Question about ViewSonic VA1912wb Monitor
Viewsonic VA1912wb power goes off
I have a Viewsonic VA1912wb monitor. When I first boot the computer all is well, after about 15-20 seconds the monitor goes blank. The power light which went from amber to green as normal the goes off. I have unplug the power cord and go thru the process to get anything to happer again. When the power comes on at first eth video appears normal....
Any thoughts anyone.
Terry
[email protected]
  • 2 more comments
  • azraq27 Sep 04, 2008
    Yeah... the only way too get it back is to:
    - unplug power
    - unplug video
    - wait ~30 seconds
    - plug in power
    - plug in video
    If anyone has any clue what's wrong, I'd appreciate it
  • Anonymous Sep 21, 2008
    Yeah I have the same problem and with the same monitor. the first time i restarted it, it worked but now it doesn't. Help please !!!!
  • Roadstump Oct 01, 2008
    same problem, did your suggestion and monito powered up but did not see video and would shut down. Had to do a hard reboot to get everything back up to normal. This is the first time my monitor has shut down like this and I've had it for a couple of years.
  • ajay May 21, 2012
    Even I am facing the same problem.....
    Screen goes blank when I first boot computer.....
    after some time it works fine....
    this happens at every boot..........
    please suggest good solution..........
XZAxZC
Posted on Sep 03, 2008
SOURCE:
I have a view sonic 1912wb a blank screen come on for 1 second then goes of. Can this be repaired?
The problem of this unit is bad or bloated electrolytic capacitors like this image:
bc3eb3e.jpg that is common to viewsonic monitor.
Sep 29, 2010 | ViewSonic VA1912wb Monitor
My viewsonic monitor goes into sleep mode and it doesn't want to wake up. Eventually it works when i pull the plug and reconnect, or reboot but it is getting worse.
It may be getting worst because the capacitors in the power supply are going bad, look for caps with bulgign tops or seals, see example of failed VIEWSONIC monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Mar 21, 2010 | ViewSonic VA1912WB 19" WideScreen Monitor
Monitor fails during boot
the problem is due to hi-esolution, boot in SAFE MODE uninstall / reinstall the video drivers
Feb 07, 2010 | ViewSonic VA1912WB 19" WideScreen Monitor
I have a VA1912wb ViewSonic monitor. Lately, when I power on the computer, the monitor is black, I press the buttons on the monitor, it takes 5-10min to power up.
The viewsonic monitor is a good unit.
If the unit takes more than 30 seconds to power up, you have a problem with the power supply and will have to be repaired.
Oct 20, 2009 | ViewSonic Computers & Internet
No display on Viewsonic VA1912wb
Your monitor sounds like it has gone bad. Cost for a repair is not worth it, a new one would be cheaper. Prices have gone down a lot in three years
Sep 11, 2009 | ViewSonic VA1912wb 19" LCD Monitor
ViewSonic VA1912wb 19" LCD need sound driver
operation174 -
Here is the driver download page for your monitor:
http://www.viewsonic.com/support/downloads/drivers/?prod_name=VA1912wb
Choose the correct download for your operating system.
Thanks,
videoman7
Aug 07, 2009 | ViewSonic VA1912wb 19" LCD Monitor
Viewsonic va1912wb monitor goes blank for few seconds and comes back and this happens very often
Your power/inverter board needs to be overhauled.
Your capacitors on the board are probably burned out.
If you open it up and send me a picture , I may be able to tell you if they are or aren't.
There is also a chance a transistor has gone bad on the board.
I repair many viewsonic boards on ebay
bammbammfran
Oct 21, 2008 | ViewSonic VA1912wb Monitor
Viewsonic VA1912WB error says analog signal
I had a Gateway 19" TFT that did the same thing.
Does the power light stay on? If so, you more than likely have "dry" solder joints at the inverters. Take it apart & shoot a little solder on the inverter solder joints. Good as new now. The solder joints dry out because of the high heat generated. This is a very common problem.
Apr 22, 2008 | ViewSonic VA1912wb Monitor
ViewSonic VA1912wb Monitor Logo
597 people viewed this question
Top ViewSonic Computers & Internet Experts
Steve Allison
Steve Allison
Ekse
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
