Question about Health & Beauty
Will not continue running.it runs about4 min. then service light comes on .shut it down & immediately start it up and it will run another 4 min.
  • 17,970 Answers
Soun like overheating from some components; need check the compressor, for begin.
Tell us news.
Posted on May 15, 2010
  • 3 more comments
  • owatkins May 15, 2010
    Don't think its the motor because you can start back up immediately without the motor cooling down
    still got problem
    still got problem
  • ZJ Limited
    ZJ Limited May 17, 2010
    If the unit shuts down frequently or fails to start, you may have a low voltage situation.
    Low voltage can also be suspected when:
    • The compressor fails to start or motor does not get up to full power or speed.
    • Other motor operated appliances fail to operate properly or too many motor operated appliances are on same circuit.
    Nebulizer overheats. The nebulizer has an internal thermal protector to prevent the device from overheating. If the internal temperature reaches the preset level, the unit will automatically shut down, and the power LED will turn RED.
    If the Nebulizer does not work, and the light indicator is red, its possible that the thermal protector has been activated due to:
    a. The device operating outside the conditions outlined in this manual.
    b. The device has been operating near heat sources or in hot environments.
    Allow the nebulizer to cool down for a minimum of 40 minutes. Wait until the RED light turns off before turning the nebulizer on again.
  • owatkins May 17, 2010
    This puritan-bennett-companion 590 oxygen concentrator does not work like it should. maybe i didn't it clear this thing will run about 4to 5min.then it shut down then then a light comes on saying to call service man .If you hit the power button to turn the thing off and immediately hit the power button it immediately starts back up and runs 4 to 5 min. I have gone through this cycle for up to an hour and nothing seem to get hot or to slow down. thank you Ollie
Sub zero 700 br
Thank you for your information, are you getting a flashing display showing service on the screen? I the past I have found the service light has shown before the unit shuts down. Your unit has thermistors that need information from the compartment to continue to run. The computer defaults when the information is not present and then shuts down. With this being said, the thermistors could be the cause of this issue you have. There are two in each compartment, one on the evaporator other in the compartment itself. If you have a broken wire or corroded, the computer can't detect the compartment is running and will shut done. Normally will flash service within 20 mins of start up. Look into this and get back to me if you need more information.
Good luck,
Mar 25, 2014 | Sub-Zero Refrigerators
Yamaha ef3000ise shuts down after start up
Replace the low oil light censor, that's ur problem giving false reading
Oct 07, 2013 | Yamaha Electrical Supplies
Ac unit runs, inside blower shuts off after 2 mins, compressor continues to run, t-stat still calling for cool
My central AC unit decided to stop on the hottest day of the year. It would start and run normally for a few minutes and then the blower would shut off. After checking the breakers, thermostat and overflow shut off (did not have one) I saw something about a blower motor capacitor. This was easy to get to and replace and my last hope before waiting for someone to come fix it. The capacitor cost $4.04 with tax and had my AC working again. Needless to say I was beyond happy. I hope this can help others with a similar problem.
May 20, 2012 | Heating & Cooling
Oven comes on for 5 min then shuts down everything even the keyboard
Same problem here on JKP15WOW1WW. The cycle starts like this:
1) Open circuit Breaker
2) Open oven panel and push ribbon connector to ERC. Replace planel.
3) Close circuit breaker
4) Run to oven, notice clock flashing some time but not 12:00 and start Bake. Bake button beeps and starts bake coil.
5) Within 5 minutes hear a beep and all buttons on panel are unresponsive. Bake continues. if oven light is on it continues to glow. Only button that responds with a beep (and not to clear bake or oven light) is Clear botton.
Rinse..wash..lather...repeat...
Nov 11, 2009 | GE JKP15 Electric Single Oven
I have a 93 Jeep Wrangler 4.0 that cranks and doesn't wanna start. Fuel Pump is working and has good fuel pressure. Problem is coil loses power after the first start. I put in new distributor, new coil,...
Ok...you mentioned that there is no spark coming from the coil when it's in no start...Is there power from the alternator going to the coil?
One other item...If the timing chain is worn and stretched, it is possible that the cam sensor and crank sensor are out of phase with each other, just enough where a temperature difference will change starting ability.
One question...while in no start, have you tried changing the throttle position while cranking to see if it lights at part or 3/4 throttle?
Oct 15, 2009 | 1993 Jeep Wrangler
Kohler confidant 4 generator will not run.
i got the same gen and with the same problem
mike
Sep 24, 2009 | Kohler Electrical Supplies
The unit shuts down after using for 4-5 minutes and I smel burnig
Sadly, light duty machines as yours do overheat and shut off. Shredders are rated for run time. An example: 4 min run time with 60 min off to cool down. I could not find your machine's rating. However, given the 10 page volume I would guess the rating close to the 4 min on.
High volume shredders are rated as continuous run. They should never over heat.
Apr 21, 2009 | Cross Infoguard Shredder SX102M
My v.w glof glow light dose not come on?
Most likely ignition switch has gone bad.  Don't need to worry about oil pressure light IF the motor is not running, but IF it IS running, shut down motor immediately until oil pressure can be verified with an external gauge.
good luck
please rate all solutions
Sep 11, 2008 | 1997 Volkswagen Golf
Compressor starts and doesn't stop
Relay for the compressor may be stuck ( Contacts welded) both the fan and the compressor should operate at the same time. Have the relay(s) checked and possibly replaced.
Apr 29, 2008 | Dometic Rooftop RV Air Conditioner
Health & Beauty Logo
55 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
