Question about Philips SHP 2500 Consumer Headphones
How to open Philips SHP2500 to change the cable ?
I have Philips SHP2500 headphones but the cable broke and i need open them to change the cable .
3 Suggested Answers
  • 17 Answers
SOURCE: Puppy chewed the cord on
You can repair the cord by cutting out the chewed section and reattach the wires to the corresponding wire on the other end and if you solder the connections then it will last longer. Make sure you isolate and exposed wire with electrical tape.
Posted on Dec 20, 2008
rommelalilin
  • 2178 Answers
SOURCE: my dog chewed through the
Feed the dog some good food next time...you might need to solder the wires and make sure the ground is not cross wired to any signal wires.
Posted on Dec 08, 2010
My dog chewed through the cable of my Philips shp2500 headphones, I have reconnected the all the wires but they still don't work. any help guys?
Dec 08, 2010 | Philips (33-01-031) Headphones
The cord on my philips shl9600 headphone was recently severed. The cut happened just below the volume control dial. Are these headphones now completely useless, or can the perfect working head set still be...
See my tip on replacing dodgy cables plugs on headphones. Just click my name. I doubt you will be able to save the volume control, unless it has screws to open it.
Nov 21, 2010 | Philips (33-01-031) Headphones
I have a purchased Philips sbc hc8445 cordless headphones. The sound in the headphones is no louder than what is on the TV. Am I doing something wrong.
I have lost the charging cable for the cordless headphones.
Is there any sample of the jacks as i'm in the midst of searching the cable.
Jul 30, 2010 | Philips (33-01-031) Headphones
I have broke my headphone? now what can i do
depends on where it is broken and whether or not they are ear buds. ove ear headphones or even the on ear, can be easily repaired by soldering the leads back onto the respective speaker. however ear buds tend to be a bit tougher for a novice to solder. if you broke the cable off of the connector, you are better off buying a new pair of headphones modern wires used in the cables for headphones is coated with a colored (or clear, for the grounds) lacquer that is hard to clean off and still get a good connection. good luck, and i hope this helps.
Apr 13, 2010 | Philips GoGear Flash MP3 Player
Problem using headphones 3.5mm output with Sony Bravia tv
Just mute the TV and you will get sound out of your headphones. You may have to turn the TV sound up though.
Sep 09, 2009 | Sony Bravia KDL-37L4000 37 in. LCD HDTV
Puppy chewed the cord on my Philips shp2500 headphones. Is there any way to repair the cord?
Yep. Same exact thing happened to my HD280's. Damn beagles!
Simply buy replacement cord from Sennheiser. It has a nice .100" pitch header so no soldering is necessary to replace the cord.
The trick is to get the phones apart. I almost destroyed mine before I realized you can take the ear padding off by stretching it from around the plastic earcup. Be careful not to tear the thin fabric on the inside of the pad. I believe you can buy replacements of the pads if you are not so lucky.
There are two screws that hold the phone parts all together. Take these out and you are there. Be sure you watch how all the parts come out because it is a bit of a puzzle to get it all back together. The tiny wire are also very fragile inside the phones so be very gentle.
Putting the pads back on was probably the hardest part. :/
Cheers.
Dec 18, 2008 | Audio Players & Recorders
Philips SHP 2500 Consumer Headphones Logo
420 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
