Question about Minn Kota Maxxum 70 Universal Motor/Sonar Combo
Foot pedal adjustment
Foot pedal moves too easy,causes hard to steer
  • Caleb Aronson Jan 21, 2009
    I have a logitech steering wheel with footpedals, the steering wheel will work but the foot pedals won't
  • Anonymous May 15, 2009
    The trolling motor steering requires constant correction because it won't hold its course. There is a steering cable tension screw adjustment under the front of the pedal and I have tightened it some but I'm afraid of over-tightening. Is there another adjustment for this problem? Should I lower the depth of the prop further or what?
Hissing noise when braking
The hiss sounds like the power brake booster has failed.....but usually that only causes the pedal to get hard. A pedal that goes all the way to the floor normally indicates a bad brake master cylinder.
Aug 01, 2014 | OEM 2001 Chevy Suburban 1500 Radio / CD...
Ignition locked on a 1996 Toyota Camry
If the steering wheel won't move either, then just put the key in the ignition and wiggle the steering wheel or pull a little harder to the left while turning the key. Happens all the time when people push themselves out of the car by the steering wheel. They lock the steering wheel, which locks up the ignition.
Feb 13, 2014 | Prenco 1996 - 2001 Toyota Camry Direct...
My toyota avanza fuse blown...where it is? what is the short form of the fuse?
Commonly below steering wheel, between pedals and left door is located a fuse box, they're colored but you can see if any is opened (blown), possibly you'll need pliers to remove them from the box, is recommended to do it one each, to avoid messing them.
Mar 01, 2011 | GPS
Car started running rough - sounds like only firing on three cylinders? very wobbly on tickover and not much power on acceleration?
Probably a bad o2 sensor.Do you have to have your foot on the gas pedal at a complete stop to keep it running?
Nov 21, 2010 | GPS
How do I adust the windsheild mount?
I just got on myself. It is deceiving but it can adjust. You have to be very firm with it. I strongly recommend NOT having the GPS unit attached or having the mount on the window when adjusting as you have to bend it hard to move it. Just bend it whatever direction you want it to move and it will move. It is just VERY stiff. My guess is because that helps it maintain whatever position to bend it into. Good luck.
May 31, 2009 | Motorola Mobility MOTONAV TN20 GPS...
TomTom XL V2 EasyPort Mount
I wish I had that problem...mine won't stick at all!
Sep 16, 2008 | Tomtom One Europe v2 GPS Receiver
Minn Kota Maxxum Trolling Motor
I had the same problems with my 70lb, my motor just quit while on the lake, took it to a minn kota service repair shop. I had two issues. One was the little magnet under the button on the foot pedal got recessed to far down, the tech told me if it happened again pop the button off and pull the magnet up some. Simple fix. I took it home put it back on the boat and nothing just a slight ticking noise heard from the pedal with no prop movement. So I thought maybe somethin was wrong with one of my batteries. Unhooked everything, tested both of them, all good. Even though there was hardly any corrosion, I clean everything, hooked it up and "WALLA"! Power! Problem solved, for now. Waitng to test again out on the lake
Aug 24, 2008 | Minn Kota Maxxum 70 Universal Motor/Sonar...
GPS Logo
241 people viewed this question
Top Minn Kota GPS Experts
Will Halftowaite
Are you a Minn Kota GPS Expert? Answer questions, earn points and help others
