I have a Zenith Personal Control center pcc ...... It has buttons from 1- 14 1-5 is TV 6-10 is VCR 11- 14 is Cable I don't have the codes anymore
I recently purchased a new PCC Multi-Brand Remote Control Transmitter by Zenith that meets your description. It came with the Operating guide with the key codes. If you would like to share the cost of the purchase, I can bill you via paypal for $12.50 and scan and send you the guide.
To make sure it is of use to you though, please identify the brands of TV, VCR and CATV so that I can verify that they are in the listing.
You can email me at liberty@hodgens.net
Posted on Jul 23, 2008
    Sergeant:
  • 247 Answers
Thy Googling the model number with the word "codes?"
Hope this helps.
Posted on Mar 30, 2008
I need the cod
Hello
I don't know what code do you need. Your post is not clear. Anyway assumeing that you needs universal remote contol codes for your Hitachi, and posts this solution.
Three digit universal remote code for Hitachi are:
001/ 004/ 009/ 013/ 059/ 061/ 079/ 088/ 091/ 137/ 139/ 140/ 141/ 142/ 143/ 144/ 145/ 146/ 179/ 210
Four digit universal remote codes for Hitachi are:
0088 0059 0142 0060 0072 0004 0009 0091 0001 0012 0061 0137 0139 0141 0179 0227
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
Apr 26, 2011 | Hitachi 51F510 51" Rear Projection...
VCR doesn't work when installed between cable box and TV
a simple way is to get an AV switch .
you may like to try connecting it with different cables
May 07, 2009 | Televison & Video
Cannot connect a VCR/DVD player to Zenith SY1959Y
you don't need a code for the vcr/dvd combo to work on your tv. You need to make sure you have hooked up the cables correctly. remember that the dvd can be hooked up with the component cabels and the vhs may need to be hooked up thru the tv cable hookup.
Jan 08, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
I am trying to find a universal remote code to control the new Zenith digital tv tuner converter box. The model # is DTT900. It is for a person with low vision who cannot see the buttons on the remote...
Pls post back with the brand and model of the universal (replacement) Remote Control or what remote control you would want to use with the Zenith DTT900 Digital-to-Analog Converter Box.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 23, 2008 | Televison & Video
Remote does not work
Remote stopped working - I bought a universal remote Phillips / Magnavox used a code in the 400 range and everything worked. Hope this helps.
Aug 08, 2008 | Zenith IQB50M90W 50" Rear Projection...
Sitting in a cheap hotel room after work and have to get up to change the channel, have a Philips universal cl034 remote but do not know how to program it to the older Hitachi tv.
http://rsk.imageg.net/graphics/uc/rsk/Support/ProductManuals/1500115_AD_EN.pdf
Here is the link for your remote.
Here is the list.........
Save Code list for future reference Refer to the setup procedure below and look up the 3 digit code for your brand of TV, VCR, etc., from the list below.
Refer to the Owner’s Manual for your remote for more information.
TV including LCD,
Plasma, & Panel TVs
HITACHI ........... 0410 0507 0815 0607
....... 0808 0002 0502 0710 0701 0802
....... 0707 0315 0515 0715 0519 0324
Direct Code Entry
1. Press and hold the CODE SEARCH
on, then release the CODE SEARCH
button.
flashes.
Code Search (by Brand)
Lets you search for a code for a specific
Brand within the Code Library for a
particular manufacturer.
1. Turn on the device (TV, VCR, etc.) to
be controlled.
2. Press and hold the CODE SEARCH
button until the red indicator remains
button.
indicator blinks off once.
4. Press and release the numeric button
(0-9) corresponding to desired
Manufacturer (see table below).
Note, pressing “0” performs a full
library search same as Device Library
Code Search Method.
5. Press the CHANNEL UP button ((or
POWER or PLAY (VCR only))
repeatedly until the device to be
6. Press and release MUTE to install
the code.
Note, when all codes under a Brand
have been searched the red indicator
flashes rapidly for 3 seconds.
Code Search (by Device)
If after trying “Direct Code Entry” or
“Code Search (by Brand)” your device
listed, try doing a device search of the
the steps below.
button.
then stays lit.
the code.
codes under Cable, etc. If you want to
store a VCR code under Cable, etc., first
Entry and press Cable in step 2 of
Brand Search or Complete Search.
Brand Search Table
Look up your brand in the appropriate
column (TV, VCR, etc.) in the table
below. Look for the digit (1, 2, 3, etc.)
that applies to your brand, and enter it
in step 4 of “Code Search (by Brand).”
