Question about McCulloch Garden
I have a McCulloch Cabrio 433l Petrol Strimmer & Edge Cutter which starts ok but the throttle doesnt work i cant get the case open to investigate the problem to ascetain what is causing the problem the unit is new and hasnt done any work due to this fault.I have followed the operation manual instructions i was wondering if its the operator or the machine am i not doing the right thing when i start it? I cant return this to the manufaturer because i cant find the receipt which was lost during a house move i purchased the unit 9 months ago prior to putting all me posessions into storage hence the long time between using it.
If its the same as mine, you need to take off the air filter cover (two allen keys) and then you will probably see that the throttle cable has come out of its fixing on the carb. Hook back in and away you go!
Posted on Jul 07, 2010
How to load new cutting line onto a McCulloch Strimmer TM250
You can probably find a Youtube demonstration video.
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
User manuals McCulloch Service
I trust this information proves beneficial.
Jul 16, 2014 | McCulloch 41201-33 Line Head, Models...
Mcculloch petrol strimmer
Agnes take of the cutting head again and see if it runs at full speed without it. If it does you have either put the head on too tight or it's the wrong head.
May 11, 2014 | Garden
Mcculloch 210 strimmer lost power now wont start for more than afew seconds
remove the muffler and run it the mufflers plug up and restrick the exhaust some mufflers you can open and clean the screen
Sep 14, 2012 | Garden
Petrol strimmer,, spark at plug,, petrol & 2
I have a flymo 430 petrol strimmer and cannot start it. ive cleaned the filter, put in new plug it went first time and then stopped and wont start again the plug seems to get wet all the time any ideas
Jul 03, 2011 | McCulloch Heavy Machinery
Mcculoch mt 300mcculoch petrol strimmer carb two adjustable screw bolts ones for petrol, ones petrol & air mixture hich one does which
Actually both screws are for petrol mix. The screw closest to the engine is the Lo side. Lo side jet provides petrol at idle and during the ramp up to speed. Hi side jet (closest to air filter) only effects the mix at high speed.
From McCulloch, these were set at 1 1/4 turns out.
Sep 16, 2010 | Yard Machines Garden
Mcculloch t 240 petrol will not start
If your petrol has been sitting in the machine for a long time then yes it is your petrol. Mix a new batch usually you cannot let that sit around for more than 30 days, I always try to use fresh mixes, usually that means making smaller batches unless you use your trimmer quite a bit, most people do not though and that's when problems arise.
Jul 04, 2010 | Garden
Hi there,i have a mcculloch tm210 petrol strimmer and the problem is that it will not start,i have noticed that the fuel primer bubble dose not come back out.please can you advise.
clogged fuel line or carberator. my weedeater did this at the first of the season. i took off both lines going to the gas tank and blew on each line separately while holding throttle open on carberator. i felt the clog go thru and put back together, poured a little gas in intake and it started right up and the primer worked right. good luck
Jul 03, 2010 | Garden
Mcculloch strimmer/brush cutter - cuts out when throttle opened
Hi sounds like it could need a diaphram kit in the carby if it has mixture screws one markedl for low speed and one marked h for high speed you can try winding out the low speed screw a bit but if that does not work it will definatly need a kit.
Jul 25, 2009 | Garden
Garden Logo
630 people viewed this question
Top McCulloch Garden Experts
Jim Parker
Jim Parker
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
