Question about Orbit Sprinkler System Power Source Transformer #57040
Controller Orbit model 57979 (9 station) will not open valves
Controller goes through sequence ok but valves do not respond. Batteries are ok
red light is flashing
I have an Orbit 9 Station Sprinkler System & the manual watering feature isn't working. I replaced the 2 AA batteries & the fuse in the control box but it still won't come on. Can you help me?
Based on my knowledge of Orbit branded products like yours your timer has failed and you need to replace the unit with another more reliable brand. Orbit has real issues with their designs.
Aug 03, 2016 | Orbit Hardware & Accessories
Why doesn't valve respond?
take out battery and put new one in. I had same problem and this solved my problem
Apr 01, 2016 | Orbit 4 Station Zone 3 Program Sprinkler...
No AC fault in Orbit Sprinkler Timer Model 57896
Call Technical Support at Orbit. The 800 number should be listed in the instructions.
Apr 17, 2014 | Orbit Underground 57896 6 Station In/Out...
Just hooked up (water lines only, no control wiring yet) a 3 station Jar top Manifold. One of the valves is open while the other two are shut. Have taken apart and see not apparent reason for it to be...
Make sure the bleeder is closed or solenoid is tight. Sometimes valves just fail without a obvious reason. Suggest purchasing the same jar top valve and rebuilt it using the new diaphragm, spring, bonnet and solenoid. This should correct the problem.
Apr 13, 2014 | orbit"" 1"" jar top valve"
Model 57882 9 station timer I did set up station 1 where do I begin in order to set up station 3
Question is not clear.
Do you have programming problem with the timer?
Or problem locating sprinkler heads?
Or a sprinkler valve problem?
Add a comment with detailed information.
Sprinkler timer turns ON-and-OFF.
Timer does not advance the sprinkler to next station. The sprinkler valve advances to next station when timer turns OFF.
For example, when timer turns ON, then station 1 starts watering.
Timer turns off, and then sprinkler valve automatically advances to station 2.
Timer turns on again, and station 2 starts watering.
Orbit resources:
http://www.orbitonline.com/support/
http://www.orbitonline.com/lib/media/InstallationGuide.pdf
http://www.irrigationdirect.com/media/manuals/owners-manuals/orbit/Orbit-WaterMaster-57880-Controller-Owners-Manual.pdf
Aug 02, 2011 | Orbit 57882 9 Station Super Dial...
Need orbit irrigation manual for model #57979
How does one connect the Wired Toro Rain Sensor, Model 53769 to the Orbit, Model #57979?
Jun 05, 2010 | MicroBoards Orbit (ORB-4201-01) Burner
Solenoid on one station, sprinklers on another, cant turn both on
the should be a pump or master solenoid connection inside the controller
Apr 12, 2009 | Orbit Hardware & Accessories
Orbit Sprinkler System Power Source Transformer #57040 Logo
302 people viewed this question
Top Orbit Hardware & Accessories Experts
appman67
appman67
 Kenneth
Kenneth
Andrew Taylor
Andrew Taylor
Are you an Orbit Hardware and Accessory Expert? Answer questions, earn points and help others
