Question about Intermatic Malibu 300W Power Pack Transformer ML300RTW
I have a ML100T model power pack with red and blackclips. The instructions have beenlost and I need to know if the red or black is the on clip?
  • 565 Answers
RED is the ON, BLACK is OFF.
Posted on May 15, 2010
Testimonial: "Good answer and quick response. "
Bought Malibu model 8310-2921-08, it doesn't have the power pack instruction sheet, so I really don't know how to use the power pack, please help.
Malibu 8300 appears to be a low voltage lighting fixture.
You might have the digital power pack???
Copy following link for operation, operation tips, power pack troubleshoot, etc.
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html#digital
If this is not your timer, then add a comment and describe timer in detail.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Sep 04, 2012 | Hardware & Accessories
Tip
Olympus E-10/20
I have been on love with my Olympus e-20n since the day I bought it. Yes, it's only 5 mega-pixel but the SLR design and full manual functions out weigh the limited resolution. I was very disappointed when I tried to buy a replacement high capacity battery and Lithium Polymer 8400ah battery was not only discontinued but totally not available (except for some used ones on Ebay and I'm just not brave enough to buy a used battery)
So crafting a replacement became my Memorial Day Weekend project. One quick trip to Fry's Electronics later and I had the solution. A 6-cell AA battery holder, 6ea AA NiMH 2600ah rechangeables and a 9-volt battery clip with pig tail is all I needed.
Crack open the external battery add-on (looks like a power winder on a 35mm SLR) 4-screws on the botton, one inside the battery well and 2 under the rubber hand grip. Locate the battery connector and un-screw the RED and BLACK prime power leads from each side. Cover the connector with electric tape or an insulated cover, your done with it, forever.
Solder the pigtail 9-volt battery clip to the RED and BLACK leads (red to red and black to black, duh!). Extend the 9v battery clip outside the case and re-assemble the case.
The 6 AA-cell battery holder will fit nicely into the battery door cup and if you pack the vacant space in the battery well with sponge or an old gym sock the battery will not slide around.
Fill the AA battery holder with the rechargeable batteries you have freshly re-charged and hook up the 9v clip. Thats it, new life for the my old companion.
on May 31, 2010 | Cameras
Need to set the timer properly. No instructions to follow. Want lights to come on at 6PM and off at 6AM. the timer has red and black pegs on the timer, HEL:P
Experiment with the timer.
Hook up the lights and timer. And read resource link below.
Put the trippers on the dial. Put red at 6pm and black at 6am.
Then manually rotate the dial two revolutions.
Turn the override knob to different setting, and then manually rotate the dial two revolutions.
Watch what the lights do as you rotate timer dial.
Then rotate dial two revolutions until current time lines up with stationary arrowhead located on inner dial.
The clock motor located inside timer rotates the dial, and trippers move small switch that turns lights on-and-off.
More resources with important tips for power pack:
http://waterheatertimer.org/How-to-set-timers.html
Sep 27, 2011 | Malibu ML88TL 88Watt Low Voltage Power...
Have an ml60t low voltage transformer timer purchased with house and now instruction manual. neet instructions, esp how to set it with pics
I don't know of a website that has picture-steps for setting Intermatic/Malibu power pack.
The manual has a few illustrations for the do-it-yourselfer.
You put black and red put trippers on the dial, connect wires to A and B terminals, connect lights to wire, plug power pack into outlet. To check operation, listen for power pack making humming sound, manually rotate dial two times and then line up current time with arrowhead located on inner dial, watch if dial is rotating and keeping good time, rotate manual override knob and see what happens.
ML60 power pack does not show on Intermatic sell sheet.
http://waterheatertimer.org/ML-power-pack-sell-sheet.pdf
Manuals show on following page: click on model number for Instruction manuals in English Spanish French
http://www.intermatic.com/products/professional%20lighting/low%20voltage%20landscape%20products/power%20packs.aspx
Open following link for troubleshoot, warranty, parts, tips etc:
Add a comment for more help.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jun 06, 2011 | Hardware & Accessories
How do you set lighting to turn on and off throughout the day?
You posted under Malibu power pack.
If you have analog dial that rotates as time passes, then setting on-off times is accomplished by using black and red tripper.
Usually the timer comes with 2 red ON trippers and 2 black OFF trippers.
Place trippers on outer edge of dial and then set timer according to instruction manual.
If you need more trippers, they can be ordered
http://waterheatertimer.org/Intermatic-trippers-and-parts.html
Open following link if you need instruction manuals or troubleshoot steps for setting up power pack.
Add a comment with exact model number if you want more detailed instructions, and add your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
Apr 05, 2011 | Malibu ML200RT - Low Voltage Power Pack...
I need instructions for setting the timer
Malibu product manuals
http://www.malibulights.com/customer_service/owners_manuals.aspx
Manual for 300 Watt power pack
http://malibulights.com/docs/pdf/8100-9300-01.pdf
Read cautions
Tips
300 Watt power pack requires sum of bulbs to equal 300 Watts
If you use 10 - 20 watt bulbs that is only 200 Watts so you need 200 Watt power pack
Replace burnt out bulbs immediately or other bulbs will burn out and shorten life of power pack
When working on bulbs, unplug power pack so it does not shorten life of power pack
Set Malibu Timer:
Red trippers are ON
Black trippers are OFF
Place trippers on dial at ON OFF times/ AM and PM
Set current time of day:
Plug in power pack
Trippers are installed
Rotate dial counter-clockwise to current time, say 9 am
Rotate dial 2 more revolutions and then return to current time
That's it
Oct 12, 2010 | Intermatic Malibu 300W Power Pack...
Need red plastic timer clips for my ML600TW. Transformer works, but only have one red movable clip for setting a time. Timer may be broken, but would like to try installing the on/off clips first. Any idea...
Open following link for ML power pack trippers, plus troubleshoot, plus tips to keep power pack from burning out, and warranty:
Upvote the help.
Oct 04, 2010 | Malibu ML600TW - Low Voltage Power Pack -...
How do I set the timer for the malibupower pack
set the dial to the corect time by turning the dial. remove the clips by pulling straight out. reinsert clips on the desired times for on and off red on black off
May 24, 2010 | Intermatic & Malibu& 300 Watt Power/Pack...
CANON PIXMA MP510 WILL NOT POWER ON
I had a similar problem. What worked for me was to remove the power pack, which is secured by two clips. Slide a knife or similar to release the power pack. It will slide out to reveal a mini-plug with five red wires. Disconnect this.
This where it gets a bit uncertain. I plugged in the power pack and put a meter across the outputs. They seemed to be working (ie I was getting voltage). I had a quick look at the indide of the MP510 and decided there was nothing further I could do. I then reassembled everything and, just out of curiosity, pressed the power button again. And it came back to life!
I suspect that in your and my cases, the MP510 had "crashed" and I performed a hard reset by removing and then reconnecting the power pack. But who knows? Best of luck
Nov 07, 2008 | Canon PIXMA MP510 All-In-One InkJet...
Problem with zapp seat
There are two blackclips on the top inside handles pull these gently to loosen the seat cover. Then repeat on the bottom. You will also have to unbutton the back of the seat (there are two black straps) then half fold the buggy and pull the seat towards you. Its a bit niggly and frustrating but does eventually come off.
Jul 07, 2008 | Quinny ZAPP Stroller
Intermatic Malibu 300W Power Pack Transformer ML300RTW Logo
266 people viewed this question
Top Intermatic Hardware & Accessories Experts
Craig Butler
Craig Butler
Gene Haynes
Jay Finke
Jay Finke
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
