Question about Bissell 9400 ProHeat Upright Wet/Dry Vacuum
No water from my Bissell
I have a Bissell ProHeat 2X Model 9400 that has always worked great. Today I got it all set up but it will not spray water from the reservoir no matter what I try. Any suggestions?
  • lindaloucrim Nov 25, 2008
    I also have the same Problem. I got my machine all set up and no water coming out of it. I have cleaned Just about everything I can think of.
  • Anonymous May 08, 2009
    no water will come out
  • 25 Answers
I AM BISSELL WARRENTY DEALER, AND MOST COMMON PROBLEM WITH THESE UNITS ARE CLOGGS IN THE LINES AFTER THE HEATER OR IN THE HEATER THEM SELFS VERY DIFFICULT TO GET INTO. THE PUMP IS A DIRECT DRIVE WITH NO BELT AND I HAVE NEVER HAD TO REPLACE ONE NOT TO SAY ITS NOT THE PROBLEM BUT UNLIKELY IF AT ALL POSSIBLE TRY TO GET SOME FLOW AND TRY RUNNING SOME SORT OF LIME AWAY CLEANER INTO SYSTEM AND LET SIT THIS WILL HELP PREVENT CLOGGS AND POSSIBLY CLEAR CLOG OTHER WISE YOU WILL HAVE TO DISSASSEMBLY MACHINE AND CLEAR HEATER AND LINES MANUALLY. IF YOU GET WATER TO ATTACHMENT HOSE BUT NOT NOZZLE YOU MAY CHECK THE RED TIPS FOR CLOGGS. THESE CAN BE REMOVED WITH OUT TAKING THE MACHINE APART.
Posted on Mar 31, 2008
The sprayer nozzles were all plugged. Even the one at the end of the upholstery hose. The vac started working again once I got the nozzles cleared.
Cant find heater in bissell 8920
I have one and watched a video on youtube that shows the red washer in the improper place under water tank. It shoed in unit base. He removed with screwdriver and placed back on nipple on the water tank and it worked.
Jan 21, 2014 | Bissell Brushroll Proheat 2X 8920 9200...
Bissell proheat 2x model 2400 will not spray water or cleaner
You will need to look in the front were the water comes out to see if the jets are clear. SOmetimes they get clogged up.
Nov 12, 2012 | Bissell 9400-3 ProHeat 2X Select Pet...
Bissell pro heater 2x won't spray
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
Sep 08, 2010 | Bissell 9400 ProHeat Upright Wet/Dry...
My bissell stops spraying water, carpet not wet
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
heatman101
rtetrhgd
May 30, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Intermittent water spray or no spray at all with my Bissell proheat 9400
you may have a partial clog, try running a mix of water and vinegar thru it to see if it will clean out the lines and spray tips.
Apr 28, 2008 | Bissell 9400 ProHeat Upright Wet/Dry...
No water
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=618960&thid=467200
No water
Posted by Emma Ann on Mar 25, 2008
My Bissell ProHeat 2x and it's not spraying any water out.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Bissell 9500 ProHeat 2X Clean Shot Upright
This could be that you have a defective water valve assm below the water tank or the trigger assm is not working properly or not connected. You may want to refer to your owner’s manual and check out the trouble shooting guide for no water coming out. You may want to contact the factory or manufacturer to see if they have service tech support or to send out a new owners manual for your current model #. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.bissell.com/ By Phone Customer Service:
(800) 237-7691 Hours:
M-F 8:00 a.m. - 10:00 p.m. ET
Saturday 9:00 a.m. - 8:00 p.m. ET
Don – The Vac Man
Go Ahead. Use Us.
Mar 25, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell 9400 ProHeat Upright Wet/Dry Vacuum Logo
788 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
