Question about Audio Technica ATW-R14 DIVERSITY RECEIVER (57R) ATWR1457R Microphone
How to change the frequency of ATW-R14 receiver and ATW-T52
Use ATW-R14 receiver and ATW-T52 microphone, they work on 809.475 Mhz. This system worked fine line to 2 months. Now in my seat installed wireless digital television. I have big problems because the receiver frequencies overlap with the frequency of digital television.
Is there any possibility to change the frequency of the receiver and microphone? and how to do this. ''
3 Suggested Answers
  • 5603 Answers
SOURCE: ATW-T52, hissing/crackling.
A common problem that SOME have is due to the foam windscreen inside the metal screen rubbing the diaphram of the mic.
Unscfew the dome screen and make sure the foam is out agaist the scree everywhere.
If the dome has become dented, this is my cure: Temporarily remove the foam sheet inside the dome. Put the dome over the handle of a Crescent wrench (has about the right contour). Pound on the screen with a RUBBER mallet, rotating the screen as it reforms! Good as new! Replace the foam sheet and reassemble!
Posted on Dec 26, 2009
SOURCE: changing frequencies on wirleless microphone
want to change the frequency on an Audio Technica ATW252. How do i go about doing it?
Posted on Mar 01, 2010
Can u take teh antina from atw t51 and put in another atw t51
just opened up a atw-t51 transmitter. (carefully prise apart the two halves of the case with a sharp blade). The aerial is soldered to a terminal post on the circuit board, so anyone competent with a small sodering iron should be easily able to swop the aerials for you.
Dec 08, 2010 | Audio Technica ATW-R14 DIVERSITY RECEIVER...
I purchased 6 receivers of this model, I need to get the mics...Even if I got them, is it posible for them to work, in other other words Can I adjust them to the receivers' frequencies? And if so, would...
Normally the mics and receivers are sold as a unit but replacement mics can be bought separately.
However the ATW-R11 has been discontinued so may now be hard to find.
This model has 20 available frequencies so you should be able to change frequencies okay.
NOTE - you will require a license for these frequencies
Aug 26, 2010 | Audio Technica ATW-R11 Microphone
I have a atw-t52 audio techina wireless mic. And when i turn it on thr crackling begins to come through the speakers and i have to play with the input and output cable and move the base unit around and...
I have the same problem in my ATW T52, in st by its ok (the rf leds show perfect signal) but when i set in on the af level start punch and i hear in the monitor a noise like a heartbeat (pum-pum-pum....) Please any answer for this problem
German
Radio del Sol 96.3 Mhz
Villa de Merlo - San Luis
Argentina
May 20, 2010 | Audio Technica ATW-T52 Professional...
How do we figure out the frequency?
The only way to figure the transmitting frequenty is by using a frequenty counter. For the receiver it's more difficult.
You will need a sweeposcillator which can sweep to 1GHz with a digital read-out.
Good luck,
Gerard Jansen
Feb 04, 2010 | Audio Technica ATW-R14 DIVERSITY RECEIVER...
Dec 20, 2009 | Audio Technica ATW-T52 Professional...
How do I program the frequency of transmission on the mic?
Some of these have a body cover that just unscrews off, and expose a set of rotary channel and group selector that you can turn with a small flat screw driver. Match to the new numbers letters on the receiver. If it is the LED type you just need to hold the ch or grp button down until the display flashes then just toggle through the codes.
Jul 27, 2009 | Audio Technica ATW-T52 Professional...
Change the frequency
hello firstable you need to know at how many ohms is the base unit then in microphone change the impedance transformer to match the low or high frecuency you want......saludos
Nov 20, 2008 | Audio Technica ATW-T52 Microphone
HELP
Audio Technica Part number 235401550, call 330-686-2600. The cost is $21.93, plus shipping
Jul 29, 2008 | Audio Technica ATW-T52 Professional...
Vocals disappear in parts using this mic
It is very common to have the squelch on the receiver set at full or much too high. With the audio output unplugged or at least turned all the way down, and with the transmitter turned off, locate the squelch control - you may need a screwdriver depending on which model of receiver you have. Turn the squelch control counter-clockwise until the TX light turns on, then turn it back up just past the point where it turns back off.
If you turn it all the way down and the TX light doesn't come on, that's okay. If you get blasts of noise occasionally when the transmitter is turned off, then set the squelch a little (only a little) higher until it stops.
Joe
Jul 21, 2008 | Audio Technica ATW-T52 Professional...
960 people viewed this question
Top Audio Technica Audio Players & Recorders Experts
 Grubhead
Grubhead
Greg Cann
Greg Cann
Clif Roberts
Are you an Audio Technica Audio Player and Recorder Expert? Answer questions, earn points and help others
