Need a lamp access door for mitsubishi model WD-62528
    Champion:
  • 213 Answers
Parts Information
Vendor need a lamp access door - mit.jpg Part Number 761C751010 Description Door-a/v Substitute Part n/a Estimated Weight Unknown Availability 0 Estimated Ship Date 04/05/2008 or 6 days On Vendor P.O. No Core Price 0.00 Part Price 9.75 Total Price 9.75 Not Available for Resalehope this help you?
Posted on Mar 30, 2008
    Sergeant:
  • 247 Answers
It is usually accessible near the lamp window (the holes where the light shows through). If not, you need to remove the entire case and you will see the light and socket.
However, do not work on it with the power plugged in because microwaves are dangerous.
Hope this helps. :)
I have a mitsubishi 60 in rear projection tv and it only blinks 3 times and dont come on can u help me
the lamp door pushes a switch if the relay is bad it wont register the door is closed
Nov 12, 2012 | Mitsubishi WD-62528 62" LCD HDTV
Where are the capacitors that need replacement located on the Mitsubishi WD-62528.
Look for ones that are bulged on the tops and replace those, if you don't see any bad ones your going to need a ESR meter to test them
Jan 05, 2018 | Mitsubishi WD-62528 62 in. LCD Television
Where is the DM Module on a Mitsubishi WD-62528?
A few pieces of advice--the boards are sandwiched in the main signal chassis and not easy to get at.
If you have replaced those 4 in the actual power supply they do for some models sell the entire signal chassis (has almost everything except the optical light engine) for about 250 exchange.
Let me know what issues you have and I may have suggestions--this model has one very odd issue that is simple---picture gets so dark it is hard to see--not the lamp but easy to fix.
May 26, 2012 | Mitsubishi WD-62528 62" LCD HDTV
I have a 62inch Mitsubishi wd-62528 when I plug it in the timer power light blinks green rapidly, it turns on once and not for long then shuts off with no light
There should be a system restore button on the front that you can use a ball point pen to press. If you hear a difference if operation (like the fans starting up) then you have reset the system. However if it does not come on and light up the screen then you are likely to have a bad lamp. The lamp has an access door either on the front or the back of the set and is usually on the back. Take the lamp out and inspect it for breakage inside the bulb. Also look very carefully at the root of the filament in the center for bubble like of the glass. If so it is bad and needs replacing. The best place I have found to get a lamp w/housing is pureglare.com
May 24, 2011 | Mitsubishi WD-62528 62" LCD HDTV
I have a Mitsubishi TV Model# wd-62528, the red light comes on on the lamp light
Need to replace a new lamp. Or if you still see picture, go to menue and reset lamp. I f no picture, need to replace a lamp.
May 09, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Lamp lcd
Make sure lamp door is properly on, there is a sensor on the door.
Sep 19, 2009 | Mitsubishi WD-62528 62 in. LCD Television
It will not turn on
Try to unplug it for a minute, plug it again and see if the green light blinks for about 2 minutes. After that you will probably be able to turn it on. But the blinking light tells you that is time to replace the lamp.
Apr 25, 2009 | Mitsubishi WD-62528 62" LCD HDTV
TV does not come on
Similar problem with my Sony. Unplug for 36 hours from the wall and it fixed my problem
Dec 16, 2007 | Mitsubishi WD-62528 62 in. LCD Television
Televison & Video Logo
77 people viewed this question
Top Televison & Video Experts
