Question about Asko 1385 Dishwasher
Asko 1385: 13 year old dishwasher stops during cycle. If you push on the middle of the door it starts again. It is like the latch is not working properly but by all appearances the latch works fine. Troubleshooting ideas?
  • 198 Answers
When you latch the door it closes the circuit.
you may have to open the casing of the door to access the switch. it may be stuck or defective.
Posted on May 15, 2010
Testimonial: "bang on! thanks for the input. Asko sent the replacement part as per the recall. It's now working 100%"
Asko d3251 randomly stopping during cycle.
The thing that immediately comes to mind is a faulty door switch or latch. The door switch can be replaced and you might be ok. But the latch would be more tricky to check. Sometimes if dishwasher is not level or if the door springs are misalinged the door tends to slip and release the latch due to pressure. It works when you open and shut. But not sure about the night time cycle. That sounds a bit creepy if it starts again by itself. Why not put a tape around the door and then start. That will help eliminate the obvious ones. The other thing that exends dishwasher cycle time is the lack of adequate water temperature. Could be heater or thermostat or both.
You should be able to stroll through the parts by selecting categories on this site.
http://www.repairclinic.com/Shop-For-Parts/a9b126d867701/Model-D3251White-Asko-Dishwasher-Parts
May 01, 2014 | Asko 24 in. D3250 Built-in Dishwasher
Dishwasher is not cutting off when door is opened during a cycle also is starting without door being shut. Catch on door seems sloppy and worn. Machine is about 8-9 years old.
Hello and welcome to fixya. Based on your description and trusting it is indeed an Asko 1776 I'd suspect you have a door switch "accuator" sticking ( control pin as identified by Asko. pin part #80 575 42, switch part # 80 554 73 ). This has been a random occurance with Asko dishwasher's since they went to this design around 1994 or so. If the dishwasher doesn't stop when you open the door as you stated, here's a possible remedy you can try on your own. Make sure the unit is off first. **Turn the breaker off at your home service panel before attempting any service suggested here on 'fixya"...safety first" This procedure I'm going to suggest can be done easiest and more accurately by removing the door panel & control panel for better access as well as to visually inspect other component. It is quite involved though so I recommend calling in an authorized Asko tech. It can also be done without removing the panels by identifying the small round "pin" in the the door latch channel ( where the latch goes into the door when closed ) and with the aid of a small screwdriver, tooth-pick, paper clip or hair-pin etc. Add some vasiline or grease to the top of the pin working it in via pushing the pin up & down...I recommend removing the panels though. To do this... Open the door and along the both sides and the top you'll see "T20" torx head screws, there are also two in the middle of the inside door panel near the bottom. Remove just the screws for the door skin/panel first, three on each side and the two in the middle as I mentioned. This next part can be tricky and you must also be careful as the edges of these panels are sharp ( auto-mechanics protective gloves are good for this ). Once you've removed the screws from the panel, it should create a small gap at the bottom of the door where the inner and outer panels meet. with a free hand reach in and push the plastic condensation vent away from the slot in the bottom of the door and then push up on the middle door panel attachment ( the piece with two screws removed ) up as you pull the panel away from the door. Now the panel should come off. Now you need to remove the control panel/user interface panel. This should be relatively easy after what you've just managed to do. Remove the remaining "T20" torx head screws for the control panel and it should come off with little effort. Once off you can see the micro-switch and the small "pin" I was referring to earlier much easier. Apply some grease or silicone lube to the shaft of the pin/accuator and work it in really thoroughly. Re-attach just the control panel part of the door and you can test it before putting it back together entirely. Let me know if you require further assistance. Thanks for coming to fixya, please take a moment to rate the help you received. Good luck. Macmarkus :)
Jun 18, 2010 | Asko D1776 Stainless Steel Built-in...
Viking (made by ASKO) Dishwasher Problem
You can find parts, solutions and manuals at link below. Hope this helps, Sea Breeze
Click below
http://www.retrevo.com/s/Asko-D1716-Dishwashers-review-manual/id/21338ci577/t/1-2/
Dec 18, 2008 | Asko D1716 Built-in Dishwasher
ASKO 1605
Hi Guys
My dishwasher this morning has desided to not work correctly.
Its a ASKO 1302 about 20 years old. It has been a very good machine.
Over the last couple of weeks during the washing cycle, the dishwasher has been making a loader noise than usual.
1. Today, the dishwasher timer, travels all the way through its cycle, but very little washing take place.
2. Soap power is still there, plates not clean!!!!
3. Water is hot
4. At the end of the cycle, there is no water in the dishwasher.
5. I'm thinking the problem could be the pump needs replacing.
What do you think?
Greg
Sep 05, 2008 | Asko 1375 Dishwasher
Asko dishwasher d3250 door not closing
the door latch is faulty or needs to be rolled open
Jul 08, 2008 | Asko 24 in. D3250 Built-in Dishwasher
ASKO 1595
yes have you tried what i suggested yet
Mar 29, 2008 | Asko D1776 Stainless Steel Built-in...
Cranky dishwasher
You want to make sure that the dishwasher is level and secure first of all. Then I would look into the door latch assy. Sounds to me that you are not making all the latch switches when closing normally. When you are slamming it, you are making the switches. The heating element runs through the neutral side of switches, therefor if the switch is broken or the latch is not making, no heating of the water. This results in a default or very long wash time. Check this out first....Catriver..post back.
Oct 15, 2006 | KitchenAid KUDS24SE Built-in Dishwasher
Asko 1385 Dishwasher Logo
413 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Owen Barnes
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
