS WATER IN TUB AFTER SPIN CYCLE.
Cylon, sounds like you need to replace the water inlet valve. It's not seating and weeping water. For series 10 the part number would be 40097701. Not that hard of a job. Catriver..post back.
Feb 20, 2007 | Amana ALW880WH Top Load Washer
Amana 3.2 cu. ft. Top-Load Washer Logo
121 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
