Question about Jenn-Air W30400P Stainless Steel Electric Single Oven
Jenn-Air W30400P door does not shut tight most of the time. Light comes on when the door is not tight. How do I fix this problem?
I think that must be a design flaw with that model. I have one, and it does the same thing.
Posted on Oct 20, 2010
  • DrJRHYS Feb 08, 2011
    I have same problem, but no one seems to know if there is a fix for it. Company line is - Our products are highly tested etc. etc. Advise getting it assessed. But no one can say that there is a fix. Is there a fix? Will having it serviced be beneficial, or just a waste of time and money?
Can NOT remove glass cover to change light in oven Jenn Air W30400P
If it is the round glass cover it should unscrew. It is thick glass so you might need to try more force of tap it with a piece of wood.
Jan 02, 2011 | Ovens
The self cleaning oven is not working. The fan in the back of the oven turns very slowly. the door locks briefly and then unlocks and everything shuts off.
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Dec 13, 2010 | Jenn-Air W30400P Stainless Steel Electric...
Jenn-Air electric wall oven door opens slightly when in bake mode
you either have a bent door hinge or a broken door spring.
check the hinges by opening the door and see if it opens past 90 degrees. if it leans towards the floor then the hinges are bent.
if not then your door springs are broken off. you can check this by seeing if the door "feels" heavy when opening.
either way the door should close tight against the frame when up and the light should not come on without opening the door.
Jan 22, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
Time and Temp. display on my JennAir Expressions is not working.
99% likelihood of a bad clock, part # 71001799. This is unfortunately very common with this model. Hope this helps!
Dec 31, 2008 | Jenn-Air W30400P Stainless Steel Electric...
Display light
Found out that I could replace the C3 capacitor with a 100uF 35V (high temperature - 105 C). Spent $1.69 for the capacitor and 1/2 hour taking the unit out, soldering the new capacitor in, and remounting the upper clock unit back on the oven. Works like a charm. No need to buy the whole Clock/Temp unit, waste of money.
Aug 13, 2008 | Jenn-Air W30400P Stainless Steel Electric...
Oven door won't unlock
I posted a message on 12/27 and since then I have contacted Jenn-Air again and as I mentioned above the two things they told me to do didn't work, so I looked at the schematic of the unit and there appears to be a motor that locks and unlocks the door. I have a service repair coming this Saturday and seems to believe the motor is bad. Trenatru are you getting an error message? I was told by Jenn-Air that there is a 6 yr. warranty on electrical parts so will try to keep you posted if that is the cause. If you havn't tried shutting off the power try that first. They said keep it off for a couple minutes before turning back on. If that try pushing on the door and hitting cancel twice. If those two things don't work, will let you know what I find out next weekend.
Dec 24, 2007 | Jenn-Air W30400P Stainless Steel Electric...
Selfcleaning Jenn-Air electric oven
How do I clean my jenn-air double oven when I lock oven door and turn oven to clean mode set time to start I don't get anything. Also when I lock the oven door the oven lock light does not come on.
Dec 05, 2007 | Jenn-Air JJW8230D Electric Double Oven
Jenn Air oven
Does anyone know the part number to replace on model W30400P - the digital display is completely out - the oven heats up but can't read time/temp - not a thing on the LED display - thanks!
Nov 19, 2007 | Jenn-Air W30400P Stainless Steel Electric...
Jenn -air oven w30400p
Do you mean the service engineer replaced the hinges?
If so call him again and tell him he didn't fix it. The service engineer should come again and fix it for free if there's any justice in this world.
Nov 08, 2007 | Jenn-Air W30400P Stainless Steel Electric...
JennAir W30400P
i think you can get downloads from maytag.
Mar 25, 2007 | Jenn-Air W30400P Stainless Steel Electric...
Jenn-Air W30400P Stainless Steel Electric Single Oven Logo
215 people viewed this question
Top Jenn-Air Ovens Experts
 Fix Your Board
Fix Your Board
Dan Webster
Dan Webster
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
