Question about Craftsman 20 Hp 42" Deck Lawn Tractor
I have a 20 hp 48 dlt2000 mower wont move after 15 minutes of mow
I have a 20 hp 48'' deck DLT2000. model number 917.272242. it mows bout 15 minutes than it acts like transmission is slipping. i put new drive belt on, checked tranny oil its full but black how do you drain it and will that fix it? -brad
SOURCE: I have a Craftsman DLT2000 20 hp 48 inch lawn
the safety switch is under the frame of your mower look under the frame follow the clutch rod then you will find the switch.
Posted on Aug 29, 2010
wadembly
  • 513 Answers
SOURCE: craftsman DYT 4000, 24 hp 48
there is a fuse in engine compartment that might have blown causing the engine or blades not to start but what probably happened was something got caught in the blades check under the deck & see if there is & also try spinning blades by hand & see what happens
Posted on Jun 14, 2009
  • 44 Answers
SOURCE: 48 inch deck problems
a lot of problems here.try this.[grass buildup]. usually cause by damp grass or blades not going fast enough to throw into box.engine cutout is then caused by grass jamming blade[s]. backfire is usually too much choke or wrong petrol/air mixture.re bent grass.try cutting driving in reverse[if strip is wide cos of back tyre then blade is uneven.]
Posted on Jul 21, 2009
mowerman1857
  • 389 Answers
SOURCE: Smoking Craftsman Riding Mower
1st thing, check your dipstick up inside the cap part of it and make sure the O'ring is there and in good condition.
2nd, make certain when you put it back on that you get it on straight and firmly seated. They will only seat one way properly the other way creates a leak into the crankcase and causes oil consumption and smoking. You should be able to tell if it has been improperly installed by an excessive amount of oily dirt accumulated around the threaded area of the cap
Posted on Sep 15, 2009
SOURCE: Stanley mower model# 425605X692
need a new hydrostat trans. i have the same problem
Posted on Apr 23, 2010
Need the measurement of a deck belt for a
This machine takes 2 Deck Belts the first #47 is Model# 180808 which is 89 1/4in.L x 5/8in.W
The second is #48 Model# A-174368 that is 89 1/2in.L x 5/8in.W, 21599_65x65.jpg
Oct 16, 2014 | Garden
Craftsman dlt2000 20 hp kohler runs great until i try to engage blades pull up on the switch to engage and motor bogs and stalls
Now is a great time to remove the deck and sharpen the blades! In the process, you will find your problem. Look for clogs, seized bearings, freely rotating belts, etc... The problem is in the deck or drive belt. Hope this helps!
Sep 26, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
CRAFTSMAN 26 HP 48'' DLT2000 MOWER ELECTIC PTO CLUTCH SEIZED UNPLUGGED BUT BLADES CONTINUE TO TURN. CAN IT BE REPAIR OR MUST IT BE REPLACED?
I would say replaced to ensure correct opperation.Thanks for asking and I hope this helps out.Please leave me 4 thumbs up.
Jul 20, 2010 | Craftsman 26 Hp 54" Deck Yard Tractor
Swisher 60 deck belt breaks after mowing about 15 minutes.
Even though the routing is correct, have you checked that every spindle and idler pulley turns freely? These bearings can freeze up or bind because debris builds up in them. Also, if the bushings on the idler pulleys can wear, causing them to misalign. Keep checking. Also - is the belt snapping clean, or do you see a burnt, worn spot?
May 27, 2010 | Swisher 60" 26 Hp Zero Turn Radius Riding...
Need deck belt diagram for huskvarna yth2242t lawn tractor
Go to... http://www.searspartsdirect.com/partsdirect/index.action and enter your model number, Then scroll down the subcomponent list to Mowing Deck. There ya are.....
Jun 13, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
LTX1000 42" 18HP Kohler - Blowing fuse after 2-4 min mowing.
sounds as though you are on the right track
but be sure to check the wiring directly from the electric clutch on the front of the motor back to the switch
a wire could be pinched in the frame and shorting out intermittingly
look around and find those wires and move them around and look for chaffing and tightness
and what you could also do is to unhook the clutch at the connection to it at the front of the motor and engage switch and ride around and see if fuse blows and if not you may have an electric clutch issue
Jun 07, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 20 Hp 42" Deck Lawn Tractor Logo
94 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