Digit
6
78
90
TV
RCA, GE,
Proscan
Zenith
Philips,
Magnavox
Sony, Panasonic,
Sharp, Toshiba,
Daewoo
Hitachi, Sanyo,
LG-Goldstar,
Samsung, JVC,
Mitsubishi
Sylvania, Fisher,
Curtis-Mathes,
Emerson
N/A
N/A
N/A
ALL
VCR/DVD/DVR
RCA, GE,
Proscan
Zenith, Apex
Marantz, Philips,
Magnavox
Sony, Panasonic,
Sharp, Toshiba,
Daewoo, Yamaha,
Denon
Hitachi, Sanyo,
LG-Goldstar,
Samsung, JVC,
Mitsubishi
Sylvania, Fisher,
Curtis-Mathes,
Emerson
N/A
N/A
N/A
ALL
CABLE
Scientific Atlanta
Jerrold
Tocom, General
Instrument,
RCA, GE,
Proscan, Pioneer
Zenith, Gemini
Philips,
Magnavox
N/A
N/A
N/A
ALL
SAT/DBS
RCA, GE,
Proscan, Pioneer
Zenith, Gemini
Philips,
Magnavox
Sony, Panasonic,
Sharp, Toshiba,
Hitachi, JVC,
Samsung
General Instrument,
Echostar, Dish,
Hughes, Primestar
N/A
N/A
N/A
ALL
CD/AUDIO
RCA, GE, Proscan
Zenith
Marantz, Philips,
Magnavox
Sony, Panasonic,
Technics, Sharp,
Toshiba
Hitachi, Sanyo,
JVC, LG-Goldstar,
Samsung,
Mitsubishi
Sylvania, Fisher,
Curtis-Mathes,
Emerson, Optimus
Pioneer, Teac, Nad
Kenwood, Yamaha,
Denon, Onkyo
N/A
ALL
HDTV Set Top Boxes
HITACHI . 0538 0324 0336 0931 0834
Mar 04, 2008 | Televison & Video
I have a GE universal remote and want ot program it to work a Zenith VCR
You need the instruction manual that came w/ your universal remote control.Follow all installation instruction carefully.First use the Direct Code Entry.If any of the 4 Digit code from your Zenith vcr doesn't work,use the code search method instead.Be patient because RCA requires you to press the channel up button up to 300 times.Good luck.4TUNE
Jan 21, 2008 | Televison & Video
Apex Digital GB4308 remote
Programming the Remote Control Remote-control switchover Press VCR/DVD, SAT/CABLE or AUX to select the device you want to control. To program the remote control Press and hold VCR.DVD, SAT/CABLE or AUX for over 2 seconds until the LED on the remote control turns off. Release the button the LED will light again (the remote control enters the PROGRAMMING mode). Enter three-digit code number for your equipment. If the correct code number is entered, the LED blinks three times. If you enter a code not listed below, or you press any other buttons than SEARCH and 100+, the LED turns off. To search codes Press ad hold VCR/DVD,SAT/CABLE or AUX for over 2 seconds unil the LED turns off. Release the button (the LED wil light again) and the remote control enters the PROGRAMMING mode. Press SEARCH. Press CH+/- to search codes downwards or upwards. Each time you press CH+/-, the code number decreases or increases by 1 while the remote control sends the code number for POWER button on your device. If the desired code number is found,press 100+ to program the code for your device until the LED blinks three times.Then the remote control exits from the PROGRAMMING mode and returns to norml operation. Or press any other button to exit from the PROGRAMMING mode after the LED blinks rapidly eight times, and the operation is not active. To check the current code number Press and hold VCR/DVD, SAT/CABLE or AUX for over 2 seconds until the LED turns off. Release the button (the LED will light again) and the remote control enters the PROGRAMMING mode. Press 100+ . You may read the code numder according to the LED display status as follows. * If there is no operation within 20 seconds during the steps mentioned above, the remote control will automatically exit from the appropriate operation. Code Number First - digit 0 1 0 1 Second - digit 0 0 4 5 Third - digit 0 6 3 0 First - digit Blinks rapidly once Blinks once Blinks rapidly once Bliks once Secod - digit Blinks rapidly once Blinks rapidly once Blinks four times Bliks five times Third - digit Blinks rapidly once Blinks six times Blinks three times Bliks rapidly once
Jan 05, 2007 | Apex Digital GB4308 43" Rear Projection...
Televison & Video Logo
50 people viewed this question
Top Televison & Video Experts
Electro Med Services...
