Question about Nokia 3120 Cellular Phone
I had forgotten my sd mrmory card password,
I had forgotten my sd mrmory card password, please help me to unlck with deleting the file in the memory card
  • 1,557 Answers
Check my postings on mobile phone unlock codes
Posted on May 15, 2010
Forgotten memory card password
final thing is format memorry card and try to recovery files
Nov 19, 2013 | Skque 8GB MicroSDHC / MicroSD / Micro SD...
Tip
Unlocking SD Memory Card of Nokia 2690
Nokia 2690 is a mobile phone made by Nokia Corporation. Nokia 2690 have 25 MB internal memory, microSD memory card slot with hot swapable. Many user faces problem in unlocking the password of SD memory card. As the SD memory card contains valuable data like songs,images, files, etc. To protect the SD memory card from the unauthorize use, its is protected by secure password or lock code. Some time the password gets forgotten or it gets blocked technically resulting in faliure to unlock the SD memory card. To unlock the SD memory card password you need the utility called FE Explorer. After installing the FE Explorer in the phone, insert the card in to the phone but do not access it. After running the FE Explorer open the path C:system. There is a file called mmcstore. Rename the mmcstore file to mmcstore.txt. Transfer the mmcstore.txt to the pc or laptop and open it in notepad. After opening the file there is a password to unlock the SD memory card of Nokia 2690. Using FE Explorer we can remove the password of other micro SD memory card like Kingston, SanDisk, Verbatim.
Please download the software from the link provided below :
http://fexplorer.en.softonic.com/download/25347
Also visit the help link provided below :
http://www.mobiclue.com/recover-memory-card-password-from.html
on Jun 14, 2011 | SanDisk 2GB microSD Memory Card
My memory card as been locked it is not opening and asking the password
Micro Secure Digital memory cards, or Micro SD cards, provide storage for a variety of different kinds of devices, including mobile phones, PDAs and cameras.
They can be protected by passwords so that the information that you have saved on it is secure. Sometimes, the password can be forgotten or lost.
Recovering your password is easily done with your computer and SD card reader on your computer.
Place the micro SD card into your card reader on your computer.
Right-click your "Start" button and then "Explore".
Find the micro SD card, it will be listed as a removable drive.
Click on the micro SD card and the files will show on the right-hand side.
Find the file that says " MMCSTORE" and then select "Copy."
Right-click on your desktop and then click "Paste."
This will move the MMCSTORE file to the desktop so that you can get access to edit it.
Right-click on the MMCSTORE and then click on "Open With." Open the file with Notepad.
Read the text to find the password. It will be in plain text.
Remove the SD card from the computer and place it into the device for which it is used as storage. Turn on the device.
When it prompts you for the password, enter it.
or
Delete a MicroSD Card Password
Some MicroSD cards are password protected, preventing you from using the card without the password.
You can circumvent this restriction by formatting the card, which eliminates the password requirement.
Insert the MicroSD card in your MicroSD card adapter and insert the adapter in the SD slot on your computer.
Right-click "Start" and select "Explore".
Click "Computer" and right-click the drive letter of the MicroSD card.
Select "Format", select the "FAT32" file system from the drop-down menu and press "Enter" to reformat the card.
Jan 24, 2012 | Kingston 1 GB microSD Card with USB 20...
I have locked my memory card and forgotten the password. Format card also requires password and my laptop cannot read it. Please help.
All you have to do is:
Step One:
To save data, use EASEUS Data Recovery software (free version - 1GB of data recovery). how:
1. Download and install EASEUS Data Recovery
2. Choose Complete Recovery - Next
3. Choose the drive micro SD - Next
4. Save the data to the hard disk (max. 1GB)
5. Because of your micro SD 2GB, repeat the process of recovery (repeat step 2, 3, 4)
After all data is secure, do the process of removing the micro SD password
Step Two:
The first alternative - use the software HP Drive Key Boot Utility
1. Download and install the software HP Drive Key Boot Utility
2. Then, double click the file cp006049.exe
3. If you are using Win XP, double click the file cp006049.exe - select Install.
4. If you are using Win Vista or Seven, double click the file cp006049.exe - select extrack.
5. Then, open the program "HP Drive Key Boot Utility or hpdkbu.exe" - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Finish.
6. Remove the micro SD from the USB port, then insert it again.
7. Quick format micro SD (FAT file system)
8. Restore all data, to the micro SD.
The second alternative - use software HDD Low Level Format Tool
1. Download and install HDD Low Level Format Tool
2. Select micro SD - Continue
3. Click S.M.A.R.T - click Get Smart Attributes
4. Click LOW LEVEL FORMAT - click Format this device
5. Wait until the process is complete - press OK
I hope this information helps. Thank you for using FixYa!
Oct 11, 2011 | SanDisk 2GB microSD Memory Card
I have forgotten my password of Memory card of sandisk SD 2GB . i need the secret code if there is any . so please help me .
hi de
there are 2 solutions
1)insert the memory card in that phone in wich you locked the memory card,then install y browser in the mobile,open c drive in y browser go to sys folder and then go to bin folder,there you will see a file named mmc.dat open it with notepad,you will find your mmc password
2)insert the mmc in a s60v5 mobile(5233,5800,5235)and format the mmc,this will delete the password and your mmc will be unlocked
Mar 27, 2011 | Nokia 6303 Cell Phone
To clear sd memory card password
i cant to delete files from my memory card
Mar 20, 2010 | SanDisk 2GB microSD Memory Card
How to delete my memory card password in Nokia 3110 .It is 256mb
format the memory card. passwords are dangerous when forgotten. You loose all that you wanted to protect. format it either in the phone or on a PC.
Aug 05, 2009 | Nokia 3110 Cellular Phone
Unlock 1 GB micro sd memory card of Kingston Made
I hav a kingston 1gb micro sd card i have forgotten password.plz. help how to unlock the card?
Jun 29, 2008 | Nokia 6300 Cellular Phone
Nokia 3120 Cellular Phone Logo
71 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
