Question about Zanussi FJS1225W Front Load Washer
It has begun to make a loud knocking noise when on fast spin, what could be the problem?
    Problem Solver:
  • 5 Answers
Its very possible that the load you have in the washer was too big, you had too many clothes in there. That or you had something heavy like shoes or something in there or while washing your load got off balance (clothes shifted to one side) and thats what started the knocking.
Posted on May 15, 2010
4 Suggested Answers
  • 234 Answers
SOURCE: loud knocking noice around drum area when on final spin.
This is not an unusual problem for washers, but how to eliminate or reduce it would help to know what brand and model. Sometimes it is the balance ring that sits atop the inner drum, or it could be the antivibrate friction pads that are too worn (they are diffierent on each brand), or could be the balance springs at the bottom of the tub assembly ( there are 3 or 4 springs and one could be broke), or could be the balance (suspension) cables that appear in some brands and the cables or pulley wheels are not in line or are worn/broke.
Goodluck, Macgivor
Posted on Oct 14, 2009
Testimonial: "hi its a creda 1200 excel 1200 w220vw"
emissionwiz
  • 76682 Answers
SOURCE: Model 417.42042100 Makes a LOUD
Thanks for the model number but need the make as well to use the model number to research problems with the machine associated with this noise you have, it would save time to know if this is a front loading machine as well.
Posted on Nov 05, 2010
heatman101
  • 43501 Answers
SOURCE: LOUD NOISE AND KNOCKING ON FAST SPIN
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems
Washer noise when spinning
heatman101
Posted on Feb 21, 2011
Washing machine makes loud noise when spinning
call out a repairman possibly the tub bearings have begun failing .
Mar 14, 2016 | Maytag Bravos MTW6600T Top Load Washer
Washing machine makes loud knocking noise
drain or drain pipes blocked
bearings gone
Aug 18, 2014 | Washing Machines
Washer Problems
heatman101
Feb 21, 2011 | Hotpoint Aquarius WF220 Front Load Washer
Loud noises during spin cycles
Hello, If the noise is a squealing or grinding sound, you are likely looking at a bad seal and bearing.
If the noise is a knocking sound, it's more likely a suspension or out of balance condition.
Thanks
Jun 12, 2010 | Maytag Neptune MAH5500B Front Load Washer
When on a fast spin it is extremely loud, too loud...
Water in bearings causes rust, and rust in bearings creates noise...This is the most likely reason for the noisy spin....Check for any slop in inner drum....Bearings and seals and likely the shaft probably need to be replaced....Quite a big and complex job....Good luck....Nomess
May 18, 2010 | Washing Machines
Loud knocking noice around drum area when on final spin.
i suspect the bearings have gone
hope this has helped :)
Oct 14, 2009 | Washing Machines
Spinning cycle has become very noisy on fast spin
Hi
The most common cause of this is the main drum bearing seal has failed and water has washed all the grease out of the drum bearing and knackered it. You will hear a loud roaring noise on the fast spin when this has happened. As it's certainly not a 5-minute-job, it's not economic to have this fault repaired on an older machine if you are paying for the repairs yourself. Get a new machine.
It is fairly unusual for balance weights to come loose as they are usually held tight by locking nuts. I've seen it happen but not very often. Sometimes they break off the drum completely. Symptoms of this are loud knocking noises, the machine attempting to leave the building while on a fast spin and a heavy piece of metal/concrete on the floor under the machine!
Thanks for contacting Fixya.com
Oct 11, 2009 | Zanussi FLA1201W Front Load Washer
Loud grinding noise when machine operating
Hi
Oct 11, 2009 | Zanussi ZWD1470W Front Load Washer / Dryer
Loud noise in final spin
Verify that the inner drum isn't broken. Sopin by hand it should trun smoothly and staight.
Aug 30, 2009 | Frigidaire ATF6000ES Front Load Washer
Kenmore Coldspot 69182990 - knocking noise
check te rubber mounts at the bottom of the compressor
the rubber rots after some time and the compressor moves on shutting down as the knocking could be that noise
May 20, 2017 | Kenmore Refrigerators
Zanussi FJS1225W Front Load Washer Logo
184 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
