Question about Viking DDBB363 Bottom Freezer Refrigerator
Viking Condensate Freezes
I have been going around and around with this problem.
The evaporator is clear, it's defrosted, but the condensate doesn't drain, and thus freezes.
I have replaced the defrost terminator.
Two weeks ago I removed all the frozen condensate, wrapped a wire around the 'calrod', and routed the wire is into the condensate drain. Today, I see ice on the floor of the freezer.
What else could it be? Does the calrod defrost the evaporator? If so it must be working. My only other thought is that the evaporator defrosts by hot gas?
The refrigerator is 3 yrs old. It just started doing this in September/October.
  • Doug_Mpls Apr 02, 2008
    Well I blew it out with 60lbs of compressed air last time. Also shined a flashlight, and poured a cup or two of hot water.
    I called the tech for Viking, and sent him a couple of pictures. I'll let you know what happens.
  • Virginia Vik May 19, 2008
    I have the exact same problem.. Have had techs out four times to look at it... Could it be that it is just not defrosting at all? I am thinking of ritually turning the machine off over night (emptying the freezer so I can leave the door open. Viking sucks. It is definitely not a problem with the drain because when I defrost it out, I run water through the drain and everything is fine.
  • 447 Answers
Most likely the drain is plugged try using some low pressure compressed air to blow out the tube, yes the heater is what defrosts, no hot gas, other than that the icemaker fill tube could be leaking, freezing the drain.
Posted on Mar 31, 2008
We had the same problem... we emptied the freezer, turned off the power and left a blow dryer running in the freezer side for about 45 min. the ice line had been frozen, and there was a huge amount of frost buildup. Everything defrosted, drained, and then we refilled and turned it back on. It's working fine now.
Posted on Dec 06, 2008
Love this air conditioner but it doesn't drip any water out the back or anywhere. I can hear it sloshing around when it shuts off. Is this okay? I have it slanted properly and I read somewhere not...
Hello, most window units to not drain the condensate, the fan blade picks up the condensate and pushes it on the condenser, since the condenser is hot it evaporates the condensate. That is the sloshing sound you are hearing and is normal when humidity is high.
Jun 05, 2011 | Frigidaire FRA065AT7 Wall/Window Air...
Defrost condensate not draining
Make sure the water goes down the drain quickly. If the drain is a little clogged it may not be draining fast enough, letting it freeze before it drains. I use compressed air at a low psi to clear the drain from the freezer compartment. Does the refrig have an ice maker?? If the water is spilling over the fill tube behind the freezer panel it will also ice over the drain. Also sometimes drains just ice up for no apparent reason. I deice them and then they work fine. You can also take a piece of romex wire (the solid copper strand type) use the ground wire (bare copper) or strip the insulation off the black or white wires and loop the wire over the defrost heater and down into the drain hole. This will help any ice that builds up around the drain to melt in the defrost cycles. Let me know how it turns out.
Nov 19, 2007 | Viking DDBB363 Bottom Freezer Refrigerator
Winndscreen does not clear unless have air conditioner on
Blowing air across the windscreen does not necessarily clear away condensate from the inside. Water vapor condenses on any cool surface, and humid air blowing across a cool windscreen will result in more condensate on the windscreen. Often the air that blows across the windscreen is just humid AND heated, and doesn't solve the problem.
The air conditioner system performs two functions. Not only does it cool the air, it also extracts moisture, resulting in dryer air. Once the dried air is re-heated in the defroster system, it should allow the moisture on the windscreen to evaporate.
In other words, it sounds as though the defroster system is functioning properly.
Feb 06, 2011 | 1998 Volvo S70
Refrigerator is not cold but motor is running.
Hello and Welcome to Fixya,
This is one of the most common problems in most of the refrigeration appliances. What's going on here is that the condensate drain hole in the freezer gets plugged with ice. Once this happens, all the frost melted off the evaporator during subsequent defrost cycles can no longer drain and so spreads out on the freezer and dribbles down and also chokes other components. Here are the instructions that you need to follow inorder to get rid of the problem:
  • Unplug the refrigerator and pull everything outta the freezer, and I mean everything.
  • Remove the bottom panel inside the freezer so you can see the condensate trough in the back of the freezer.
  • Notice that the condensate trough is filled with ice- all that has to be cleared out.
  • Take it easy back there, delicate parts are exposed- don't start hacking at it with an ice pick because there are chances that you'll just end up puncturing the evaporator and you'll turn a simple, inexpensive repair into a majorly expensive one.
  • Use hot water to drain all the frosted ice that is visible.
  • Re-place all the units removed during the process.
  • Once all the ice is cleared away and the condensate drain opening is cleared, you are done.
Best of Luck,
Please do rate my solution, If found helpful.
Regards.
Dec 21, 2010 | Viking DDBB363 Bottom Freezer Refrigerator
THE FREEZER IS BLOWING WARM AIR
Best of Luck,
Regards.
Nov 20, 2010 | Roper RT18HDXKQ Top Freezer Refrigerator
My Jenn-air refridgerator freezer section leaks water and builds up on bottom of freezer, defrosts then leaks out
sounds like you have a clogged defrost drain. when the unit self defrosts, the meltwater from the evaporator is supposed to go down a drain under evaporator, to a condensate pan underneath. when this drain gets clogged at any point, the water then drips into the freezer floor, freezes, eventually over fills the floor, and leaks onto kitchen floor. Do not try to snake out the drain, as it is plastic and usually not permanently attached, snaking can damage or dislodge the tubing, making problems worse. If you have a compressor, you can direct some compressed air into the drain to clear out any obstructions. Again, use caution against too much pressure, to avoid dislodging tube. Any reliable refrigerator repair service shouldnt charge much more than $100 to resolve this issue.
Mar 28, 2010 | Jenn-Air JCD2389G Side by Side...
The freezer frosts and ices up so bad it plugs the holes that cool the refrigerator. Then this morning there was a puddle of water in front of it
This is one of the most common problems in most of the refrigeration appliances. What’s going on here is that the condensate drain hole in the freezer gets plugged with ice. Once this happens, all the frost melted off the evaporator during subsequent defrost cycles can no longer drain and so spreads out on the freezer and dribbles down and also chokes other components. Here are the instructions that you need to follow inorder to get rid of the problem:
  • Notice that the condensate trough is filled with ice– all that has to be cleared out.
  • Take it easy back there, delicate parts are exposed– don’t start hacking at it with an ice pick because there are chances that you’ll just end up puncturing the evaporator and you’ll turn a simple, inexpensive repair into a majorly expensive one.
Best of Luck,
Regards.
Jan 25, 2010 | Haier HTQ21JAAWW Top Freezer Refrigerator
I have condensation in the bottom part of the fridge say the ceiling part
I believe your defrost condensate drain has a blockage of ice and will need to be defrosted and clean the condensate line from the freezer to the condensate collection plate below your refrigerator. Most times the blockage begins slowly until the opening of the drain hole under the evaporator freezes itself shut. Below is a link to some solutions I have collected over a period of time. Also has a short movie that makes the repair look simpler. There are many reasons for this happening for example water leaking from a water supply line for the dispenser or ice maker, a crack in the defrost pan, water leaking inside and draining through the refrigerator cabinet, but most are caused by a defrost drain line blockage. Below is a link that may be helpful so try to take it all in and use the parts that most refer to your specific problem, Thanks Sea Breeze
click on link below
Sep 23, 2009 | Howard-McCray Refrigerators
Viking DDBB363 Bottom Freezer Refrigerator Logo
339 people viewed this question
Top Viking Refrigerators Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Viking Refrigerator Expert? Answer questions, earn points and help others
