Question about Bosch Axxis WFL 2060 Front Load Washer
Washing machine makes a noise (like rocks tumbling) when machine is draining water
  • Bosch Master
  • 43,501 Answers
If you are having a problem with your top load washer then check out this tip...
Washing Machinewashing machine makes a noise (like rocks - 2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Posted on Jun 02, 2010
Making a terrible noise when water is going in on spin cycle.Ok when filling .Please help
You hav debris in the drain pump. It's mostly rocks, pieces of glass or coins. You will have to remove them.
Jan 03, 2016 | Washing Machines
Washing machine spins to slow to drain all water
Your drain hose might be clogged. Disconnect it and try to run water through it.
Dec 01, 2012 | Frigidaire 14 Cycle Tumble Action Washer
The drum isn't moving....
possible drive belt is broken if so it should be fairly inexpensive to get it replaced
Oct 02, 2012 | Hotpoint Washing Machines
When water drains and machine goes into spin cycle it starts to make a loud clonking noise. It sounds as if the drum is going to fly out of the machine.
I've experienced this on occasion. stop the washer, redistribute the clothes, etc. so it is evenly balanced. The "rocking" occurs when the balance is uneven.
Apr 10, 2011 | Kenmore Washing Machines
My front load washer started making a very loud noise, as if rocks were being tumbled in the agitator. I did open the washer and found a small stone (probably from one of the children's pockets). However,...
HI- It is possible that one of the stones got stuck between the stainless basket and the tub. This is not a good scenario as the whole from panel and tub boot have to be removed and whatever is stuck has to be fished out. I would look as well for a nail or something long that is stuck down though one of the holes in the stainless basket and is rubbing on the tub. If you only notice during the drain or spin then likely there is something in the drain pump. You can check this by opening the pump cover at the bottom of the machine and removing the pump filter. Your Owners Manual should have an explanation of this procedure. It's pretty easy, just be ready to catch the water that will come out of the pump. Hope this helps, good luck.
Sep 24, 2010 | Asko W6021 Front Load Washer
Washing machine won't spin and drain
the drain pump is not working,after wash cycle the washer should drain the used water,if it does not function-all the next cycle will not commence.
Mar 19, 2010 | Washing Machines
Water draining makes loud noises
if water isn't draining properly the cycle will stop thereon check the drain pipe
Oct 12, 2009 | Washing Machines
I have a LTF2940ES1 horrible noise and wet clothes
you ahve a clogged pump
remove the toe kick
the pump will be right there on the right
get a towel and disconnect the hoses
you will see a sqaure sump take that hose off
and clean it out
check to make sure there is nothing in the pump
reassemble and should be fine
Oct 07, 2009 | Frigidaire GLTF2940ES Front Load Washer
E20 error when starting tumble dry cycle
E20 on your machine means some sort of Drain problem. If it actually goes through the Spin cycle o.k. then there is most likely some water still not drained out at the time of the tumble dry. Check the drain to make sure it isn't clogged. also the drain hose.
Feb 29, 2008 | Washing Machines
Bosch Axxis WFL 2060 Front Load Washer Logo
143 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
