Question about Dryers
Dryer has light on inside butwill not turn on dryer
    President:
  • 2,468 Answers
The door switch can cause this because one way the switch lights the lamp and when closed the other part of the switch operates the unit,then check the thermal fuse located on the blower/ vent housing
Posted on May 15, 2010
Why is my overdrive light flashing on my 2005 ford focus
That is what is called limp mode does the transmission shift gears real hard you need to Pull transmission codes and see what is the problem
Feb 13, 2015 | 2005 Ford Focus
Does this dryer has a light inside?
Not all dryers have an inside light. Yours may have one though. Do you see a light socket and cover inside your dryer. If so, you may just need to replace the bulb. If not, you nave to just live with it until you get a new one. Unless you are in a dark room, there should be enough to do your drying.
May 05, 2014 | Bosch Nexxt WTMC 3300 Electric Dryer
Car won't start
Please further define won't start; engine will not turn over, engine will turn over but very slowlly, engine turns over fine butwill not start? Please let me know.
Thanks,
Tom
Aug 27, 2010 | 2000 Mitsubishi Diamante
Has power but won't start. the light inside the
First, go to your circuit panel and turn off then back on the dryer breaker.Second, check for a broken belt. The belt switch will be open if the belt is broken and the dryer will not start. Next.Replace the thermal fuse located on the top right of the heater canister located in the inside rear of the dryer.
Aug 28, 2009 | Hotpoint Dryers
Hot water heater went out when they replaced our dryer doesn't
Make sure the gas valve at the dryer is turned on. Dryers use a glow plug or electronic ignitor to light the gas. There is no pilot light. Plug the dryer in and start it. Look inside the front lower panel to see if the ignitor glows. If it does and the gas does not light then the gas to the dryer is probably turned off. Look for a valve in the supply line to the dryer. Also inside near the front underneath.
Aug 05, 2009 | Dryers
Duet dryer ygew9200ll1 will not turn on
make sure the door connecting also theres a capacitor inside these can stop your dryer working
goodluck
shaun
Jan 11, 2009 | Whirlpool GEW9250 Electric Dryer
Dryers Logo
26 people viewed this question
Top Dryers Experts
