Question about Zebra TLP 2824 Printer
HELP! I need to help installing a zebra label printer
  • 6,993 Answers
I believe your printer is Zebra TLP 2824 Printer. In order to install the your printer, you need to install the drivers for the printer first on your computer, after installing the drivers, connect your printer to your computer while your printer is turn on, and your printer will automatically install the printer since the drivers for the printer is installed earlier.
In case you don't have the drivers for your printer, you can visit the link below, download the driver and install it on your computer.
That's all you need to do for your printer to be installed. Once you follow the above steps, you printer will be ready for use.
If your printer is not the above model, please let me know and state the right model for your printer.
I hope this will help to solve your problem and if it doesn't, please let me know so that I can give you further assistance.
Good luck
Posted on May 15, 2010
  • Walesarumi
    Walesarumi May 15, 2010
    for further detailed assistance, you can visit the link below:
    http://www.ehow.com/how_4870546_install-...
    or
    http://www.ehow.com/how_4815742_set-up-z...
    Please don't mind the printer model stated on the link, its the same process with any Zebra model.
    Take care.
4 Suggested Answers
SOURCE: label printer
Try reseting the auto gap detection.
http://www.fixya.com/support/p257130-zebra_lp_2844_thermal_printer/manual-19245/page-15
Posted on Mar 30, 2008
  • 54 Answers
SOURCE: zebra T402 USER GUIDE
The T402 has been oblsoleted and Zebra no longer supports the unit.
I do have a copy of the manual in PDF form.
Posted on Feb 25, 2009
  • 62 Answers
SOURCE: An extra, blank label prints from a Zebra 2746e.
Check media settings in the printer driver. Check version of printer driver. Zebra printersuse an internal printer driver with their Zebra Designer software (Zdesigner driver) or a ZUD (Zebra Universal Driver) for other windows applications. These drivers can be downloaded directly from the zebra website.
Alternatively you can download the seagull scientific driver and use that instead. (used with bartender program)
Label skipping occurs if the media dimensions are not specified correctly. The important ones are label height, and media setting for type of media.
Perform a media calibration before you go changing settings. Power on printer, Hold top and bottom buttons in on control panel for 5 seconds, release bottom button only then when printer starts feeding labels release top button. When printer finishes press feed button.
Posted on Apr 18, 2009
Using copaq 7400 laptop for running zebra 90xiIII
Can you explain in complete sentences what you are trying to achieve here?
It sounds like you:
have 90XiIII printer
have a Laptop running Windows 98
either need or have a driver
either need or have a label printing program
want to print labels with sequential numbers.
Go to zebra.com and download the Zebra Designer label creation software package. Read the help files. Install the driver for your printer from this application. Create a label and hit print. the sequential label feature may not be available on the free version.
Jan 18, 2010 | Zebra 90XI II Printer
Problem with my Zebra LP2824 printer
You have to calibrate the printer to solve this problem
Check following to solve this problem
1)Press the feed button and hold it for 1-2 seconds switching printer on.It will calibrate the labels.
2)Install Zebra Designer driver from CD.After installing Zebra designer Add printer Zebra Designer LP2824.After installing driver right Click the printer Zebra Designer LP2824 and go to printing preferences then select advanced option and calibrate printer.It will calibrate printer
3)Check the label size is properly set in printer or not.Label width and label height in printer settings should be same as label which you are using .
Aug 22, 2009 | Zebra Eltron LP 2824 Thermal Printer
Zebra stripe s500 skips 5 labels prints 1 skips 1
He are the steps you need to calibrate your printer
Label Length Calibration
Note: This is typically the only procedure required when first installing the labels.
1. Load the printer with media and ribbon.
2. Press the printer front panel MODE key until the CALIBRATE LED is lit.
3. Press the FEED key and allow the labels to feed.
4. When the labels have stopped press the MODE key once to save the value in memory.
Jul 10, 2009 | Zebra Stripe S500 Thermal Label Printer
ZebraDesigner Pro is changing my settings
If you have two printers 105se and the 105sl must install the two printers and select the correct model when you print your labels.
Mar 10, 2009 | Zebra 105SL Thermal Label Printer
Zebra LP 2844 label printer
I'm having the same problem and got the same result when trying the manual calibration on the 1st page...
Jul 14, 2008 | Zebra LP 2844 Thermal Printer
Printing every third labels ---> not every one:(
Sounds like the label height is set too high. Go into Printer Preferences in Windows and change the height dimension to match the size of the label you are using.
May 08, 2008 | Zebra S4M Thermal Label Printer
Printing every third labels ---> not evry
You need to take the labels out.
If you are using the labels that have perforations is where you can tear them off.
What you need to do is to
1) Switch off printer
2) ensure that the ribbon is loaded correctly
3) take some labels, feed them through the mechanism till you can see them coming out from the other end.
4) Make sure that the labels are lined up with the alignment mark or sometimes with label printers there is a light.
5)switch on printer and do a test print
Printer Stripe S-500 Zebra
Question, when the printer prints is there an image of the data on the ribbon when it spools onto the ribbon takeup spool? If so, the ribbon may be installed backwards. I'm sure you know what you are doing but one must check even the smallest detail when trying to solve these strange problems. If the ribbon is installed correctly and there is no image of the data on the ribbon you may be dealing with a bad printhead and the printhead needs to be replaced.
Dec 19, 2007 | Zebra Stripe S500 Thermal Label Printer
When printing more then 10 labels from Acrobat some of them are missing
Hello!
Dear
I need ur assistance about this types of Model TLP-2844,LP-2844,S4M,S-600,105SL,110xiii,140xiiiPlus,Z4M,Z4MPlus,How can I Install a Printer With Label and Ribbon?Can U help me regarding this problem?I am waiting for ur assistance.If possible please send me a video file about how to Install a Zebra Printer with label and Ribbon.
Dec 13, 2007 | Zebra Z4Mplus Label Printer
Zebra TLP 2824 Printer Logo
143 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
