Question about Western Digital Passport WDXML800UE (WDXML800UETE) 80 GB Hard Drive
Copying CCTV DVR data to external HDD for storing data
I want to know how to copy data from internal hard disk of my CCTV DVR when there is only LAN port and external I/O at the DVR. I intend to copy previous data to exteranl HDD before the DVR will overwrite the recordings.
  • 74 Answers
Use the software that comes with ur dvr. connect to it via lan.. and save the infor in to ur computer
Posted on Jul 01, 2010
Tech support
DVRs store files on either data tapes or on hard drives or on memory chips such as SD cards. If SD card then simply remove the card and plug into a computer where it will appear as a removable drive. If internal hard drive your DVR will be equipped with either a IEEE1394 mini socket or a USB mini socket. In either case plug the appropriate cable from your DVR to your computer where it will appear as an external removable drive. If you are talking about a proprietary DVR such as a Foxtel IQ or other brand name DVR then you have to know the format of the video files. Foxtel, for example, uses their own format which can be recovered and saved to an external hard drive on a computer using a video capture card and playing the file back in real time. Time consuming, but that's how I do that. Other branded DVRs use standard video file formats that can be copied to your computer easily via an HDMI socket or USB3 or whatever it has.
Dec 09, 2013 | Audio Players & Recorders
What hard drive is used in wj-hd316a
The hard disk is divided into three partitions: "Normal Recording,"
"Event Recording," and "Copy." Image data is automatically
recorded to the appropriate partition according to the recording
mode. For the normal recording partition, the data is overwritten
when the capacity is full. The event recording partition prohibits
overwriting to protect data. Copy partition prepares data for
retrieval to external medium.
Hard Disk Partitioning Function* automatically
selects the partition to be recorded.
RAID5 distributes image data to multiple hard disks in the
extension unit. Upon hard disk breakdown, lost data can be
restored from other hard disks. When using one WJ-HD300A
Series unit, mirroring function is available for data backup.
RAID5 / Mirroring Function
Playback VMD
One VMD area can set one
playback image for motion
search.
WJ-HD300A Series
Conventional
(* 10, 13, and 16 screens are available only with the WJ-HD316A.)
Even when images from multiple cameras are displayed on a multi-screen,
live monitoring can be achieved on all cameras at a full rate of 60 ips
(image per second). Experience real-time,
full surveillance with
full-rate video images.
Full Rate Live Multi-Screen
4-window 7-window 9-window 10-window* 13-window* 16-window*
Multi-screen in versatile variations
GUI Setup Menu
Time Table
Actual recording result (Example)
hope it helps
Feb 25, 2012 | Panasonic (WJ-HD316A/500) (WJHD316A500)...
I am a complete novice, can you help me please? I have purchased a 3.5 SATA/IDE back up enclosure to transfer files from old to new desktop. I have removed frame holding old harddrive into tower but cannot...
You want to remove the hard disk from old computer, connect it to the enclosure, and connect it externally to the new computer, right?
Now you have a problem connecting hard disk to the enclosure.
Usually there are no SATA/IDE enclosures. They are either IDE or SATA.
If the data connector in the hard disk (HDD) is rectangular with around 40 pins inside, it is an IDE HDD. Else if it has L shaped horizontal connector, it is a SATA HDD.
I suggest you to take the hard disk to the store and ask for a matching enclosure. If you bought the wrong one, they might replace it with the correct one.
If you feel you want to do it yourself, let us know. However an IDE HDD cannot be connected to a SATA enclosure and vise versa.
I sincerely hope you will get to copy the required files to your new computer. However before copying, it is better to install a reliable virus guard.
Sep 14, 2011 | Computers & Internet
It has been only 3 months since i bought my transcend portable 500 GB.up until now everything was fine.but now i'm facing some problems with coping files.when i copy files from external to internal...
Try to defrag you external hard drive, cek your hard drive wether there a bad ?
sometimes bad cluster can running slow for copying your data or else.sorry my english is poor.thank anyway
Jun 25, 2011 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
Want to replace 80Gb HDD with a bigger one. How? Do I have to copy everything from the original one to the new one before actually replacing it? how?
Before you change the 80 GB Hard Drive you can take the backup of your hard drive to the External Hard Drive or if you have any sata case so you put your new hard Drive in the sata case and make 2-3 partitions in the new drive and copy your data in the new hard drive except in first partition which will be primary C Drive for your laptop and will replace data when you install windows in it. after the windows is installed and your data is verified in your new hard drive you can clear your old hard Drive or use it as an External Hard Drive (as you like )
2nd thing which is more safer and reliable is that you make backup CD/DVDs for your data before proceed to formatting or even changing hard drives, it will be very useful and helpful for any unforeseen data loss
if you require more assistance regarding this feel free to reply to this post
Regards, BA
Jan 14, 2011 | Acer Aspire 9300 Notebook
Samsung sp0802n hdd, failure is imminent back up data and replace. wont let me, just goes back to the BIOS screen.
The disk is about to fail and Windows is corrupted. Boot from a Linux Live-CD and copy all your data to an external hard disk. Then replace the hard disk with a new one and junk this one, reinstall Windows and copy all your files from the external hard disk in the new internal one.
Oct 16, 2010 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
My pc tells me that I'm running out of hard drive
You can use either.
You can also use external portable hard disk, you can move all your software and stuff to it.
Better would be installing a new operating system to new hard **** with larger capacity, it will make your system fast.
You can also fit hard disk in your computer PC cabinet, you will just need to set it as "Slave" or secondary hard disk, to do this, setting is available on the hard disk.
Nov 03, 2009 | Compaq Evo D500 PC Desktop
My samsung 500gb external hdd is niether copying nor being format
you can do one thing remove the hard drive from the casing and put on some other casing then check, if the problem is the same then its the problem of hard disk
Oct 09, 2009 | Samsung 500GB, 7200RPM, Internal, 16MB,...
Copy DVR'ed shows to an external hard drive or VHS
how to copy one month dvr data(1 TB)to external HDD
Jul 11, 2009 | Motorola Televison & Video
Tried installing hdd from cctv dvr to save it's contents.....
Most PVR's use a small linux micro operating system to run there menus and handle the drives, as such many of the drives used by them are formatted in Ext2/3. You will need to install a driver in windows that allows it to mount ext? drives and then you should have no problem accessing it. The link below will take you to a download site for a free driver, but they do ask you to donate. Please if it works throw them a bone as this is how they keep providing such useful software for all of us.
If this works, copy the files to your computer and then let the PVR reformat the drive, unfortunately when windows doesn't recognize the drive as being formatted, it marks it. That mark is messing with the PVR but after you add these drivers you should have no problem moving the drive back and fourth as it will recognize the drive and it's data in the future.
http://www.fs-driver.org/download.html
Hope this helps FixYa,
Chris
Jul 06, 2009 | Western Digital Passport WDXML800UE...
Western Digital Passport WDXML800UE (WDXML800UETE) 80 GB Hard Drive Logo
1,434 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
