Question about Maytag Performa PAV2200
Maytag performa dishwasher pdc3600awx
Our dishwasher is not working. It leaks and the arms don't move so the dishes don't get clean.........it fills and heats, and drains just fine.
Help please!
  • vtbigboi Dec 05, 2008
    i bought a pdc3600awx used and have no way to connect it to the sink. what parts do i need?
    Problem Solver:
  • 5 Answers
Home depot sells the faucet adaptor you need. It is called "Long Dishwasher Aerator" and states 55/64 " - 27 thread. The number on the top left which I suppose is the part number is 36094B. It also has a yellow stick with "2A" on it, which should help find it quickly. It is located in the section where they have all the kitchen faucet aerators etc. Found it easily. Cost was $3.77
Posted on Feb 05, 2009
Http://www.specsserver.com/CACHE/FILE14059.PDF
Posted on Sep 14, 2008
SOURCE:
Maytag mdb7160aww dishwasher not cleaning dishes lower arm not turning fills and drains okay
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Jul 13, 2011 | Maytag MDB6000 Dishwasher
Dishwasher will fill up with water but wont clean dishes.
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound.
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes.
Hope this helps... Please post back if you need more information.
Daniel
May 18, 2011 | Maytag 24 in. MDB5651A Built-in Dishwasher
It is just not cleaning the dishes. Runs - OK
Hi
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes. Hope this helps...
Daniel
Mar 24, 2011 | Maytag Jetclean II MDBH945AWS Stainless...
Dishes not geting cleaned. Soap is left in the door dispenser only partially used.
Hi
Daniel
Dec 13, 2010 | Maytag Dishwashers
My dishwasher is filling up with water but it is not cleaning dishes. the lower spray arm is moving but has limited pressure. The top sprayer is barely moving. Water gets hot but seems as thought the...
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
agf23
Sep 06, 2010 | Maytag 24 in. MDB4100 Built-in Dishwasher
My Maytag Performa Dishwasher is leaking when doing the dishes...
Sounds like your fill valve is stuck in the filling position...see if you you have water standing in it a couple hrs after a drain cycle. if it does then the valve needs to be replaced or you can take it apart carefully,(there is a sping that might fly out and get lost) and clean it. Mine had some small trash in it from the city water line.. The left side has an over flow hole is where your water is coming from..
Nov 12, 2009 | Maytag Performa PAV2200
Maytag performa dishwasher PDBL390AWB - dirty dishes
The problem is hard water. Go to www.dishwasherfilter.com and get their new product. It filters the water and takes out the hard minerals that cause spots and clog dishwashers. It is very affordable and has a money back guarantee.
Sep 13, 2009 | Bosch SHU9915UC Dishwasher
My Maytag Performa recently stopped washing the food off the dishes. It fills and drains like it is supposed to, but seems to not have the right pressure.
Before drawing any serious conclusions check wash arms for blockage in spray holes, < possibly slowing delivery of water pressure > it can be calcium from hard water.
Apr 26, 2009 | Maytag 24 in. PDB1420 Built-in Dishwasher
Dishes not clean. Lower spray arm possibly not moving.
Remove the lower basket so you can access the lower arm.
Does it spin freely? If not, remove and clean the rotating point. Make sure the spray nozzles are not clogged and there as no chunks of stuff inside the spray arm.
Jan 24, 2009 | Maytag 24 in. MDB8600AW Jetclean II...
DISHES ON TOP RACK NOT GETTING CLEAN.
MAYTAG MODEL MDB7160AWB DISHWASHER
fills,starts wash cycle and shuts down about 2 min. into cycle
Nov 12, 2008 | Maytag 24 in. MDB5600A Jetclean II...
Washing Machines Logo
1,278 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
