Question about Kitchen Ranges
Knob no longer controls burner
With the dual burner on this range, the burner is working independently of the knob position. I try to turn on the burner and nothing happens or I try to only turn on the smaller burner and both burners come on. Now, I have the knob in the off position and the smaller burner keeps cycling on and off. I have small kids nad it is scary to think the stove may not be off when it says it is-
thanks- Lisa
  • 25 Answers
Dear Lisa
think about your kids and seek a professional in ur area to fix the prob immediately you never know wat can hpen
Posted on Mar 30, 2008
I have KitcheAid KERS 807, electric stove/oven range. Left lower part of ceramic stove top that has single/dual heater sizes is malfunctioning. Single one is still working but from recent dual does not.I...
Either the knob has gone out or the burner element. I would test the knob first to see if there is current when turned to the large zone. If the knob is working, next would be to test the burner to see if the outer ring has burned out. I would guess more likely the control has gone out. Burners have less failure (typically).
Apr 14, 2014 | KitchenAid KERS807SSS Electric Kitchen...
KitchenAid gas stove main burner igniter does not work when the control knob is turned to the ignite position; however when any one of the other burners control knob is turned to the ignite position, the...
Hi Cecchung,
I think I know it.
Modern cookers have semi automatic ignition. Behind every knob there is a hidden switch and the switches are wired in "parallel". That means, when one button is put in "sparkstand", all plugs will spark. At least it should be.
In the youtube movie you can see how these switches are in a string.
So I suppose that the switch behind the button for the main burner does not work.
Fortunately, you still can lit that burne r with the other buttons.
Look at the movie, may be you can fix it yourself.
Kind regards, Dik
Maytag Gas Stove Burner Won Light Spark Ignition Switch
Feb 04, 2018 | KitchenAid KGST307 Gas Kitchen Range
The electronic ignitor on front right burner no longer works.
All ignitors should fire regardless of which burner is turned on. See if the right front will light up if you turn on another burner or look for a spark. If not, the ignitor is probably fouled and needs a good cleaning. If the right front burner will spark or ignite when a different burner is turned on, it is the right front control switch - not an easy fix. When cleaning the cook top, if you remove the knobs, any liquid that gets into the switches will short them out. Found that out the hard way.
Dec 20, 2009 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
When I turn the surface control to lite sparks come from the other surface controls. The burner does come on but we are afraid to leave the burner because of the sparks coming from the other controls. Do...
When one burner knob is turned to the light position, all burners will spark. Once the burner lights, just move the knob slightly so it is no longer in the light position and all sparking will stop.
Nov 12, 2009 | Maytag MGR6772BDS Gemini Gas Kitchen Range
When I turn on a burner, all the other burners click like they are trying to turn on as well. The clicking is continuous and really annoying! Thanks for your help! Tammie
Anytime you turn on a gas range all burners click for safety reasons. If a knob has been turned by mistake the gas lights to prevent gas from escaping into the room. If you turn the control knob past the LITE position after the burner lights you should be OK and stop the clicking. If the clicking continues regardless you have a defective ignitor switch that must be replaced.
Aug 26, 2009 | Jenn-Air JGR8850 Gas Kitchen Range
I have a GE glass cook-top electric range. burner stays on.
You need to replace the switch which controls the burner.
Apr 07, 2009 | Kitchen Ranges
Two from burners will not start , unless a match is used
Check the position of the ignitor that sparks, compare it to the burners that do lite.
The other one may ne replacement
Mar 18, 2009 | Jenn-Air JDS9865BDP Stainless Steel Dual...
Wirlpool elect range GR465LXLS, cant control heat on dbl burner
yes it is your control infinite switch the knob swicht that goes from 1 to 10 or min to max thanks from gilles
Mar 13, 2009 | GE Cooktops
Dual element burner on glasstop range...inner element stays on
It is the burner control (behind the knob). The triac in the control has failed. $50 item, 10 minute change. Just make note which wire goes to which terminal.
I doubt that it is the control board, as the board has little to do with the stove top, but rather controls the display and the oven temperature/feedback monitoring.
Hope this helps.
Jan 14, 2009 | Frigidaire FEF366DC Electric Kitchen Range
Burner on range will not turn off
Look at the back of your range there should be schemetic for your power control board. look for defective burner wire going into relay. There should be 5 relays in rows. Realy is the problem. I had the same problem with my front left burner stuck on high.
After replacing everything works okay.
Apr 07, 2008 | LG LRE30755 Electric Kitchen Range
Kitchen Ranges Logo
116 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
