Question about HP OfficeJet 6110 All-In-One InkJet Printer
The orange light keeps flashing, screen saying "Remove and Check Cartridge" even though I have checked and changed the cartridges a few times.
  • HP Master
  • 4,737 Answers
This is generally caused by cartridge, make sure the cartridge's connectors (interfaces) are cleaned and not ink or dust stuck on it. for further reference, you can see this http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=125&prodSeriesId=1845551&prodTypeId=18972&objectID=c00818561 Good luck..
Posted on May 15, 2010
Green light flashes, will not print. Checked all
Hi can gave you the truble codes
  • Light Orange - 2 beeps: Remove any paper jammed
  • Light Orange - 3 beeps: Remove any paper jammed
  • Light Orange - 4 beeps: Add Ink
  • Light Orange - 5 beeps: Re-install cartridge or replace it
  • Light Orange - 6 beeps: Re-install cartridge or replace it
  • Light Orange - 7 beeps: Re-install cartridge or replace it
  • Light Orange - 8 beeps: Waste is almost full
  • Flash 1 x Orange - 10 beeps (error code 6100): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 2 x Orange - 10 beeps (error code 6300): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 3 x Orange - 10 beeps (error code 6800): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 4 x Orange - 10 beeps (error code 5100): Make sure nothing is blocking the cartridge movement, if not requires service.
  • Flash 5 x Orange - 10 beeps (error code 5400): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 6 x Orange - 10 beeps (error code 5B00): Waste full (make a reset)
  • Flash 7 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 8 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 9 x Orange - 10 beeps (error code 5600): Replace the BJ Cartridge(Printhead) or reinstall it
  • Feb 01, 2010 | Canon BJC 4400 InkJet Printer
    Orange cartridge keeps flashing after cartridge
    Are you using a factory new HP ink cartridge?
    If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
    They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
    Also take a moment and make sure that all of the protective tape coverings have been removed from the cartridge.
    Don
    Oct 22, 2009 | HP Deskjet 6980 InkJet Photo Printer
    I replaced the black ink and it keeps saying replace ink cartridge. I actually went ahead and changed the color as well even though it did not ask and it keeps saying replace cartridge. HELP! I am a...
    Did you replace the ink cartridge with a new one, or did you refill an old one.
    Some printers have a memory and can tell which ink cartridge is in them. This prevents them from easily being fooled into printing with refilled cartridges.
    Another option is that you changed the ink cartridge without following the specific guidelines for replacement e.g. To replace the ink cartridge, select replace ink cartridge from the main menu, then open the printer panel when the light flashes X number of times.
    You might also try unplugging the printer for a couple of minutes the reset it.
    Oct 15, 2009 | Office Equipment & Supplies
    Put new cartridge in but error light keeps coming on even after reboot how do i fix this?
    Remove the cartridge and put it in again.
    If it has a reset button, push that.
    If you have "refilled" your cartridge the answers will be different. Did you?
    Sep 25, 2009 | Canon Pixma iP2600 Photo InkJet Printer
    Printer keeps saying remove and check cartridge
    http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01091133&cc=us&lc=en&dlc=en&product=1141647
    >copy and paste this on your browser and follow the steps and see if this will resolve your issue
    Aug 05, 2009 | HP Photosmart C4180 All-In-One InkJet...
    The orange light flashes even though I have changed the colour cartridge, The printer will not print
    change the catr insecting unit and the cable together for it to work well. that the problem
    May 23, 2009 | HP DeskJet 940c InkJet Printer
    Hp 845c orange light keeps flashing
    When the orange light is flashing, either paper jam or ink problem is happening.Try unloaging & reloading the stack of paper in the main tray. Remove & reinsert ink cartridges in the printer. You may also clean the contacts of the cartridge and inside the product.
    Mar 09, 2009 | HP DeskJet 845c Printer
    Problem on a canon 3100
    The Power Light Flashes Orange - Error Codes When an error occurs, the power light flashes orange. The number of orange flashes followed by a long green flash indicates the cause of the problem.
    Two orange flashes: Out of paper, paper jam, or paper feed error
    If no paper is loaded in the auto sheet feeder, or if the paper is not loaded correctly, set the paper correctly and press the Resume button on the printer to continue printing.
    Three orange flashes: Paper jam
    If paper has jammed in the printer, carefully remove the jam and press the Resume button to continue printing.
    Four orange flashes: A tank inside the BJ cartridge (print head) is out of ink
    Replace the empty BJ tank and press the Resume button to continue printing.
    Five orange flashes: BJ cartridge is not installed properly
    Remove and reseat the cartridge correctly. Make sure the orange protective cap and tape have been removed. Make sure the blue locking lever is locked down securely.
    Six orange flashes: BJ cartridge (printhead) is not installed
    Seven orange flashes: BJ cartridge (printhead) is defective
    Remove the BJ cartridge and check that the contacts on the cartridge and cartridge holder are clean. Make sure the orange protective cap and tape have been removed and reinstall the cartridge. If the error occurs again after you resume operation, you may need to replace the BJ cartridge.
    Eight orange flashes: Waste ink absorber almost full
    The printer has a built-in waste ink absorber to hold the ink that is consumed during print head cleaning. This error indicates that the waste ink absorber is nearly full. Press the Resume button to skip the error so you can continue printing.
    The POWER light flashes orange and green alternately: Service error
    A service error means the printer requires the attention of a qualified technician. Count the number of flashes. (You may be asked this information.)
    Feb 02, 2009 | Canon PIXMA MP150 All-In-One InkJet...
    INK CARTRIDGES
    turn off printer...check the bottom of the printer cartridge for any blockage or film
    Apr 23, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
    Printing Dillema
    Flashing resume light also can mean:
    1. cartridge is missing or an incorrect print cartridge is installed
    2. cartridge is out of ink
    3. dirty cartridge contacts
    4. paper jammed
    Check are cartridges firmly snapped into place and not empty. Use water to wash copper on cartridges if contacts are dirty.
    Oct 30, 2006 | HP DeskJet 690c plus InkJet Printer
    HP OfficeJet 6110 All-In-One InkJet Printer Logo
    119 people viewed this question
    mukhtar21 shaikh
    mukhtar21 shaikh
