Question about Pride Jazzy 1103 Ultra Standard Power Chair
Jazzy 1103 will not charge. Power cord and electrical outlet verified good. Plug in chair for charge, the ammeter indicator bar remains at 0, even after several minutes. If chair is powered on (while plugged in), the chair will operate as if not plugged in. The batteries are a few years old. Charger? Batteries? Other? Thanks.
    Problem Solver:
  • 11 Answers
The battery charger is only made to last 1 year if you
re lucky. They are all made in China very cheaply and some only last a matter of months. If you are on Medicare they will replace the charger if necessary after a year. Good luck, hope this helps
Posted on May 16, 2010
Jazzy charge light on chager does not come on
The red light indicates that power to the off-board charger is on. Try a different ac wall outlet that you know works. If a red or green light does not come on you will need to replace charger. Also check the condition of your batteries - dead batteries will not charge.
Mar 22, 2013 | Pride Jazzy 1103 Ultra Standard Power...
The battery light flashes and the chair wont go.
Sounds like it might be time to change the batteries. Even if batteries are charged correctly they eventually lose power with use and need to be changed. Here is a link to the battery needed for the Jazzy 1103 Ultra http://www.replacementupsbattery.com/UB12350-NB.html
Oct 31, 2010 | Pride Jazzy 1103 Ultra Standard Power...
Jassy 1103, will not start charging the battery.\r...
the 1103 uses an onboard charger. Charger's life span is about 3 years; some fail in 6 months, some in 6 years keep in mind. You can charge the 1103 using an offboard charger which are available for about $50.00 on Ebay. Search for electric wheelchair charger. You want one that has a 4 to 6 amp rating.
The offboard charger has a 3-prong connector on one end and the other plugs into a grounded wall outlet. Plug the charger into an outlet and the three prong connector into the female three prong connector located at the bottom front of the joystick. Give it a good overnight charge and it should be back up to snuff in the morning.
May 21, 2010 | Pride Jazzy 1103 Ultra Standard Power...
Chair no longer charges, no flashing or blinking, lights,
The number of lights that are blinking indicate what the problem is. Visit this site to locate the type on controller on your power chair and you will be able to see that the blinking lights mean:
http://www.pgdt.com/scenter/diagnostics/diagvsi.html
Try to reset your manual brake release as this is a common problem.
If you continue to have a problem, contact your manufacturer or dealer for service. If your insurance purchased they power chair for you, they may also cover the cost of repairs.
May 07, 2010 | Pride Jazzy 1103 Ultra Standard Power...
How do you charge the jazzy 1103? It is on 0 on the back. Plugged it in overnight with chair on. Went from 4 to 0. Help we don't want to be stranded.
The meter on the back is an amp meter and tells you how many amps are entering the batteries when charging. Many people get confused with this and think that the needle should rise as the batteries become more charged. This is in fact incorrect and the opposite should happen. So just to sumarise, when you plug the charger in when the batteries have been used, the needle should be above 0 (maybe, 3-5 depending on how discharged the batteries are) and as the batteries become charged, the needle should gradually drop down, and should be on 0 when they are fully charged. The batteries should not be taken off charge untill the needle is on 0. Hope that has helped.
Apr 15, 2010 | Pride Jazzy 1103 Ultra Indoor Power...
Jazzy 1103 Ultra batteies are good but?
If a fuse is blown, no lights will come on. One red light is an indication that the batteries are too low to operate the chair. Try using a different charger on it. The 1103 has an on-board charger, but you can charge the chair using an off-board charger that you can acquire on ebay for about $50.00 or so. Make sure it has a 3-pin XLR connector (most do), that will match with the 3-pin female post located on your joystick. Plug it in and see if that doesn't power up the batts. I just did a search on ebay and found these. http://shop.ebay.com/?_from=R40&_trksid=p2681.m38.l1313&_nkw=wheelchair+charger&_sacat=See-All-Categories
Dec 29, 2009 | Pride Jazzy 1103 Ultra Standard Power...
Replacing battteries in Jazzy 1103 power chair
Here's a quick link to the owners manual for the 1103 that will show you how to replace the batteries on your chair.
http://www.pridemobility.com/pdf/Owners_Manuals/US_Jazzy/US_1103_Ultra_om.pdf
Oct 22, 2009 | Pride Jazzy 1103 Ultra Indoor Power...
Not Charging
Probably the charger has gone bad. You can look on Pridemobility.com for a dealer in your area.
Apr 14, 2009 | Pride Jazzy 1103 Ultra Standard Power...
Pride Jazzy 1103 Ultra Standard Power Chair  Logo
496 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
