Question about NEC NR 7800A CD-RW Burner
How to set NEC NR 7800A as the master
I have two CD drive (NEC NR 7800A) and a DVD writer Liteon SHW-160P6S need to know how to connect the cables to make one master and other slave
    Problem Solver:
  • 6 Answers
The First thing you need to do is make sure the jumpers on the back of the drives are set ,one to slave and one to master. there will be a mark either on the case by the jumpers or on a label on the drive. On systems I build
I set the top one to master and bottom one to slave. It makes it easier to hook up the cable to them. The end of the cable goes to the top one and
the other one to the slave.
Posted on May 16, 2010
Cant get burner to reconised on pc
Since this is an IDE drive, please check the Master/Slave/Cable Select jumpers, if you've connected the drive in the same cable of your hard drive, you should check its jumper settings, if hard drive is set as Master, the DVD writer it should be as Slave, if the hard disk jumper is set to Cable Select (CS), the DVD should be in the same way too. After this check if DVD drive is identified correctly in BIOS, it's a good idea to set drive detection as Auto, if this all is OK, check its driver in Windows, it must be appear as a DVD-RW drive.
Mar 03, 2011 | LG GH22NP21 DVD-Writer - Internal...
I have a problem w/ my Lite On SHW-160P6S DVD RW Dual Layer Burner which won't read any DVD or CD. Also, The door to the unit won't open unless you insert a pin in the little hole on the front of the unit...
You will have to open the unit. To be honest, it's a good idea to buy a new one as I had to change to belt and my drive started smoking when I turned my computer on.
Dec 15, 2010 | Lite On SHW-160P6S (SHM160P6S04) DVD RW...
What is the comparable drive for lite-on dvdrw drive SHW-160P6S?
IMHO this Lite-On model,
http://www.tigerdirect.com/applications/searchtools/item-details.asp?EdpNo=4893211&csid=_21
Except it is faster, will read, and burn dual layer disks, and also has LightScribe Technology.
(LightScribe Technology is from HP. You have to use HP disks, (CD or DVD) that are made for LightScribe Technology)
This is the specifications of the Lite-On SHW-160P6S for you to compare against,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1740403&CatId=482
This is information about HP's LightScribe Technology,
http://en.wikipedia.org/wiki/LightScribe
Regards,
joecoolvette
Nov 09, 2010 | Computers & Internet
Says I dont have a dvd burner and I have this one installed.. lite-on DVDRW SHW-160P6S..I can't burn a cd...any help? Sorry for the dumb question you guys!
do it only if u r a professional..
open it up, with the lens assembly there is a small preset, turn it using a screw driver a little anti-clockwise..clean the lens with clean cotton using isopropyl alcohol..
if not done, replace the lens assembly..
or else, replace the drive with a standby n see..
i gotta know: is ur drive pata/sata and the device make n model..
assuming that ur drive is pata, n u r a professional n aware of bios/cmos setup utility handling..!!
open up ur system cabinet and see if all the data cables n jumper settings at the back of the drives (master/slave selection)..itz most important..!!
however, at the bootup (0.29sec) start pressing briskly the key to enter cmos utility or bios setup (eg. F1/F2/F10/Del as applicable)..glance in the standard settings if r detected individually..change the 'Mode' if m/b is hybrid type(both SATA+PATA) : Native/Compatible/Enhanced (as applicable)..
see if ur device needs any additional driver or not, if so try downloading..
also try checking itz data cable for loose or faulty..
above all explanation is applicable only if itz not being detected by the m/b or system..(not for reading or writing problem)..
contact ur system admin/vendor....
Nov 23, 2009 | Lite On SHW-160P6S (SHM160P6S04) DVD RW...
Light_On dvdrw SHW-160p6s working properly but doesn't read anyth
Thanks for coming to FixYa, The problem you have is either a well documented software problem or a failing drive.
Click the below link, then scroll down and click the "Fix It" button. Follow the onscreen instructions, restart when it's done and see if your drive re-appears. If it does, you're done, if it doesn't work then your drive is most likely failed and you should replace it.
www.microsoft.com/kb/341060/
Hope this helps FixYa,
Chris
Jul 15, 2009 | Lite On Beige&Black16X Double Layer DVD RW...
Dvd writer
run filtercheck 4.6 or some tool to remove upper and lower filters.
Aug 18, 2008 | NEC ND-3550A DVD RW Dual Layer Burner
My LH20A1p186c Lite on dvd writer will not do anything. A simple swap into my comp with 3 cables and the comp. does not recognize the new hardware. In fact both dvd and old cd player appear tp be one...
Check the Master Slave jumper on the back of the drives. If using 2 drives on 1 cable, make sure one is set to master and the other is set to slave. The jumper positions usually are labeled on the top of the drive as "M" and "S"
If you have them set to the same, both drives won't work.
If the drive is sharing cable with a hard drive, try changing the M/S setting.
Mar 31, 2008 | Lite On LiteOn LH-20A1P - Disk drive -...
Liteon DVD writer & re writer
You can not use cable select without the correct cable. Most "stock" cables are not. So...
An IDE port supports -2- drives (CD, HD, DVD, Etc). If you have 2 drive connected on the ribbon cable then one must be set to master and the other to slave (the little jumper clips on the back). If it's the only drive on that cable, set it to master. Some drive may say Master Only and Master with a slave.
Geno
Feb 16, 2008 | Lite On LiteOn LH-20A1P - Disk drive -...
NEC NR 7800A CD-RW Burner Logo
104 people viewed this question
Top NEC Computers & Internet Experts
Steven Wander
Steven Wander
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
