Question about Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima wf640
Machine is filling with water in both drum and dispenser and then draining itself without washing!!! I again have checked all nozzles and all seems ok. Have cancelled and put it onto drain but still goes straight to wash and H20 flashing again..
  • sueandrog Apr 05, 2008
    Thankyou for your help! I re-checked everything and machine now works beautifully! Thanks again!
Read your washer instruction manual and check all connections also h2o stands for the chemical sign for water
Posted on Apr 03, 2008
    President:
  • 1,294 Answers
Your exit hose behind the machine has to go over a certain height before it goes into your wall standpipe or sink. The height is marfked behind your machine, approx 3 feet above ground level. The hose should put about 3 or 4 inches into the standpipe, & not fitted airtight. Post back later if the code stil comes up...........
  • prem mathew Apr 06, 2008
    Few people reply like you did, fewer even rate.........thanks a heap!
6ya staff
SOURCE:
Stiff drum.
You can attemt to take the side panel off the machine and look around with a flashlight. if there is something stuck it will be very apparent.
Apr 08, 2014 | Hotpoint Washing Machines
Hotpoint ultima washing machine wma74 drum not turning
If the machine wasn't excessively noisy before and when you select spin only you can't hear the motor running its likely to be the carbon brushes in the motor worn down till they no longer contact stick a new set in if the carbon length sticking out the brass holder is less than around half an inch long
Dec 08, 2013 | Hotpoint Ultima WF860 Front Load Washer
Machine does not clean clothes the machine seems to work ok but the washing feels stiff and there is sedment on the washing the machine is a hotpoint ultima 18 months old.
Try cleaning out the dirty water pipe. Mine was completely blocked up with scale and soap powder. We used a coat hanger and went from the out side as well. The water now pumps out completely without leaving any left under the drum
May 08, 2010 | Hotpoint Ultima WF860 Front Load Washer
Washing machine won't spin
Do you hear the motor spinning loud whirring noise,when drum is not,if so drum belt has come off or snapped,if no noise possible brushes on motor need replacing
Jan 18, 2009 | Hotpoint Ultima WD72 Front Load...
WF860 drum filling with water
Normally I would think that the problem is with the drain system (faulty pump or clogged lines), but you told me that also "When the washing machine is not bein.g used the drum slowly starts to fill with water!!" therefor I think it can be a dafective inlet valve or a faulty control assembly.
In either case, you will need a technician to fix this.
Dec 23, 2008 | Hotpoint Ultima WF860 Front Load Washer
Error code on display panel
F-12 is a drain problem.
Check if the drain hose is free, if cycle stops and gives you f12 without draining the water, there is a problem with the drain system.
The Hotpoint should have a removable paner at the back on the lower side. The panel gives access to the pump. If cleaning the drain hose does not solve the problem, the pump must be removed and cleaned or replaced.The repair should be done by a technician.
Dec 14, 2008 | Hotpoint Ultima WF865 Front Load Washer
Hotpoint WF840P washing machine
the pump is blocked... at the bottom back there is a plastic cover, remove this and the pump is located on the back right hand side.
tilt washer far forward, place a bucket under to catch water and remove pipes.
once cleared, test again, if still no joy then you just need a new pump, but this part is a work horse so i would assume it is blocked with something like a baby wipe or babies sock (usual suspects)
Jun 23, 2008 | Hotpoint Ultima WF840 Front Load Washer /...
Click on your model number (below FIXYA) on this website, & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, you have your manual on line. You might find the mysterious codes there.
And dont forget to rate me on this great site.
Possible your thin hose going down from the pressure switch to the pump area is off or blocked; this hose should be blown into from the top, or try to unblock & refit carefully from below the pressure switch
Mar 30, 2008 | Hotpoint Ultima WF860 Front Load Washer
Soap dispenser
Some softeners are too thick, you could dilute this with water before you add to the machine. Note: Your tube to the softener drawer could be loose or something, you could check this by taking the top of the machine off to examine. Actually simple.
Oct 07, 2007 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Ultima WF860 Front Load Washer Logo
238 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
Eric Taylor
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
